Panamera 2010-Current
Isudar Carplay for PCM 3.1
Old 03-18-2022, 07:00 PM
  #841
GT4Kevin
GT4Kevin's Avatar
I'm stuck at this part, mine looks way different than OPs, I seem to have more going on in mine. Any help would be great
Old 03-18-2022, 07:44 PM
  #842
danby
danby's Avatar
You can look at the PCB they sent you. It should say on it which hardware version it is in the silkscreen.
I have the same setup as you and I ended up removing the green shroud off the sirius XM module connector which won me about 2-3mm of space and allowed the board to clear with the two stacked spacers. I also wrapped some electrical tape over the (now bare) connector, just in case the board rubs a bit to keep it from wearing through the solder mask on the PCB and causing shorts.
Note: earlier they were shipping the wrong size spacers, so if you bought this a while ago like you said, you may need to email them to ask for the taller spacers.
Old 03-18-2022, 07:46 PM
  #843
GT4Kevin
GT4Kevin's Avatar
What if I just don't install the XM card and leave it disconnected?
Old 03-18-2022, 07:58 PM
  #844
danby
danby's Avatar
I'm pretty sure you can't do that. I think I remember reading that it will cause issues beyond just the satellite radio not working.
TWalk (03-19-2022)
Old 03-19-2022, 04:07 PM
  #845
GT4Kevin
GT4Kevin's Avatar
Okay so got the spacers and plugged everything in now I have other issues
The post calls out an optic cable but mine doesn't have one to unplug, so when I plug it all on the radio comes on but the screen is black and none of the controls including volume work. Would that be tied to loose ribbon cables? I'm starting to lose my sanity here and I am dreading opening this thing back up
Thank you
Old 03-19-2022, 06:36 PM
  #846
Willy07
Willy07's Avatar
Not sure what car you have…..but if you had no optical cables…..you most lokely did not have Bose head unit, no biggie,
Black screen is almost always poorly seated ribbon….check them all .
Old 03-19-2022, 06:46 PM
  #847
Gixxerboy63
Gixxerboy63's Avatar
I've decided to sell my Isudar unit...
I attempted to install it myself, but failed in the process. My head unit has Bose, XM modules, backup camera and mic installed from the factory, yet none of the videos provided any details on that + no instructions or videos on where to connect all the remaining wires on the car side of the harness, so it wasn't exactly plug n play for me....
When I gave up and took it to my local installer, they didn't want to mess with Isudar... (but of course) they recommended their own version of Apple Carplay. 🙄
I thought I'd let you guys know about it before officially posting it up in the Classifieds.
PM me if interested
Old 03-19-2022, 07:34 PM
  #848
danby
danby's Avatar
Yeah the instructions are certainly not great. I had to piece it all together from several sources which is kind of annoying, but it's $350 vs the $1500+ most shops charge to install their own solution.
Old 03-20-2022, 04:20 PM
  #849
GT4Kevin
GT4Kevin's Avatar
Alright so got this bad boy installed properly, what a mess.
The OP's post is great help but still had to use about 3 Youtube videos, the horrible instructions provided, and OPs post to get it all done.
What software updates are available for mine (and where to download) and are there any tips I should be aware of?
Old 03-21-2022, 01:33 AM
  #850
LogicoZone
6th Gear
LogicoZone's Avatar
Thank you
Do you have enough clearance with XM radio board on? I took it out and I lost FM/AM radio. I haven't had chance to put it back in and need to figure out the clearance issue. It seems very tight when I initially installed the board. That's why I took it out and realized that I lost FM/AM radio.
Old 03-21-2022, 09:29 AM
  #851
GT4Kevin
GT4Kevin's Avatar
I did, I double stacked spacers, I think it's
 these these
Old 03-22-2022, 01:30 PM
  #852
aenemated
5th Gear
aenemated's Avatar
Just wanted to drop in after 2-3 weeks of this guy and say my experience has been pretty great. Only issue - that isn't a huge one really - is the BT connection being lost and having to reconnect every so often. Really only if I haven't driven in a couple days. I work from home so that can happen in the week.
Otherwise, everything is working great.
I did notice there were some artifacts around UI elements in Carplay (most noticeable in Maps) which I initially just figured was how it would be. But my curiosity got the better of me and I tracked down some much better ribbon cables than the ones found on Amazon and replaced them all including the original factory ones - and display is crystal clear now.
50 Pin
30 Pin
Those have the "ears" and snapped right in much easier than the ones that shipped with the Isudar unit (even before I broke one haha) as well as the factory ones. Hope that can help some of yall having connectivity issues.
Cheers!
BW369 (03-22-2022)
Old 03-22-2022, 01:49 PM
  #853
Willy07
Willy07's Avatar
Excellent find !! for sure better quality.
On the BT connection......I believe that the BT connection is supposed to drop, after connection. Then on, communication, CP, is handled via wifi.
Old 03-22-2022, 01:50 PM
  #854
Willy07
Willy07's Avatar
@GT4Kevin
I believe you have a Version 1.2 board......and your firmware is a few revisions behind.
Old 03-22-2022, 01:57 PM
  #855
aenemated
5th Gear
aenemated's Avatar
Ah. When it happens, I've had to go back into BT settings on my phone and reconnect. Which, like I said, I've only had to do if I don't drive for a couple days so it's not even a big deal. In my old 911, I had an aftermarket head unit and had to plug my phone in for Carplay - which got really old after a while haha ... so I won't complain too much. (Or god forbid going through the 100 steps to just play a song from my phone through the stock PCM - totally why I went down this route in the first place)
Quick Reply: Isudar Carplay for PCM 3.1
