Hybrid stroker project
Old 11-25-2013, 12:09 AM
  #496
blown 944
blown 944's Avatar
Thanks Shawn. It came in at 8.5:1 again using a non surfaced head.
Old 11-25-2013, 05:23 AM
  #497
Dutch944
Dutch944's Avatar
Nice work!!
Old 11-25-2013, 05:59 AM
  #498
Voith
Voith's Avatar
Nice build, as always.
Can you share some more details about closed deck block?
You are using steel wet sleeves and aluminum plate cut to size and pressed in, or is it some other approach?
Old 11-25-2013, 07:15 AM
  #499
Thom
Thom's Avatar
Looking good Sid... What are the two pin holes in the deck, near cyl #1, for?
Old 11-25-2013, 07:24 AM
  #500
black944 turbo
black944 turbo's Avatar
Really interesting, please share more details about the closed duck procedure and the co. That did this.
Old 11-25-2013, 10:30 AM
  #501
blown 944
blown 944's Avatar
The block was done by Dave with FRF. We had been working together on a closed deck design. I wanted a stf "flat deck" so that's where this one came in. I know he's been mia lately, but he is still around.
The block is still dry sleeved. Started with a late NA block. The perimeter and tops of the cylinders are CNC machined. Then the deck plate is machined and press fit. Then the bock is bored and also machined the the flange to be counter sunk into the plate. Using ductile iron allows for using a much thinner sleeve while retaining the superior strength. Tfe sleeves also sit against a ledge at the floor. The deck should be quite a bit more stable with so many attachment points.
Thom, those holes look to be steam vent holed that are in the cometic gasket.
If it really does what I think it will, I should be able to crank up the boost quite a bit. Once I have both cars where I want them, I'll push it pretty hard.
Old 11-25-2013, 01:57 PM
  #502
Black51
Black51's Avatar
Now it's time to put EVO's to shame!
You have a PM Sid.
Old 11-25-2013, 07:31 PM
  #503
BC
BC's Avatar
Hey Blown. We have spoken before about e85.
I found an article that was about singe cylinder knock testing. Essentially, the theoretical knock limit for ethanol is... there is none. Obviously the user will find other limits to their power package in many different ways, but I am excited to be getting closer to a few of my engine buildups that will utilize the fuel to its full potential.
Why did you choose to reduce the compression? I don't see, theoretically, where this is needed with e85?
Old 11-25-2013, 07:39 PM
  #504
refresh951
refresh951's Avatar
I am sure Sid will answer this but...
E85 is a significant improvement but it does not eliminate knock potential.
Peak cylinder pressure is a concern in our motors even if knock does not occur. There are several threads discussing this in detail.
Old 11-25-2013, 10:55 PM
  #505
333pg333
333pg333's Avatar
Reduced from what? 8:5.1 is half a point higher than stock. For a 2 valve head which is going to run pretty high boost this doesn't seem to be crazy low c/r.
Old 11-25-2013, 11:30 PM
  #506
Rogue_Ant
Small Business Partner
Rogue_Ant's Avatar
Shawn is correct on both accounts.
E85 can knock, though it is much more resilient to it than gas - both due to the octane and the cooling effect.
However, on E85 (or sufficient octane gas) these 8v 951 are not really knock-limited, but mechanically-limited. Specifically, head-lift & head-flex. As Shawn mentioned, this is directly related to peak-cylinder pressure.
Reduced compared to the common trend of tuner-car E85 approach...
But good to point out that it is still a small bump up from the factory CR.
Old 11-25-2013, 11:40 PM
  #507
333pg333
333pg333's Avatar
ps...the work looks great too!! :-)
Old 11-25-2013, 11:41 PM
  #508
67King
67King's Avatar
E85 is about 108 (R+M/2 for our non-US folks, or somewhere around 113-115 RON). That's probably good for a couple of points in CR, ceteris paribus. But, in boosted applications, that's rarely the case. It certainly will knock if you throw enough at it. But there are tons of other factors.
Side note, I'm a 4V fan. Plug is in the middle of the chamber, good for about 3/4 of a point. And contrary to popular belief, you can tune them for lower end torque instead of upper end power.
Old 11-26-2013, 12:04 AM
  #509
blown 944
blown 944's Avatar
Yeah 4v would be good , but right now I just chose the easier route. Really to make things less complicated.
In regards to CR. In my experience, its a bit of a balance. Kind of like choosing a turbo. I've tried higher compression on a 2.5 and found that it brought down the overall power potential on the 2v. I like to think of it as the path of least resistance. These engines have many weak points that will be exposed as power levels are increased (E85 or other). Cylinder pressure will find the fuse eventually.
Cylinder movement
Stock rods
Block and head flex (not sure which is first)
stud size and thread boss material
I'm hoping I have most of these addressed to stay together at 6-650rwhp. Other than a faulty old valve seat the last engine was very reliable at pretty high hp levels for my usage.
Obviously a 2v head will be a challenge.
If it has any problems along the way I'll just leave the power down. DSM's are much cheaper to replace lol
Back to CR...The real question is why did I raise it? ... It was going to be 7:1
Old 11-26-2013, 01:15 AM
  #510
Tom M'Guinn
Tom M'Guinn's Avatar
My motor is about 8.8:1 (despite what Andial used to claim) and is manageable with high octane fuel. Have to be careful with ignition timing advance or you'll blow the coolant out like Mentos in Coke bottle. Are you planning a cam to bring the dynamic pressure down? I'm not sure if Garrity is among us on the list these days (?), but he used to experiment with deck plates -- not sure he ever got it reliable as expansion rates differed, etc. I have a new block prepped for oversized studs (essentially 9/16") -- did you consider that? How about the bottom end for that much power -- considering stronger fasteners or shuffle pins?
Quick Reply: Hybrid stroker project
