928 Forum 1978-1995
Sponsored by: 928 Specialists
So what did you do to your 928 Today......
Old 05-09-2020, 12:52 PM
  #7996
Wisconsin Joe
Wisconsin Joe's Avatar
Originally Posted by Tony
Yeah.. I'd say it is squished a bit...
Front protection plate.
Not anymore it's not.
Any idea what happened to it?
It almost had to have happened off the car. I can't imagine that kind of damage happening on the car.
Old 05-09-2020, 03:57 PM
  #7997
Tony
Tony's Avatar
ive had the car for 20years and am pretty certain this all occured prior. There is history of damage to the ac compresser and bracket on my car so that would explain the large deformation on the right/pax side. Other than that, my guess is just curbs..steep slopes....dunno.
Fixed now. It will be interesting when i pull into my drive way when the car is all settled. The approach is pretty steep.
on topic..
todays job...the rain gutters and sunroof panel seal. Then just a matter of collecting all the parts to be painted and drawing up some notes for the body shop to address and be aware off etc.
Old 05-14-2020, 08:47 AM
  #7998
slownrusty
slownrusty's Avatar
Getting ready for some new boots.
Bertrand Daoust (05-16-2020)
Old 05-16-2020, 12:11 AM
  #7999
jeff spahn
jeff spahn's Avatar
Diagnosed a hard starting issue to a worn out (leaking gas when pulling a vac with mity vac) fuel pressure damper. Its the one at the back by the MAF. Of course, its the only one I haven't changed in 10 years and I didn't need to because my old supercharger didn't use it and my new one won't either. Just went bad during the time I am driving it NA. Temp II sensor wiring is bad too so ordered a new pigtail for that from Roger. Now, just to sort the new keyless entry/power mirrors/power seats acting wonky. Think it is a short in the door wiring harness.
Old 05-18-2020, 03:15 AM
  #8000
UKKid35
UKKid35's Avatar
I fitted the hoodliner that I bought at Sharktoberfest 2012
Old 05-22-2020, 04:28 PM
  #8001
slownrusty
slownrusty's Avatar
So I had my fuel injectors ultra sonically cleaned, flow balanced and tested. The lab performing the work said that the condition was commensurate with the age and years (1987 S4 with 116k miles) and a few of the injectors were borderline, so really looking forward to driving the car in the future with all 8 injectors cleaned and performing equally. Cost was $156 US for all 8 injectors and a two day turnaround.
Old 05-23-2020, 09:23 AM
  #8002
Geza
Geza's Avatar
Those injectors look pretty clean compared to the ones out of my 130K '87. Looks like they have been cleaned before. I wouldn't expect too much performance difference. For mine, cleaning made a noticeable difference in performance, and especially in reduced emissions. A few of mine were dripping and running at half flow rate.
Old 05-23-2020, 10:14 AM
  #8003
slownrusty
slownrusty's Avatar
Agreed @Geza , thanks for sharing your cleaning results.
Geza (05-23-2020)
Old 05-23-2020, 07:47 PM
  #8004
grepin
grepin's Avatar
Here are mine. Done a few weeks a go.
Old 05-23-2020, 11:37 PM
  #8005
slownrusty
slownrusty's Avatar
After a long day in the garage.
Intake manifold ceramic coated, rubber lines replaced, new gaskets, injectors rebuilt...all back together and ready for start-up and the maiden voyage tomorrow.
The following 4 users liked this post by slownrusty:
Bertrand Daoust (05-24-2020), Brent A. (05-24-2020), Geza (05-24-2020), Michael Benno (05-24-2020)
Old 05-23-2020, 11:53 PM
  #8006
j.kenzie@sbcglobal.net
j.kenzie@sbcglobal.net's Avatar
Looks beautiful, Rusty.
Dave
Old 05-24-2020, 05:23 PM
  #8007
Fox_
Fox_'s Avatar
I haven't the slightest idea why the mirror controls were being wonky, none at all.
Clean and ready to go back together, not pictured the tiny amount of grease before final assembly. Very useful for holding the springs and pins in place.
It's exactly as fiddly to put back together as it looks, but it fixed the issue.
The following 2 users liked this post by Fox_:
AirtekHVAC (05-25-2020), Bertrand Daoust (05-24-2020)
Old 05-24-2020, 07:42 PM
  #8008
Bertrand Daoust
Bertrand Daoust's Avatar
Received 1,317 Likes on 498 Posts
I started it for the first time this year.
Everything went well.
With all that is happening right now, I might not drive it much this year.
I like to go to coffee runs with our local PCA group and go to Frenzy each year but as now, nothing is going to happen this summer.
We'll see…
dimi5928 (05-24-2020)
Old 05-24-2020, 09:44 PM
  #8009
dimi5928
dimi5928's Avatar
Today i was fix must of the water leaks on my 928.!
Last week i was pull out of my garage for the first time (start engine) after looong restoration
I clean the exterior of the car for the first time and i notice the must of the water goes in the car?!.
Hatch door seal, the one i have from my parts car was in very good condition DONE!
Top of the windshield, was change last winder but leaking on the top corners?!, after two days under the sun the adhesive spread and stop leak, DONE!
Both tail lights leaking from the mane nut seal, i remove and clean them, DONE!
Ugh!!...Sunroof...., Dripping tray was brocken....
I remove, repair, reinstall but still leaking from the corners under a lot of water because i just notice, they are crooked...!
I try to straighten up tomorrow,
Old 05-25-2020, 10:05 PM
  #8010
Brent A.
Brent A.'s Avatar
New rear shocks, rotors, pads, brake lines, wear sensors and a heck of a lot of cleaning. Time to move on to the front.
The following 2 users liked this post by Brent A.:
Geza (05-26-2020), Sagres74 (06-07-2020)
Quick Reply: So what did you do to your 928 Today......
