928 Forum 1978-1995
Sponsored by: 928 Specialists
So what did you do to your 928 Today......
Old 05-01-2011, 10:02 PM
  #871
77tony
77tony's Avatar
Default Performance stuff
High flow cats, X-Pipe, RMD. Has a little more umph, and sounds a little onery. T
Old 05-01-2011, 10:52 PM
  #872
martinss
martinss's Avatar
Cleaned the accumulation of a Toronto winter from the garage and built a new shed for some of it. 928 relevance = now I can work on the car without stepping over things. Heck, I could even dance around it.
Old 05-02-2011, 12:19 AM
  #873
finally!
finally!'s Avatar
LORD BWMAC that engine is a piece of ART!
Done recently...
- Painted tail lights and front cornes red, looks GREAT!
- Installed 930 steering wheel, feel is so much better, especially the thickness...
- Got LED upgraded HVAC unit reinstalled, wow! Can actually see it at night now! Pics later..
Today.. Installed new motor mounts, delrin steering rack bushings and urethane front sway bar bushings with help, LOTS OF HELP, and I mean LLLLLLLLOOOOOOTTTTTSSSS from local 928'ers!
THANKS AGIAN GUYS!
Old 05-02-2011, 02:24 AM
  #874
928mac
928mac's Avatar
Done recently...
THANKS AGIAN GUYS!
Thanks man, lets hope the paint sticks
ya I used the correct primer
The engine bay detailing is next then the engine can go in and I can wire in the new harness for the Tec-gt ECM
Fingers crossed everything will work out
Brad
Old 05-02-2011, 10:16 PM
  #875
finally!
finally!'s Avatar
Took it for a drive, albeit a short one due to am a bit sore from wrenching yesterday, low on gas and didnt feel like driving to get gas with roads still slick.. But... was enough to be able to notice the smmmmoooooooooootttttttttttttttthhhhhhhhhhhhnnnnnnnnnnnneeeeeeeeeeesssss sssss after installing new motor mounts. OEM ones were approx 1 1/2 inch compressed as compared to the new ones. Cant wait for a spirited drive tomorrow (finally supposed to have a sunny day) to guage the difference with the urethane sway bar and delrin steering rack bushings.
Since this is "what you did to your 928 today" thread, put in new spark plug wires, red ones too! Gotta be good for at least another 10 HP being red right? <VBG>
Old 05-02-2011, 10:44 PM
  #876
jeff spahn
jeff spahn's Avatar
Tried out redline in first and second and almost third gears.
Old 05-02-2011, 10:52 PM
  #877
928mac
928mac's Avatar
Red line in 3rd on my 89, in Drive,
she comes out of 3rd at 200 kph
Old 05-02-2011, 11:07 PM
  #878
NC928S4
NC928S4's Avatar
Motor mounts under supervision of the Ray Master. A perfect day in NC to turn some wrenches. Surprisingly, no stripped bolts from PO's mechanical jobs. New mounts went in with only minor cussing and re-assembly went way faster than dis-assembly. That's the Ray Master in the pic. Note the motor lifts - he's a pro.
Job took just under 5 hours and I'm a rookie. I did ask for a hammer several times but was denied. TT is next, bring it on. Admittedly, without the Ray Master, I would not be so courageous. Life is Good, even better with Bin Laden dead!
Old 05-03-2011, 12:09 AM
  #879
IrishLegend
IrishLegend's Avatar
Mark R. And I finally finished my TB/WP job. I learned alot. Slowly getting her in good shape!
Old 05-03-2011, 12:18 AM
  #880
ALKada
ALKada's Avatar
Drove it 1200 miles round trip to storm damaged Birmingham to check on relatives. Long drive but the shark out performed my expectations.
Old 05-03-2011, 12:24 AM
  #881
jpNcos
jpNcos's Avatar
Alignment.
Then it started snowing....
Old 05-03-2011, 03:52 AM
  #882
megaelf
megaelf's Avatar
Thumbs up Not alone
Took it for a drive with a few friends
I was the only one with a 928...
Old 05-03-2011, 09:56 AM
  #883
the flyin' scotsman
the flyin' scotsman's Avatar
New CPS install, then the bracket for the throttle cable pulley, with cleaned ground wires and the new cable for the throttle body.
The new Fuel Regulator is in Calgary so should be at the home PO today but I'm in biz meets/travel for a few days. Really after that theres nothing to stop full assembly then wheels will roll
Old 05-03-2011, 10:49 AM
  #884
puyi
puyi's Avatar
The last couple of days, I have mounted back to the car all the wires except those from the engine compartment that I did not work on it. Then the central electric as well.
I deported from + battery, the cables to the dash to mount the battery switch.
I have ordred to Roger new parts for this car track (short shifter)
Also, for my 928 drive that is stopped for nearly a year, I finally ordered a timing belt kit in order to make re rolling this summer.
A+
puyi
Old 05-03-2011, 11:31 AM
  #885
dr bob
Chronic Tool Dropper
dr bob's Avatar
I took pictures of the before/after height of the steering rack when I put Roger's Delrin bushings in the rack, and noticed that it lifted the rack maybe 1/4" on the bolts. That was enough to change the toe measurement and require a little adjustment to re-center the wheel. For most cars, raising the rack in the bushings causes a smidge more toe-in, for those same 'most cars' a good thing. Still it's worth checking.
Quick Reply: So what did you do to your 928 Today......
