zbomb's confused 996
#812
Track day tomorrow - Great !
Weather looks like its going to get crappy right when track time starts ! BOOOO
We'll just have to see how it plays out, going in with some pretty low expectations compared to hoping for a second or two off as of a couple days ago.
Good news, car is ready - running 3/4 capacity on oil, I'll be working that UAOS drain back hard, hopefully
PS - detail after track season to get all the tire marks off her... badges of honor for the moment
#814
TexSquirrel (07-29-2021)
#815
Thanks Jack - Aaron and I are here and dryish… for now.
The following 3 users liked this post by zbomb:
#816
Man - Did today KICK *** ! Yes, yes it certainly did... kicked it up and down, left and right !
The weather was constantly looming but Aaron and I were able to get 1.5 dry session, half a session of misting and I wrote off the last session as it actually started raining and I had already....
RAN A PB 1:20.8 !!!! in the 1 full dry session. Man, I'm HYPED ! The car worked great, still building up a little confidence in the brakes, was a little soft on them vs, the pre ABS / multiple off track excursions days (can see it in the data) but I saw 1.6G of lateral and was around 1.5 very consistently, that is just a **** ton of grip and does it feel GREAT.
Gotta give FSI some credit on the PB - towards the end of the lap I saw a 996 with FSI banners coming into view, it provided great motivation to push the stock M96 just a little bit harder - you'll have to watch the video to see how that plays out
Also - Thanks Aaron and Skip and Randy and DE Aaron and Ryan and Jack and Brad and Paul and Glenn all my 996 homies hanging out in this thread - you guys are the collective **** !
The following 7 users liked this post by zbomb:
GC996 (07-30-2021),
golock911 (07-30-2021),
plpete84 (07-29-2021),
Porschetech3 (07-30-2021),
TexSquirrel (07-30-2021),
and 2 others liked this post.
#817
Glad you guys had a pretty good day. 1:20.8 is AWSOME, way to go!
zbomb (07-30-2021)
#818
Thanks for the props !!! Great video, you are looking good and fast !!!!
zbomb (07-30-2021)
#819
Jason, a lot of good things to unpack in the video.
Congrats on your time. You are carrying a lot of speed. Your car is really rotating with the PSM off and LSD doing its job. Can't get over the water temps being substantially lower with your mods. Oil temps are still high. Your mods plus new radiators (CSF) and low temp thermos will certainly help with more water cooling. Oil cooling still is an issue and hoping LN has moved forward with bracket fabrication ideas for their new oil cooler. Further mitigating oil starvation with improved flow with the UIDS will also be a huge benefit.
Pretty obvious all your hard work is paying off with track times and quantifying ways to improve engine durability with specific mods and procedures.
zbomb (07-30-2021)
#820
Thanks guys ! Spent a little time looking over data for general stuff and this table below is one I really like. Speed high and low, Braking G max, Lateral G max left and right and average RPM. When speeds and AVG RPMs are up - lap times are down. Although, one would assume those things to be true, I think looking at the data points is cool and shows the limits I was able to find over any given lap.
#821
Some cool pics and a longer video from the 2nd session at Thompson, itching to get back on track.
The following 5 users liked this post by zbomb:
DougNuts (08-05-2021),
golock911 (08-05-2021),
Jnelso (08-05-2021),
Porschetech3 (08-05-2021),
Snakebit (08-05-2021)
#822
Love the photo of you and the FSI car.
zbomb (08-05-2021)
#823
The following 4 users liked this post by zbomb:
#824
Current List of Modifications and setup for anyone wanting something comprehensive...
Drivetrain:
UAOS W/Drainback
996.1 Dip Stick - oil level run at FULL mark
LN Spin On Filter W/1042 Filters
LN 2 QT Deep Sump and Baffle
LN Skid Plate
Driven XP9 Oil
Straight Pipe Exhaust - 2 Small Bullet Mufflers
Direct Feed IMS Bearing
AC Delete
Drivers Side Radiator Fan and Shroud Delete
Magnetic Oil Drain Plug
OS Giken Limited Slip Diff
Porsche Factory Trans Fluid
Aero / Exterior
GT3 Lip
Joe Toth 987 Dive Planes
Cup Side Skirts
Cup Mirrors
Cup CF Decklid
Cup Wing
Vented Fender Liner
Rennline Tow Hook
Suspension
Ohlins - 515 lbs/in F, 800 lbs/in R Swift Springs
Ohlins Remote Dampening Adjusters
Elephant F Top Mounts
Elephant F LCA
Rear ADJ Toe Arm
Cup Rear Upper Arms
Cup Sway Bar Rear
Tarrett Drop Links F + R
Brakes:
Hawk DTC 60 Pads
Castrol SRF Fluid
GT3 front Brake Ducts
Sebro Slotted Rotors
996 Cup Master Cylinder
Wheels / Tires:
BBS E88 18x9+50 F, 18x11+67 R
ECS 10MM Front Spacer
Nitto NT01 245 F 305 R
Rear wheel wells clearance aggresively
Data:
Aim MXL2 in CF Mount
Sensors - Oil Pressure, Oil Temp, Steering Angle, Brake Pressure (Oil Temp and Pressure mounted in an oil filter sandwich plate installed with the LN SOFA)
Interior / Misc:
Recaro SPG BK Fixed Mount Driver
Sparco Evo BK Stock Slider Brackets Passanger
OMP Steering Wheel
Cup Quick Release
Radio Delete W/ Window Switches, Horn and Data Link located in Delete Plate
RSS 930 Roll Bar
Schroth Harness Driver and Passenger
CAE Shifter
Rennline Track Mat Driver
Odyssey PC680 Battery in Rennline Mount W/ Killswitch
Fire Extinguisher Mounted on Rollbar
Mostly gutted, no airbags, speakers, rear seat belt, carpet, sound deadening
Alignment Settings and Weight
Drivetrain:
UAOS W/Drainback
LN Skid Plate
Driven XP9 Oil
AC Delete
Aero / Exterior
GT3 Lip
Cup Side Skirts
Cup Mirrors
Cup CF Decklid
Cup Wing
Vented Fender Liner
Rennline Tow Hook
Suspension
Elephant F LCA
Rear ADJ Toe Arm
Cup Rear Upper Arms
Cup Sway Bar Rear
Brakes:
Hawk DTC 60 Pads
Castrol SRF Fluid
Wheels / Tires:
Data:
Interior / Misc:
OMP Steering Wheel
Cup Quick Release
RSS 930 Roll Bar
CAE Shifter
#825
Freekin awesome list!
