This! Boost Logic full Titanium catless. I finally found the exhaust I've been looking for.
I look forward to more miles as the system fully breaks in the titanium turns those nice colors.
I'll post another impression after more miles as well as some drive/fly by videos.
So far, I'm a huge fan.
I heard one of these on a local stage 4 car and it was loud!!
Doesn't sound too loud on the videos you posted but in person, it was on the aggressive side but sounded very nice.
If it wouldn't tick off my neighbors, I'd probably consider something like this.
I like it loud and proud. This system is actually quieter than other setups I've run and several of my neighbors are car guys and don't mind at all.
They also have high flow cat options, which would quiet the system down for those that don't want it as loud as I do.
Did you see my vid? I had the front end up on drive up ramps. Deployed them several times using the button and they were working perfectly. Bladders Full and everything moved freely.
Under speed (75mph) and / or sitting still and using the dial to turn it "sport plus" it wasn't working, or even trying to start. So it has something to do with whatever triggers them at speed or using the sport plus dial.
I'm hoping it's just a hard code that need deleting with PIWIS or something.
Like said above, they were deploying perfectly using the button after code clear buy pulling the (+) side from battery for a few mins. to reset.
Once I drove it over 75 or tried to use the dial to put in "sport plus" it wouldn't even begin to deploy.
Sure did. Thing is - there is hardware to inflate the spoiler, pump, lines, bladder snd software to monitor its deployment. How can the deployment be monitored? Either a microswitch or else more likely imho - pressure monitoring ? So either the software and control modules are screwed up OR they're working ok and when reaching 75mph, bladder pressure falls triggering the error latch. Once that latch is triggered you can't deploy at any speed without a battery disconnect reset. I think hardware problems more likely than software glitches so I still think most likely scenario is a pin hole leak in the bladder/ air supply system or a faulty pressure monitoring sensor. I think your focus on speed sensor is a red herring. Just my 2¢ ! 🤞
I'm sure you're WAY smarter than me about stuff like this (Being totally serious), however, how can I drive 40 miles at UNDER the 78 mph threshold and deploy them PERFECTLY Multiple times (in / out / in / out) in EVERY mode (including automatically with the dial by closing Sport Plus) and NEVER throw a code or cause an issue at all????
Then after 40+ miles of staying under 78 mph, using my Cruise Control to go Just over the 77 mph mark to 78 and THEN All the sudden the msg. / code pops up??
Here's a long boring video of what happened when the Indy checked my DME with PIWIS.... Codes came RIGHT BACK while the car was sitting still running in the shop, after being cleared with PIWIS...Not even deployed and not being deployed and Not going 78 mph. Weird Stuff!!!
I'm sure you're WAY smarter than me about stuff like this (Being totally serous), however, how can I drive 40 miles at UNDER the 78 mph threshold and deploy them PERFECTLY Multiple times (in / out / in / out) in EVERY mode (including automatically with the dial by closing Sport Plus) and NEVER throw a code or cause an issue at all????
I'm darn sure Im no smarter than you 🤪 but my theory is that above 75 mph the pressure on the bladder from drag is enough to exceed the capability of the air supply to maintain required pressure OR there's a constant low pressure which only trips the alarm above speeds of 75mph. Just trying to think outside the box ... be nice if you could get it up on a ramp and spray soapy water on bladder and pressure lines and even better if you could get the front bumper off to get better access. Its an interesting problem even though its a major PIB for you! Ill try and find parts listing to see where the hardware runs ...
I’m not trying to be rude at all but I find it hard to believe that it deploys fine at 77 and trips at exactly 78 repeatedly. To me that’s too much of a repeated fail denoting that’ something electronically is happening at 78. Just seems that way to me and I’m no expert.. The physical differences between 77 and 78 would not be significant enough to cause the failure (again repeatedly) - no?
Does sound like a deployment switch. The mph reads on the cruise and on the spoiler. You have proven that. So it is telling it to deploy, but nothing happens. Hopefully, that is a simple relay type switch or a loose switch connection.
Good luck !
I agree with you both - could be a low pressure condition though that only triggers the failure latch at a designated speed. I think error codes from an obd scan are needed here !
Just got the car back on Friday after a busy first two weeks of ownership. I added a Kline 76MM race exhaust, Tial intercoolers, BMC filter and some love from Sam (who is honestly one of the easiest people I have ever worked with) to get the 91 map dialed in. I am hoping to have some time to test out the 100 map here this weekend and trying to resist the urge to jump up to stage 4 (for now). I also added a set of .2 RS side skirts, some more efficient tint and had the stock wheels powder coated gloss black to provide some more contrast against the GT Silver exterior. The car has been a blast and I am looking forward to getting some more time behind the wheel to really enjoy it!
