What did you do to your 997 today?
Old 05-18-2021, 07:15 PM
  #11686
3rdpedal
3rdpedal's Avatar
Received 1,829 Likes on 954 Posts
I bought a set of those Apex wheels but in Silver for my 997 - 18" for a winter set. Nice wheel.
3rdpedal is offline
Old 05-18-2021, 11:45 PM
  #11687
axl886
axl886's Avatar
Originally Posted by seoulshakers
is that a tint on your glass?
Yup, 70% tint IIRC.
Originally Posted by stiles_s
Love the look of the Apex wheels. Did you keep track of the weight savings vs stock?
Unfortunately forgot to weigh, but they are slightly lighter than the Turbo rims I had previously, from personal handling them.
axl886 is offline
Old 05-19-2021, 12:41 PM
  #11688
Rdsawyer35
Rdsawyer35's Avatar
I installed the Suncoast red/gray alcantara 6sp gear selector
serpentine belt
Oil change
Front bumper fog lights
LED trunk light
Xtrons HUR
Rdsawyer35 is offline
Old 05-19-2021, 12:47 PM
  #11689
krispyapple
krispyapple's Avatar
It's the rennsport magnetic mount. The MagSafe attaches to that magnetically without any additional requirements. Occasionally it will slide off if you pull the phone sideways, but it's been reliable so far. You can always add a PSA to secure it if needed.
Whats the trick for the magsafe mount?
krispyapple is offline
Old 05-19-2021, 01:09 PM
  #11690
ATX_Native
ATX_Native's Avatar
I have a SpiegeL mount (bought directly from Spiegel for the V2 that has 50% more magnet power) on a modified Rennline dash mount with a SpiegeN MagSafe case. I hated the white MagSafe outline on other clear cases.
It isn’t going anywhere. I don’t even think a car accident would knock it off.
ATX_Native is offline
The following 2 users liked this post by ATX_Native:
irnnr (05-20-2021), RockyTop (01-30-2022)
Old 05-19-2021, 08:02 PM
  #11691
platinum997
platinum997's Avatar
Reinstalled front bumper after a respray, added grill guards and a different front lip.
@emc2.. your 991 lip lastest a long time but it had seen better days. Trying something new on the front but keeping the rears.
platinum997 is offline
The following 3 users liked this post by platinum997:
EMC2 (05-20-2021), irnnr (05-20-2021), vg247 (05-20-2021)
Old 05-20-2021, 11:31 AM
  #11692
seoulshakers
seoulshakers's Avatar
Sweet! I might have to do this. I have the Rennsport magnetic mount and always pull out the corder charger to charge the phone.
seoulshakers is offline
Old 05-20-2021, 03:05 PM
  #11693
ATX_Native
ATX_Native's Avatar
Look at my post a few posts up.
The Spiegel MagSafe mod on the Rennline does not slide off and grips hard.
IMO also looks better and is lower profile in the car.
Old 05-20-2021, 03:31 PM
  #11694
seoulshakers
Yup I saw that! The spiegel mounts directly onto the Rennline? I'm assuming it uses the same ball mount?
Old 05-20-2021, 04:01 PM
  #11695
ATX_Native
ATX_Native's Avatar
Yep, mounts on the Rennline but of course you have to remove the old Rennline magnet.
You end up having to break the Spiegel mount to get to the ball.
Old 05-21-2021, 12:44 AM
  #11696
brocski
brocski's Avatar
Finally got rid of the terrible Bose factory amp and fiber optic garbage. To eliminate the MOST adapter box attached to my Sony XAV-AX5000, I installed a JBL DSP4086 amp to power the factory Bose speakers using a Bose amp bypass wiring harness... it's an incredible upgrade. The JBL amp allows you to tune the frequencies of each speaker and assign the appropriate low level line out signal to each channel through a computer interface, shown in the pic. I opted against reinstalling the Bose subwoofer box, as the woofers in the doors provide more than enough bass for my needs now and I see no need to carry the extra weight/volume in the rear of the cabin. Aside from soldering up the wiring harness and running RCA cables and a remote power wire from the back of the receiver to the amp in the frunk, it's plug 'n play. Can't recommend this enough if you've moved on from the factory PCM unit.
brocski is offline
tegraphile (05-24-2021)
Old 05-21-2021, 12:56 PM
  #11697
lexhair
lexhair's Avatar
All the weather seals and exterior rubber bits got a coat of Shin-Etzu silicone grease.
lexhair is offline
The following 2 users liked this post by lexhair:
misterdega (05-21-2021), RockyTop (01-30-2022)
Old 05-21-2021, 01:14 PM
  #11698
misterdega
misterdega's Avatar
Good suggestion!
Any technique to applying?
misterdega is offline
Old 05-21-2021, 03:58 PM
  #11699
Hootsama
Hootsama's Avatar
I like that set up. How exactly did you modify the RennLine mount to make this work? I've already got the RL installed...
Hootsama is offline
Old 05-21-2021, 09:29 PM
  #11700
rtl5009
rtl5009's Avatar
Parked in the best spot
rtl5009 is offline
The following 3 users liked this post by rtl5009:
ewc (06-12-2021), irnnr (05-25-2021), Kechu (05-25-2021)
Quick Reply: What did you do to your 997 today?
