996 Forum 1999-2005
What did you do to your 996 today?
Old 02-09-2023, 12:01 PM
  #8476
pulpo
pulpo's Avatar
Originally Posted by plpete84
Does anyone know when Porsche moved to metal pulleys? My 2004 has what looks like all metal pulleys, which I imagine are more dependable and wont break up on you over time.
Not sure. The ones I removed from mine looked like yours I'd assume they're original from my '04. I was surprised and a little concerned at first the ones that came with the Continental belt kit are so different.
Old 02-09-2023, 12:18 PM
  #8477
TheChunkNorris
TheChunkNorris's Avatar
Received 2,035 Likes on 941 Posts
My engine was replaced under warranty to the newer set up and had plastic pulleys. Both of my mine were Sebro from FCP and both were plastic.
pulpo (02-09-2023)
Old 02-09-2023, 12:25 PM
  #8478
plpete84
plpete84's Avatar
Received 1,768 Likes on 902 Posts
The ones on mine have the P logo so they're the OEM ones for sure. I suppose they won't break up but the bearing it spins on could seize. I might pull them and see if the bearing seals can be accessed so I can service the bearing itself.
pulpo (02-09-2023)
Old 02-09-2023, 12:46 PM
  #8479
De Jeeper
De Jeeper's Avatar
Received 3,393 Likes on 1,775 Posts
I just looked it up on autoatlanta and they show all the sebro, mubea and oem ones as metal?
Im guessing sebro has both available?
TheChunkNorris (02-11-2023)
Old 02-09-2023, 06:11 PM
  #8480
168Sierra
168Sierra's Avatar
Installed LN Eng catted X-Pipe
The following 8 users liked this post by 168Sierra:
EVOMMM (02-10-2023), GC996 (02-11-2023), GH996 (02-09-2023), golock911 (02-09-2023), Porschetech3 (02-09-2023), TexSquirrel (02-09-2023), TheChunkNorris (02-11-2023), wdb (02-09-2023) and 3 others liked this post. (Show less...)
Old 02-11-2023, 04:17 PM
  #8481
Willys 47
Willys 47's Avatar
Default Putzn around
Center cap tool $40
Center caps $60 each
Replacing hood struts $40 each
Wife not home, PRICELESS
The following 2 users liked this post by Willys 47:
EVOMMM (02-12-2023), wdb (02-11-2023)
Old 02-11-2023, 04:21 PM
  #8482
bmchan
bmchan's Avatar
Originally Posted by ****** 47
Center cap tool $40
Where did you buy the caps. I need ONE!
Old 02-11-2023, 04:40 PM
  #8483
Willys 47
Willys 47's Avatar
You will them on pelican parts. Good source for lots of stuff
bmchan (02-11-2023)
Old 02-11-2023, 04:48 PM
  #8484
Willys 47
Willys 47's Avatar
problem is you buy one, it’s prettier then the one on the same side so you get two, then you hate that they don’t all match and end up getting all four.
bmchan (02-11-2023)
Old 02-11-2023, 06:14 PM
  #8485
wdb
wdb's Avatar
Received 1,199 Likes on 653 Posts
https://www.summitracing.com/parts/lil-45990
$3.99
Old 02-11-2023, 10:35 PM
  #8486
imhighlander
imhighlander's Avatar
Back from the new alternator and time for some fun.
The following 4 users liked this post by imhighlander:
maekwl (02-13-2023), peterp (02-13-2023), Porschetech3 (02-12-2023), TexSquirrel (02-11-2023)
Old 02-11-2023, 10:47 PM
  #8487
chris8382
chris8382's Avatar
Default Driven and Washed
Drove it on 2hrs of errands, including through the Starbucks drive-through to see my daughter, and then washed it.
Tomorrow will be the day for sorting out the passenger window micro switch.
Old 02-11-2023, 11:33 PM
  #8488
TexSquirrel
TexSquirrel's Avatar
Received 2,411 Likes on 1,279 Posts
Finally hit 1000 miles on my engine and changed the oil.
The following 9 users liked this post by TexSquirrel:
EVOMMM (02-12-2023), fazm (06-01-2023), imhighlander (02-12-2023), Porschetech3 (02-12-2023), sasilverbullet (02-12-2023), wdb (02-12-2023), Willys 47 (02-13-2023), wyovino (02-12-2023), yaz996 (02-12-2023) and 4 others liked this post. (Show less...)
Old 02-12-2023, 05:40 PM
  #8489
wyovino
wyovino's Avatar
Love the sign!!! Great idea for people of a certain age.
The following 2 users liked this post by wyovino:
EVOMMM (02-12-2023), TexSquirrel (02-12-2023)
Old 02-13-2023, 11:46 AM
  #8490
marcromano
marcromano's Avatar
One of mine did break up. The outside casing somehow broke up. The belt became loose and was torn up. My indy tech saw it and replaced it with a pulley pulled from another bench engine. had the belt broken, the engine would have seized up. Luckily it was only a $150. repair. Had my tech not caught it I would have had a blown engine if the belt broke.
Always good to replace belts and check the pulleys during regular maintenance. We tend to not think about it.
Quick Reply: What did you do to your 996 today?
