So what did you do to your 928 Today......
#1681
Bought four 17" Turbo Twists with Bridgestone Potenza tires to kinda mix up the look a little... and, make it harder for my wife to curb my 18" RH wheels....
#1683
GREEN 81 EURO 5 SPD... refitted rear bumper(new bead),rear lamps, rear fog, aerial and freshly powder coated 16"tele dials after full respray 3 weeks ago.nearly finished just mirrors and a few other bits to complete.cant wait to get it back on the road now,2 months in the making.
#1685
??? "...confessed..." ??? what was it you were confessing to?
Last night removed rear wiper and found some plastic round thingys at AutoZone, painted them red then attached using silicon...
#1686
Said some words out loud.... after noticing that one of the new cams is slightly different and does not fit because the thrust bearing shoulder is too short (and the other part is too wide)
#1687
I going to take it for a Long drive to Calgary.
fort McMurray to Edmonton about 4.5hrs
Edm to Calgary another 4 or more depending on how quick I get out of Edmonton (droping the woman off)
#1688
Refurbished the bell house grounds while I was there (PITA). Prophylactically Changed out the fuel lines. Initially I had to replace a shot fuel dampener. Did so but... the new replacement had a threaded extension to be mounted on the bracket by nut. The old one had received a bolt to be mounted. I now have to rotate 90 degrees for the extension won't allow it to be tied into the short fuel rail. The vacuum fitting now is straight up. Spoke to Anaheim about this and was told, oh well. Res ipsa loquitur regarding future parts.
#1691
Installed a set of low mileage S4 coilovers in the rear.
Replaced motor and rewired PS mirror
Replaced 1979 gear shift **** with appropriate one (now to get it recovered by P. Champagne).
For the rear coilovers, Bill Ball's simple diagrammed photo was all I needed
#1693
Absolutely!!! Plus, just to BE on the San Juan Islands this time of year is PRICELESS!!! Congrats again!!!
