Also followed instructions per attached post and that didn’t work either
Follow the link I provided to download the app and use joserpaq's instructions to authorize third party apps. If it is still not working, let us know specifically what is not working.
Went out to the car, found the obd2 location, turned the power on to the car and plugged in ThinkDiag.
It kept searching via Bluetooth for my device but couldn’t connect?
How do you get this thing working?
I would try rebooting the android. That may fix the connection issue. Does the light on the thinkdiag turn green when you plug it in? I know it then turns blue. I think it turns blue once it connects but am not positive about the timing.
Rebooted the tablet and now the ThinkDiag green light is on. Successfully downloaded the Porsche software to the tablet and confirmed my VIN.
Not sure what to do next. I printed out the 29 page coding guide by KEN G and CROC 2.0 but my screen on the tablet doesn’t look like what they show
The Launch instructions are pretty similar to the thinkdiag. However, now that I switched to a thinkdiag, I put together instructions for the thinkdiag. See attached.
The screens on your tablet won't look exactly like what is in the 29 page pdf.
The pdf represents the screen of a X431.
The ThinkDiag screen may/will be different once you get into the coding.
Start with the instructions in the pdf and somewhere along the way you will have to figure out what to do next once the wording begins to differ.
They'll be similar, but not exactly as shown in the pdf
