The silly little question thread ...
#1625
Ok I've been on my back staring @ both sides of the tranny & dont see a mounting point that this pc mates with.
I will side w/the majority here an assume it's an engine tray mount which I have no desire to install. Thanks for all your input.
#1626
Definitely the under tray mount. It mounts to the underside of the engine near the tranny. I would leave it off.
#1628
Don't know if this qualifies as a "silly question" , but here goes. This little cover on the side of the trans had a bracket that I removed. When I drained the trans fluid, I descided to replace the gasket (which was almost non existent...just scraped off what was left) & cleaned the surface. Sourced a new gasket & torqued both nuts to 17ft lbs. It has been leaking ever since (see the drop in the pic). Never leaked before....go figure. Suggestions ?
#1629
#1630
That's a possibility, ill also check the gasket fitment by flipping it over to see if it makes a difference.
Of course as soon as I remove the cover 1/2 the trans fluid will drain out.....fun times.
#1633
Originally Posted by S2K993
The fluid in there now is fresh (Delvac) so back in it goes. Thanks for the generous offer Rob.
