964 Forum 1989-1994
The silly little question thread ...
Old Jun 26, 2018 | 05:58 PM
  #1591
Jjm4life's Avatar
Jjm4life
wow. thanks. more detective work needed
Old Jun 26, 2018 | 06:03 PM
  #1592
Foxman's Avatar
Foxman
Originally Posted by Jjm4life
hoping someone will spoon feed me the part numbers im looking for.
at some point in time, the plastic surround the steering column was trimmed, and therefore looks rough. im looking for the top cover, but also the lower cover to delete the cruise control stalk as well. thanks in advance RL braintrust
I ordered these parts recently for my 993, and to replace the lower housing in my 964 which had a red horn button drilled into it. Part nos. 96455227301 and 96455227503, but it has the hole for the cruise control stalk.
Old Jun 26, 2018 | 06:20 PM
  #1593
LPMM's Avatar
LPMM
M454 is for the cruise control, M562 denotes the airbag model, M659 is for the on board computer option in the tach. So you want the one without the M454 and M659 options if you only want turn and wiper stalks.
Old Jun 26, 2018 | 06:49 PM
  #1594
Jjm4life's Avatar
Jjm4life
Thanks again guys
Old Jun 27, 2018 | 09:41 PM
  #1595
deadendd9009's Avatar
deadendd9009
Silly question for real, but how deep do the output shaft seals (axle seals) have to go on the G50? Flush to the case, they were very close to rubbing on the stubs, so I pushed them in maybe 1-2mm. How deep should they go in?
Old Jul 7, 2018 | 10:54 AM
  #1596
No_snivelling's Avatar
No_snivelling
Default Dry sump question
I am new to Porsche and dry sump systems and I cannot understand why the oil must be checked with the engine running. My simple brain says the oil going into the tank must equal the oil flowing out of the tank otherwise the tank would over-fill or run empty. If that is true, then the oil level should remain the same with the engine stopped or with the engine running. Clearly I am missing something. Can someone enlighten me?
Old Jul 7, 2018 | 05:51 PM
  #1597
Marine Blue's Avatar
Marine Blue
I’m hoping someone could help me with finding a part number for the clips that hold this plastic trim in place. Mine are both missing and I can’t seem to find them on Pelican.
Old Jul 7, 2018 | 06:27 PM
  #1598
No_snivelling
Sorry about the first attempt at inserting an image. You need item 9 and the rubber washers. Check your model year as these parts did change.
Old Jul 7, 2018 | 06:45 PM
  #1599
Marine Blue
Thank you Tom, greatly apppreciated!!
Old Jul 18, 2018 | 12:12 PM
  #1600
Dreamstate's Avatar
Dreamstate
Does a 993 pedal box fit a 964 C4, or am I out of luck if I want a splined clutch pedal rod?
Old Aug 7, 2018 | 03:33 AM
  #1601
Dingo's Avatar
Dingo
If I drain the oil from the engine and oil tank per the normal oil change procedure.
How long can I leave that car sit with no oil in it?
Asking as I need to replace the thermostat to filter line and I'm thinking of refurbing the oil tank at the same time plus It could take a while to get the oil line rebuilt.
Old Aug 7, 2018 | 09:01 AM
  #1602
Rocket Rob's Avatar
Rocket Rob
IHI KING!
No rush as long as you don't try to start the engine. I had my engine drained while replacing the oil lines, thermostat and oil cooler. The engine was "empty" for quote a while. If memory serves, it was 6-8 weeks.
Old Aug 7, 2018 | 05:22 PM
  #1603
Dingo's Avatar
Dingo
Thanks Rob
Old Aug 7, 2018 | 08:18 PM
  #1604
John McM's Avatar
John McM
Dean, before you drain the oil, ensure that the thermostat is open by running it past 9pm on the temp gauge. That way you get the maximum oil out before you start pulling stuff apart.
Old Aug 8, 2018 | 06:51 AM
  #1605
Dingo's Avatar
Dingo
Thanks John. 2 more stupid questions.
Does the car have to be level to drain the Oil?
How long do you have before the thermostat shuts on a cool day?
I'm probably over thinking the whole thing!
