What did you do to your 997 today?
Old 06-02-2020, 05:50 PM
  #10141
TheTorch
TheTorch's Avatar
Default don't yell at me: I removed my Fisters and Sharkwerks X-pipe
I know I am swimming upstream on this change, but ... yesterday I removed my Fisters and Sharkwerks X-pipe, which Darin installed last October. I went back to stock.
They were a great sound improvement to my 997.2 C4S, but my family did not like the loud factor. Cold start was a lot louder. Happy wife and kids, happy life ... so they say.
I will miss the roar above 4000 RPM, and the subtle burbles on deceleration at 3,000 RPM.
I will not miss the attention it gets from police, scaring bicyclists when I downshift, the fart can burble when pulling away from a stop sign, and not being able to hear the engine whine.
With the Fisters/Sharkwerks, people genuinely think you are going much faster than you are. Right after returning to stock, I did one of my in-town routes, and nobody turned their heads when I drove by. With the Fisters, half the folks gave me glaring "slow down" looks. So now I am back to stealth.
To quote Steven Wright "You can't have everything. Where would you put it?" Probably PSE is the best of both worlds.
TheTorch is offline
Old 06-02-2020, 07:01 PM
  #10142
Q 997.2 C4S
Q 997.2 C4S's Avatar
Originally Posted by Khloesdad
Sorry, I actually meant underside of the engine cover. I'm curious where the intake mates to the engine cover hole/holes. Looks like a quality piece.
Oops, I'm sorry. I misunderstood your request. Unfortunately, I don't have the car nearby right now. It went back to the shop today, for them to try and fix a rattle. Sounds like loose change or bolts, sliding across metal. I think they may have accidentally left behind something during the wing install. I'll get a photo after I get my car back, hopefully sometime before the weekend.
Q 997.2 C4S is offline
Old 06-02-2020, 07:14 PM
  #10143
Q 997.2 C4S
Originally Posted by TheMurse
While the oil was draining I used the interval to install LED bulbs in all interior fixtures as well as the frunk and engine bay. What a fantastic change! I love how something so simple updates the aesthetic of the interior.
Then the main event, 8mm front and 15mm rear wheel spacers. My intent was to achieve the look of lowering without the hassle of springs. I’m thrilled with the results and I think the wheels fill the arches better without compromising the front end on my driveway.
Rear sits flush with arch
It think the spacers are perfect! And I really like how bright the interior looks with the LEDs! How difficult was that to do?
Old 06-02-2020, 07:49 PM
  #10144
Khloesdad
Khloesdad's Avatar
Haha, Stephen Wright. He has the best quotes.
Khloesdad is offline
Old 06-03-2020, 08:39 AM
  #10145
Uwon
Uwon's Avatar
What a day! Spent a few hours in the garage with Hope, learned a lot, crossed a lot off the list, and got to know her better than before.
I started by lifting her onto jack stands for the first time. Thanks to all who contributed their experience and advice to the DIY/Mod thread, it was a bit nerve-wracking but in the end she was up safely and securely. Moved to the top priority, changing her oil. 8.5 quarts later and with a magnetic drain plug in place I cut open and inspected the old filter, finding nothing of note.
Oh, before I forget, having her up on the stands gave me a look at the true state of my right rear tire. Yikes! Goodbye Pirelli, Continental ExtremeContacts on order, installation next week. So glad I found this at home and not blasting down the road!
What a rewarding day, I’m so glad I can wrench on my Porsche but I can’t wait for the next drive.
Lifted, safely up on the stands
This is usually when you should open a beer
The business end, nice & clean
Rear spacer mounted up
Front spacer ready
From whom did you buy the LEDs?
TIA
Uwon is offline
Old 06-03-2020, 12:35 PM
  #10146
TheMurse
TheMurse's Avatar
Thanks! Not difficult at all, but for the heat pumped out by the incandescent bulbs. A trim removal tool helps pop the housings free without damaging your interior. The footwell lights have heat shields that can be tricky to remove if the plastic lens is brittle or aged.
TheMurse is offline
Old 06-03-2020, 12:37 PM
  #10147
TheMurse
TheMurse's Avatar
TIA
Bulbs came in a set of ten from ECS Tuning, converts the frunk/engine bay, dome/map lights, glove compartment, footwells, and puddle lights. Simple, low-cost mod that dresses things up nicely.
TheMurse is offline
VT Blue (06-04-2020)
Old 06-03-2020, 12:55 PM
  #10148
Khloesdad
Khloesdad's Avatar
Thanks for that.
TheMurse (06-03-2020)
Old 06-03-2020, 01:22 PM
  #10149
Medford997
Medford997's Avatar
looks exactly like mine when purchased!
Medford997 is offline
Old 06-03-2020, 02:24 PM
  #10150
PJP13
PJP13's Avatar
Default Not today but last week....
Took the GTS to the track last week.
Had a blast!
PJP13 is offline
The following 3 users liked this post by PJP13:
irnnr (06-03-2020), kru911 (06-05-2020), PhillyNate (06-04-2020)
Old 06-04-2020, 09:26 AM
  #10151
mujeriega
mujeriega's Avatar
Cleaned out the airbox, cleaned the air filters and replaced the engine mounts.
mujeriega is offline
Old 06-04-2020, 08:02 PM
  #10152
VT Blue
VT Blue's Avatar
Thanks for the tip, Murse, just ordered a set today.
Bob
VT Blue is offline
TheMurse (06-05-2020)
Old 06-04-2020, 08:17 PM
  #10153
PCARNTHZST
PCARNTHZST's Avatar
I went for a 3 hour drive today but the ⛽️ station I stopped at didn’t have any fuel 😉
PCARNTHZST is offline
Old 06-05-2020, 01:09 AM
  #10154
JVinPortland
JVinPortland's Avatar
Replaced stock engine mounts with Function First "semi-semi-solid" mounts. Noticeably less vibration at idle. The stockers were, I believe, original; with 59K miles, they were pretty worn....
The job was pretty straightforward using the wisdom of the DIY index--thanks, all!
JVinPortland is offline
Old 06-05-2020, 01:50 AM
  #10155
Jaws1
Jaws1's Avatar
Parked the 997 for the first time in the renovated garage. And installed AFE dry air filters.
Jaws1 is offline
The following 3 users liked this post by Jaws1:
BLU997 (06-05-2020), JVinPortland (06-05-2020), rtl5009 (06-05-2020)
Quick Reply: What did you do to your 997 today?
