There are several functions that aren't available using IOS device and IOS app. You need to find android device and installed the android app to see those screens from what I've read. I'm using galaxy note that do have access to them.
I bought a Samsung tablet (the same one described on page 1 of this thread) and it won’t allow me to download the thinkdiag app.
You need to sideload the app. Go to the site listed below on the tablet and download the app. Then follow these directions.
Settings> Apps> click on 3 dots and select Special access> Install unknown apps> toggle My Files on to allow sideloading apks. Also, settings > Apps > My Files > Install unknown apps> toggle it on. Then open My Files, select downloads and select the apk to install it.
I now have the app loaded and connecting to the car, but I still don’t see anything called DME and have not been able to locate the overrev report or hours.
go to all system diagnostic then go to system select and you should see it if I'm not mistaken. I don't have it in front of me but if that doesn't work let me know and I'll confirm.
My tablet is very slow slow screenshots are an option.
1. select “all system diagnostics”
2. Select vin decoding to have it determine what car you have and hit enter once vin is displayed.
3. Select “system selection”
4. Select “DME”
5. Select “read data stream”
you should see data stream 1 and data stream 2
one of those will have overevs
you can use the search function once you are in data stream to find overrev
4. Select “DME”
I had to run back to the office, but I'll give this a shot a little later today... Thank you very much for your help and patience.
Anybody figure out if we can enable Android Auto on 991.2 models through this interface
There are some guys on the 918 forum that are discussing that option. 991's didn't have that option without hardware change. If you look around 918 group you can see the progress.
@slowrey I added Android Auto via the link @718socal provided above. It's fairly painless. Note: this will only give you WIRED Android Auto (through the center console). I tried it for a few weeks and then bought a wireless dongle on Amazon and now I love it. There are a few pros/cons to each but the wireless aspect is more pro than con for me. Not to derail this thread, feel free to PM me for additional info.
Yes we tried to make MIB AIO pretty much foolproof. Wireless AA or CP is the way to go for me.
Hoping someone can provide step-by-step instructions on enabling the headlight LEDs to be on with the headlights, and parking lights. I followed the instructions in the 718 forum, but cannot find DD As a marker light = yes. Any help would be appreciated
