Sponsored By:
Sponsored By:
Cayenne Coding - The Ultimate Guide & Discussion
Old 10-07-2020, 02:18 PM
  #571
rainer
rainer's Avatar
I say it won‘t work with Piwis either.
it‘s locked, don‘t think you can unlock it.
Piwis is just so kind to give you a notification that it‘s locked dor security reasons.
first time I experience such a message..
Originally Posted by F SANE IL
So, you're saying if I do this with a PWISII, it will work or will i need some kind of security unlock?
Old 10-07-2020, 02:38 PM
  #572
siberian
siberian's Avatar
Received 2,304 Likes on 1,370 Posts
There is a Security Code (as in all VDub/Audi/Lambos) that you have to enter to not override, but access certain protected fields. Where this is located and what the code is I have no idea, but I bet there is such a code.
siberian
Old 10-07-2020, 03:05 PM
  #573
twodollardoug
twodollardoug's Avatar
Interesting...
Old 10-07-2020, 03:13 PM
  #574
siberian
siberian's Avatar
Here is an example from my VAG-COM that I used on a friend's 2018 Audi Q7 to disable the ***. As to those who purport "oh this is a Porsche and you can't possibly do this because you're doing it on an Audi...". Well it works on Audis and all common platforms meaning SEAT, VDub, Audi, Lamborghini...
Select Control Module (09)
Select SECURITY ACCESS
Enter code 20113 to login
Select ADAPTATION (10)
Select Channel 34 - Auto Start Stop from the drop down list
Change Enable to Disable or vice versa depending on what it is currently set to
Do It!
SAVE/EXIT
There are dozens and dozens of parameters within Chanel 34 in the Control Module which are protected by a Security Code. I would venture that something similar is present and in place to protect critical parameters. I've not had to dig deep enough into the Launch to find this so I can't provide more details other than to offer this opinion.
siberian
Old 10-07-2020, 03:24 PM
  #575
twodollardoug
Originally Posted by siberian
Here is an example using the VAG-COM that I used on a 2018 Audi Q7 to disable the ***. As to those who purport "oh this is a Porsche and you can't possibly do this because you're doing it on an Audi...". Well it works on Audis and all common platforms meaning SEAT, VDub, Audi, Lamborghini...
Do It!
SAVE/EXIT
siberian
I'll pay you to find it. Lol
Old 10-07-2020, 03:29 PM
  #576
siberian
siberian's Avatar
Necessity is the mother of all inventions. The day I need it I'll find it as we found how to access the Hidden Menus (on the Audi MMI), Security Codes on VDubs.... Where should I send the bill to?
siberian
Old 10-07-2020, 03:56 PM
  #577
twodollardoug
siberian
Lol. If you ever come down from the great state of Alaska I will take you out to dinner.
Old 10-07-2020, 03:57 PM
  #578
siberian
siberian's Avatar
And vice versa, look forward to it!
siberian
Old 10-07-2020, 04:16 PM
  #579
F SANE IL
F SANE IL's Avatar
Don't forget about me..... I'm buying beers and scotch
Old 10-07-2020, 04:21 PM
  #580
twodollardoug
Not to go too far off topic but, I was hoping to meet a lot of you guys at the porsche parade this year because it was supposed to be in my backyard. But we all know what happened with that.
Old 10-07-2020, 04:23 PM
  #581
siberian
siberian's Avatar
I'm starting a list of attendees....
siberian
Old 10-07-2020, 04:56 PM
  #582
F SANE IL
F SANE IL's Avatar
HAHA! quick one.... plus I can't make it to Cali land.
Old 10-07-2020, 05:09 PM
  #583
F SANE IL
F SANE IL's Avatar
Do It!
SAVE/EXIT
siberian
where can i find unlock codes for different things or would it always be the same code for all of them?
Old 10-07-2020, 06:07 PM
  #584
siberian
siberian's Avatar
If I understand you correctly, if the item/parameter is (in the case of the example above) under Security Access then there's only one password that accesses all (I would guess there are over 50 parameters) within that "purview".
A word of caution, in certain cases (such as the SKC, Kessey etc.) you only have ONE chance to enter the correct code. If it's not what it expects, it locks everything up and the car is then totally immobilized. The secret codes for other blocks are of course different. HTH
siberian
Old 10-07-2020, 06:09 PM
  #585
twodollardoug
Whoa; scary.
Quick Reply: Cayenne Coding - The Ultimate Guide & Discussion
