Orthojoe's track build journal
#1111
#1112
Location: Mid-Atlantic (on land, not in the middle of the ocean)
Received 4,381 Likes
Sustained 1.6 G lateral grip is in the range of a cup car on slicks. I can't see a 991 GT3 on SC2 or Trofeo R getting close to that, except transiently. Check this out, keeping in mind significant camber of nearly all of the turns:
Weird to see rear tires wearing faster than fronts. Maybe something not right with alignment?
#1113
The mayor had his car aligned at a different shop than me and we are both seeing the same wear patterns. The extreme heat might have something to do with it...
#1114
GT3 player par excellence
brake feel was good, endless brake fluid
do order posted his pedal went to floor. he and I run same MC and front calipers. I'm on pfc08. so I think it's down to fluid.
#1115
Originally Posted by mooty
I did feel power Loss, 3:33 was best
#1116
You guys are studs hammering around that track in 113F heat!!! It was hard enough the w/e before at 101F and limited driving time compared to the open session you had. I hope you had several beers at lunch time to keep you well hydrated?
#1118
Received 1,224 Likes
In regards to the difference in lateral Gs, it probably has something to do with differences in calibration. Internal accelerometer vs GPS calculated Gs. Plus with the solo you need to re-calibrate every time you change mounting position. I can see the trofeo R getting 1.4G in ideal conditions with my accelerometer. It gets 1.3 in extreme heat...
#1120
Kyrocks. The inbuilt display is transient I suspect. My AIM DL & Vbox do not correlate with it after a day at the track. The inbuilt display is always alot higher....
#1122
With SC2 and -2.0 cambers, my readout shows 1.60 Left, 1.73 Right, and 1.48 Braking. But with those being peak values, I don't place much value in them. Hitting curbs, etc. can generate fairly high transient peaks.
#1123
For sure. In that vid I posted, compare the lateral G in T9 (which lacks camber) versus the other turns.
#1124
Originally Posted by kyrocks
I have an aim solo DL as well. I will correlate.
#1125
I freshly calibrate the G-sensor in the AIM Smartycam HD 2.0 every time I mount it to the cage. Like yours it then gives me an accurate overlay on the video feed. I see 1.1-1.2 with a max of 1.3 sustained on a warm day. We have a corkscrew and a lot of elevation on the track. My Porsche dash G-meter often reads 1.68 peak after an hard sessions. dont think Ive had it beyond 1.70 but I dont bounce of teh chicanes much...
