Isudar Carplay for PCM 3.1
#691
I have a Cayenne 92A (2011) with PCM 3.1. I will pull the fuse, but is that still necessary after completely disconnecting and reconnecting again (as I did)? Thanks.
#692
If you disconnected all cables. then no...that would be the same thing.
In most cases.....a black screen is because a ribbon cable is not making it....or defective....either in the cage or at the display board if that got tugged ?
#693
#694
From what I can see here...looks correct. If you have not, redo the ribbons., they are the usual problem.....check that they are perfectly flat, and locked in .....check them that the gold fingers on the end are not damaged. If thats all good...you need to contact support I guess.
Nectarin (02-01-2022)
#696
See my story here: https://www.diymobileaudio.com/threa...de-log.432348/
To answer your question, I have a Umik-1 calibrated microphone and use it with REW (Room EQ Wizard).
BW369 (02-01-2022)
#697
#698
#699
We had the same problems, reconnected everything, make sure that the flat wires with the blue stripes are straight in the connector, so the width of the blue is even across the entire connector.
I had also black screens, we could not believe it was faulty wiring, but it was. Now it works like a charm, no black screens, even the wifi problems solved. (Wifi stayed visible in a wifi analyzer even when the car was turned of for the night).
#700
Thanks, it did work, reconnecting everything. You can't see it looking at the pics, but one connector on the lower board did not fit well. Problem solved!
The following 2 users liked this post by Nectarin:
16PanaHybrid (02-01-2022),
AngelDutchy (02-01-2022)
#702
The official 12-step method to solve Isudar issues:
- Re-seat ribbon cables
- Ask Rennlist for help
- Re-seat ribbon cables per Rennlist suggestion
- Install new firmware
- Re-install new firmware per Rennlist suggestion
- Ask Kimii for help
- Install new new firmware per Kimii
- Install replacement unit
- Re-seat ribbon cables on replacement unit
- ... profit?
The following 4 users liked this post by sac02:
#703
- ... profit?
#704
- ... profit?
There's a missing step with reconnecting the power harness. The first one I received had to be just right to work. The second connected like it should normally connect with no issues when I got to step 10....lol
#705
- ... profit?
however, you forgot a step…. “Pull the fuse and reinstall it”...
That step could be anywhere between step 1 and 9…🙂
