964 Forum 1989-1994
The silly little question thread ...
Old 03-29-2018, 08:51 AM
  #1546
james_marshall
james_marshall's Avatar
Here's another for you all.... :-)
When we took the lateral(!) cylinder out before taking the engine from the car, the tip of the cylinder was seized to the metal cap, inside the bellows that are attached to the side of the gearbox.
When we freed it, the metal cap came out of the bellows and of course some liquid leaked out.
I got the cap off the cylinder without too much effort, but of course, had to put the metal piece back into the bellows, to stop the leak. Which it did. Pushing it back into the gearbox, it didn't seem to want to go in completely, but it wasn't leaking.
Ive since replaced the gearbox oil and its now dripping from the bellows, not fast, but its wet and i'm worried that the bellows seal must have been damaged when I took the cylinder out of it.
Ive tried to push the bellows gently back in, but it still seems not right.
Photo below. Someone give me some hope....... and not too much abuse about it needing a clean up! :-0
Old 03-31-2018, 11:47 AM
  #1547
james_marshall
Ive removed the bellows today and have tried to see if its available from Porsche UK, the usual sites in the UK don't seem to list it in the search function.
From those that might have replaced it before, does it just push in and fit, or need assistance to stay in place?
cheers.
Old 03-31-2018, 11:44 PM
  #1548
964Andrew
964Andrew's Avatar
I've replaced both of the bellows on my gearbox. It was a tight fit and I needed to use a socket and a rubber hammer to push them in to place. Both parts are listed in the parts manual.
Thanks!
Andrew
Old 04-01-2018, 01:26 AM
  #1549
LouZ
LouZ's Avatar
Location: Philly Area ----- George Washington took a dump in my backyard!
I just removed and rebuilt the ABS pump that was filled with the "wax"like substance from the brake fluid (thanks RL for the step by step tutorial).
I've bled the brakes repeatedly using my Motiv power bleeder. I can get a firm pedal when the engine is OFF, but when I start up, after a couple of pumps, the pedal goes soft and to the floor, so I have to assume that there is trapped air in the ABS. While the system was under pressure, 30 PSI, I cycled the solenoids, ran the pump motor and even cracked open the 5 hydraulic lines on the pump.
Is there any trick to bleeding the pump (a thought I just had of possibly bleeding the brakes again with the engine running)
Old 04-09-2018, 10:17 AM
  #1550
LPMM
LPMM's Avatar
What kind of glue should I use to reattach dash trim pieces like the ones shown below? A couple of them came undone.
Old 04-09-2018, 11:55 AM
  #1551
Marine Blue
Marine Blue's Avatar
Laurent I’m also curious about this as I want to replace mine due to previous owner putting a scratch near the radio. Is it glued on or bolted on?
Can a moderator make this thread a sticky please?
Old 04-09-2018, 12:14 PM
  #1552
LPMM
LPMM's Avatar
Afshin - It is not bolted on, it is held with some sort of yellowish glue. The left one and the airbag one came off when I removed the carbon fiber overlay the PO installed, so I am looking for the correct glue/epoxy to reattach it.
Old 04-09-2018, 12:43 PM
  #1553
cobalt
cobalt's Avatar
Received 1,935 Likes on 1,170 Posts
I would assume a contact cement should do the trick. Especially if the original is yellowish. I have some of these pieces in nearly perfect condition if anyone is in need.
Old 04-09-2018, 01:37 PM
  #1554
Deserion
Deserion's Avatar
I'd imagine that 3M Super 90 would do the trick.
Old 04-09-2018, 02:09 PM
  #1555
964Andrew
964Andrew's Avatar
I would use Yellow Barge glue.
Thanks!
Andrew
Old 04-09-2018, 03:01 PM
  #1556
LPMM
LPMM's Avatar
Thanks everyone for the suggestions.
Hi Anthony - I think I should be able to save most of my pieces but I will take a good look in the next few days. Can you please let me know which ones you have available, just in case. Thanks.
Old 04-09-2018, 05:05 PM
  #1557
cobalt
cobalt's Avatar
I will pull them out of inventory and PM you. Were these aftermarket? The Factory pieces I have say exclusive in the lower corner of the air bag door. They also came with "Turbo S" or "Air Bag" in lettering in the upper right corner of the air bag door. If these were the pieces they were pricey and required the complete removal and replacement of the air bag door. It splits in the middle when the air bags are deployed.
Old 04-09-2018, 06:04 PM
  #1558
LPMM
LPMM's Avatar
Mine were aftermarket. I must have mistaken your comment, I though you had “regular” black OEM replacement trim pieces, not the carbon fiber ones. I appreciate the offer, but if yours are the carbon fiber pieces, I am not interested as I prefer the look without CF. Apologies for the confusion.
Old 04-09-2018, 06:09 PM
  #1559
cobalt
cobalt's Avatar
I have some standard trim pieces from my C4 I believe the two pieces one from each side of the steering column but need to check and condition. The CF pieces are in my turbo. I wasn't sure if yours were factory or not.
Old 04-10-2018, 03:04 PM
  #1560
JesusFast
JesusFast's Avatar
Question: I have the stock steering wheel for my car and I'm cleaning out the garage...
Is it worth keeping in case I sell the car?
or who cares?
Thanks.
Quick Reply: The silly little question thread ...
