Thinkdiag Magic
#376
Not on my car. The car tends to drive the set speed of the cruise control.
CTDan (03-04-2024)
#378
I found the setting to display "N" when in neutral. There are other settings to display gear selection, but I wish I could find a way for it to tell me what gear is selected before I release the clutch and start moving.
#379
But I think that my analogue speedometer is showing about 1 mph lower than the digital speedometer. But it may also be the angle at which I am looking at the gauge. Anyway, I rarely look at that anyway.
#380
@CTDan Found it in Air Conditioning! It works to activate PSE.
Oh...I see you want to have PSE always active. This is the coding to enable the PSE button on the console assuming you have the correct hardware.
That's great - thank you.
Follow up question: Does anyone know if there is a code to set the Sport-Mode Button to "always on" or "remember last setting".
I'd love to drive in Sport-Mode, switch off the car, and then re-start in Sport-Mode right away again.
Any thoughts?
#381
Any thoughts?
Any thoughts?
#382
I think it's been disgusted on this thread. There is no way to program it but you can buy a hardward module for $200 that will do it for you but comments were that you shouldn't go into sport mode until car reaches temp so safer to leave as is and just switch manually. You can code the auto off/on.
#383
Let me know how you like the smarttop. Seeing the video of someone accessing the control module under the seat and using the vampire taps turned me off. I may do it someday if I can't figure out how to make my windows stay down after opening the top. I thought I saw that the install of the smarttop in your car is easier.
#384
This thing can do so many things. If anyone can figure out how to eliminate the hill brake hold on the manual transmission cars, you will be a hero!
#385
This is the coding I have seen to disable Hill Hold assist on the 982. It may be similar on your 991.
PSM (Porsche Stability Management): Function coding- Coding byte 1 – HOLD/Hill hold = Start-Off Assist HOLD/Hill Hold Off {Default: Start-Off Assist HOLD/Hill Hold On}
#387
I love that feature on my mercedes and hate the fact that it only works on a hill on the 991 (I live in S. florida where the only hills are garbage dumps) . It would be great to be able to enable it even when car is flat. Have you been able to do that on the 982?
#388
Any thoughts?
Any thoughts?
I am corresponding with a guy who claims to have coded his 981 to remember the last state for sports mode. I asked him for the coding that he used and am waiting a response. I will pass it along if I get it.
Frankfurt1470 (03-04-2024)
#390
It is possible that I misunderstand what you want but when I am at a stoplight and I press the brake on my 982, the hold light comes on and I can take my foot of the brake without the car moving forward. The car then starts moving when I hit the accelerator. Here is a link to a Porsche video that explains it. According to this link the 991 has this feature.
https://www.porsche.com/usa/accessor...-holdfunction/
