928 Forum 1978-1995
Sponsored by: 928 Specialists
So what did you do to your 928 Today......
Old 07-19-2014, 09:19 PM
  #4906
AirtekHVAC
AirtekHVAC's Avatar
Put LED bulbs in the cluster, epoxied a nut into the hole where the PO broke the thread nut out of the pod, found a switch (now known to be the cruise cancel switch) crammed under the air duct while looking for the ground point.
Old 07-19-2014, 09:59 PM
  #4907
outbackgeorgia
outbackgeorgia's Avatar
Ron,
The more you look, the more you find!
Keep Looking!
Dave
Old 07-19-2014, 11:00 PM
  #4908
MainePorsche
MainePorsche's Avatar
Small thing.
Removed the crumbling liner of the rear hatch lock mechanism and replaced with a new one from Peter Vik.
Old 07-20-2014, 10:32 AM
  #4909
michaelathome
michaelathome's Avatar
Originally Posted by Wisconsin Joe
What did you use for polish and media?
http://www.harborfreight.com/5-lbs-r...dia-93832.html
Rust-Cutting Resin Abrasive Tumbler Media
Michael
Old 07-20-2014, 01:29 PM
  #4910
rexpontius
rexpontius's Avatar
Took it out of the garage and took it for a good long drive. It was a hot day in NL today, but thanks to the HVAC diaphragm fix (with condoms, check my other post :-)) the A/C was super cool.
Everything worked as it should, no warning lights, just perfect driving. Life is good!!
Old 07-20-2014, 02:38 PM
  #4911
Bilal928S4
Bilal928S4's Avatar
Default Upper control arm boot replacement
Replaced the torn upper control arm boot on my 89. Not a terribly hard job, but make sure to install the smaller ring onto the lower part of the boot on the bench and then install it on the control arm. The larger ring is much easier to install.
Old 07-20-2014, 02:40 PM
  #4912
Bilal928S4
Bilal928S4's Avatar
Picture 1
Old 07-20-2014, 02:41 PM
  #4913
Bilal928S4
Bilal928S4's Avatar
Picture 2
Old 07-20-2014, 02:42 PM
  #4914
Bilal928S4
Bilal928S4's Avatar
Picture 3
Old 07-20-2014, 02:44 PM
  #4915
Bilal928S4
Bilal928S4's Avatar
Cool
Can anybody verify that the routing of the wires is correct?
Old 07-20-2014, 04:04 PM
  #4916
x98boardwell
x98boardwell's Avatar
Default I was hit.
Was on the road for only two days after having the motor out.
Old 07-20-2014, 06:44 PM
  #4917
Captain_Slow
Captain_Slow's Avatar
x98- That really sucks. I hope not a hit and and run.
Old 07-20-2014, 06:53 PM
  #4918
Captain_Slow
Drove over to Michaelathome's place. Swapped in his fan controller box and both of my cooling fans worked! Saw and drove his really nice 89 S4 save-and-restore/upgrade project. Now I want a RMB and adjustable Konis. Gotta stay focused on necessary things first. He didn't show me his vibrator, but maybe he will let me borrow it.
Old 07-20-2014, 07:08 PM
  #4919
Tazzieman
Tazzieman's Avatar
Now I just need to connect the brain to the nervous system
Old wires "past their use-by date" , most certainly. Liquid insulation only buys a few weeks.
And the patient had no symptoms , despite this degree of pathology
Old 07-20-2014, 09:13 PM
  #4920
Hold On
Hold On's Avatar
Replaced both lower ball joints, tie rods, and replaced washer pumps for windshield and headlights. front end alignment at 8am in morning. Im whooooped Beer time !
Quick Reply: So what did you do to your 928 Today......
