996 Forum 1999-2005
UAOS install/tips/tricks
Old 09-02-2021, 04:32 PM
  #481
Red998
Red998's Avatar
I have oil leaking from the oil drain tube. I did hand tight. Anyone else have an issue or solution? Other than it ran great in 100+ temps for many hours.
Old 09-02-2021, 05:54 PM
  #482
Porschetech3
Porschetech3's Avatar
Received 4,562 Likes on 2,067 Posts
Torque the Banjo Bolt to 15 ft/lbs....
Old 09-03-2021, 01:55 AM
  #483
Red998
Red998's Avatar
Thank you Thank you Thank you
Old 09-03-2021, 08:52 PM
  #484
Porschetech3
You're welcome !!! I'm always willing to give product support !!
Old 09-21-2021, 10:30 PM
  #485
Porschetech3
Default PSA
The UAOS will be Legalized in the 2022 PCA Club Spec 996 Rules for use !!!
The following 7 users liked this post by Porschetech3:
Billup (09-22-2021), c210rg (09-22-2021), GC996 (02-09-2022), george_west (09-22-2021), plpete84 (09-22-2021), Tom Loder (09-23-2021), zbomb (09-22-2021) and 2 others liked this post. (Show less...)
Old 09-21-2021, 11:10 PM
  #486
az968gpw
az968gpw's Avatar
Congrats. But that's gonna upset a bunch of engine rebuilders
Old 09-22-2021, 12:32 AM
  #487
Porschetech3
I hope not, they just need to buy them and install them ..
Old 09-22-2021, 11:30 AM
  #488
Yogibara
Yogibara's Avatar
Got any future sales on this coming up? I'd like to add one of these to my engine rebuild project. Perhaps feature it on my channel too.
Old 09-22-2021, 11:54 AM
  #489
Porschetech3
LN Engineering always does a Black Friday Sale and has the UAOS in stock.
I will be doing a May5th Sale (Cinco de Mayo) in honor of my youngest Son's Birthday ( he passed in 2019 )..
The following 3 users liked this post by Porschetech3:
Charles Navarro (09-23-2021), JohnCA58 (09-22-2021), Yogibara (09-22-2021)
Old 09-23-2021, 01:10 PM
  #490
Justin76
Justin76's Avatar
Hey Skip,
I had a shop recently install the UAOS and at idle I get a intermittent vibration where the top of the pre sealed AOS rubs which is causing the noise. Any tips to solve this or is it an installation error.You can only hear inside the car and not outside at all. see video for example
Old 09-23-2021, 04:12 PM
  #491
Porschetech3
Originally Posted by Justin76
Hey Skip,
https://www.youtube.com/watch?v=ZuSyioo2EMw
Hi Justin, I don't think the top of the pre-sealed Lifetime AOS is rubbing , there is plenty of clearance in this area.
What I have seen is one of the Aluminum Coolant pipes can be knocked out of the holding bracket and touch against the joint of the engine/transmission and cause a very strange sounding vibration noise..Check the Aluminum coolant pipes for clearance to engine/transmission.
Old 09-23-2021, 05:13 PM
  #492
Justin76
Justin76's Avatar
Well we figured it out and had to zip tie it to get it off the body.. it was this in the photo below hitting the body .. what you said made sense as well.
I see why now as they installed the flex line underneath the other line.. simple flip of routing should be the permanent fix.
Old 09-23-2021, 06:58 PM
  #493
Porschetech3
Glad you got it sorted Justin, thanks for posting the Solution !!
Old 09-23-2021, 07:00 PM
  #494
Justin76
Justin76's Avatar
Pm sent
Old 09-23-2021, 07:24 PM
  #495
Kris Murphy
Kris Murphy's Avatar
Justin, you can also route that line below the brake booster line so it is not as close to the body of the car.
Quick Reply: UAOS install/tips/tricks
