964 Forum 1989-1994
The silly little question thread ...
Old Aug 23, 2014 | 04:01 AM
  #91
Harry Apps's Avatar
Harry Apps
Originally Posted by pi5tolpete
On the C4, there is a pump that runs when the ignition is turned to position2. Sounds like it builds up pressure, then shuts off. Seems to take different lengths of time to build then stop. This is the ABS pump correct? How long should it run to charge up? If it takes 20 seconds, is that an indication of a problem?
Not ABS, but hydraulic booster for braking system and PDAS. Run time varies between cars, but 20 secs is good.
Old Aug 23, 2014 | 06:37 AM
  #92
HiWind's Avatar
HiWind
Another one...
There appears to be three horns in the RHS wheel well. The two low/high horns for the steering wheel horn, and another round one, further forward. What is the third one?
I have recently removed the scattered remains of an after market radar detector system and an after market audiovox security system. But the third horn looks OEM an,d not part of this wiring nightmare.
That's the alarm horn Pete
Old Aug 23, 2014 | 03:04 PM
  #93
bdc1's Avatar
bdc1
Has anyone adult sized travelled in the backseat of a 964? I climbed into mine, couldn't tilt the front seat back and almost had to call for help to get out
Old Aug 24, 2014 | 07:26 PM
  #94
Mr.Alex's Avatar
Mr.Alex
Not unless they are some world class acrobats. I have a hard time just getting in there to clean the rear area, and doing the wiper delete was ball busting.
Can anyone post a picture of what I should adjust to lower the driver side edge of the hood where it meets the bumper. My side to side gaps are equal, but the driver side is a bit larger. I have no leaks, but when I wash with power washer sometimes there is more water right on the inside of the rubber seal where the bonnet closes.
Old Aug 24, 2014 | 11:24 PM
  #95
pi5tolpete's Avatar
pi5tolpete
Great thanks.
I just repaired my low tone horn. Piece of cake.
Old Aug 25, 2014 | 12:31 AM
  #96
J richard's Avatar
J richard
in college i had six people in a 74 targa...short trip, but the girl in the middle up front didn't seem to mind the 3-4 shift
Old Aug 25, 2014 | 12:49 AM
  #97
Don Nguyen's Avatar
Don Nguyen
It's been a while since I had my suspension off, but can anyone tell me which camber plate (left/right) goes on the passenger or driver side?
Also, for the rear shock, does anyone know if the fatter side goes up against the rear control arm (facing outwards) or does it go on the bolt face side (facing inwards towards the engine).
File Type: jpg
File Type: jpg
Old Aug 25, 2014 | 11:05 AM
  #98
Rocket Rob's Avatar
Rocket Rob
IHI KING!
Don - The strut bearing orientation depends on what style of 964 you are running. The turbo's have a wider track. If you are running the narrow body then the strut center is oriented to the center of the car. If you are running a turbo (wide body), then the strut center is flipped 180 degrees to move the top out, away from the center of the car.
Do you have Adrian's book? I seem to remember a photo about the two comparisons.
Old Aug 25, 2014 | 02:26 PM
  #99
HiWind's Avatar
HiWind
Rob (all of you Robs actually ) thanks for the continued insight ....
I have a couple new little questions:
1. re-route spark plug leads:
best way to re-route the ignition wires that run over the fan housing? ie to make the fan housing more visible? there is a gap beneath the housing along the front but that would be close to the block. is it common to just move the cables back over towards the other set that run to the right side of the engine? or is there something cleverer/less obvious?
2. has anyone made a cold air intake that is closer to the decklid/other source of cold air? I'd love more cold air (always helps) but I also have simple aesthetic motivations (damn Singer!) ie to get rid of the stock airbox. Cone filters tend to be loud and will bring in alot of hot air .... or is the volume of air in the engine bay refreshing so quickly (I have read every 3s in a GT3) that its not worthwhile worrying about?
3. removing the 3rd pulley wheel now that aircon is gone - risks re harmonics etc..?
Old Aug 25, 2014 | 02:43 PM
  #100
Rocket Rob's Avatar
Rocket Rob
IHI KING!
1) My spark plug leads are not long enough to be re-routed. You would need to get new leads made to give you enough length.
2) Not sure its a problem as is. The engine cooling fan is drawing in 1100 liters/minute into the fan.
3) The 3rd pulley on the crank pulley is part of the assembly. Its not easily removed. Perhaps there is a motorsports version without and AC belt ring.
Old Aug 25, 2014 | 02:50 PM
  #101
HiWind's Avatar
HiWind
^ thanks Rob! They are likely silly questions but just to clarify ...
1. and were the leads longer, would you go over the back of the cowlng like the other ones?
2. I know the fan is pulling in air under the cowling ... but what about the intake - I thought it was fed via some form of ram air from above through the spoiler?
3. ok thanks! Yes I've seen patrick have one ... wasn't aware the pulleys were all joined. Engine is out so will make that easier - I was concerned re harmonics & balance of the wheels
Old Aug 30, 2014 | 10:32 AM
  #102
pi5tolpete's Avatar
pi5tolpete
What is the different between the Front and Rear brake wear sensors. They sell front and back. Is it the length?
Found the answer when I ordered replacements
Fronts are longer by about 3 inches
Old Aug 30, 2014 | 03:44 PM
  #103
jpar's Avatar
jpar
If you have oem style wires, then you can simply remove to plastic wire holder and flop them over the fan housing. Since you have the engine out, there's a slightly more elegant solution. I took two of the factory wire holders and stacked them on top of the existing ones and used longer screws to hold them both down.
End result
Old Aug 30, 2014 | 03:54 PM
  #104
HiWind's Avatar
HiWind
Thanks for confirming that would work Jpar
Fan and housing looks gr8!
Old Aug 30, 2014 | 05:26 PM
  #105
robt964's Avatar
robt964
Don't bother with buying another crank pulley, just remove the aircon pulley from the one you have. The rubber can be burned out of the aircon pulley to remove it. You'll then need to lathe of the remaining metal center. I plan on doing this when I drop the engine out over winter for a few mods. The hardest job will be getting the pulley assembly off the crank to start with.
