718 GTS 4.0/GT4/GT4RS/Spyder/25th Anniversary Discussions about the 718 version of the GT4RS, GTS 4.0, GT4, Spyder and 25th Anniversary Boxster
Sponsored By:
Sponsored By: Cobb
OEM Navigation Retrofit DIY
Old 08-02-2023, 06:51 PM
  #736
DomTheBomb
DomTheBomb's Avatar
I went through the install and unlocked Navigation and WLAN (wooo). Navigation looks good as I have carplay so the antenna was already there. However, when I try to connect my phone to the car and load up the track precision app, it just sits there asking me to connect to the wifi. Car/phone don't seem to recognize they are connected. Is there another update/step I need to do to fully enable that talk? If it matters when I did the original install and it showed me the summary screen, all the rows were marked with [-] and I hit continue. Was I supposed enable them all to Y?
Old 08-02-2023, 07:35 PM
  #737
718socal
718socal's Avatar
If you see the WLAN then you can use TPA. You should connect your WiFi to the car. Your phone has to be plugged into the USB port too.
Old 08-02-2023, 09:12 PM
  #738
mtregan
mtregan's Avatar
I'm thinking it's my SD card. Tried the partitioned 64gb, would never load even after 2 min. Found a 32gb card at home. Formatted to Fat32 and unzipped folder to it. Loading in the car. Waited 3 min. Nothing. Came on here to report and saw one of the last threads said wait maybe 10 min. Tried that, nothing. Went back and selected Car/Media. Now in Developer mode. Go to software update and shows SD1, SD2, USB. All are greyed out, like it doesn't think anything is in SD1 slot. Put the 64gb card back and selected software update again. SD1 is still grayed out.
64gb card is Lexar. 32gb is sandisk.
Only problem now is I don't know how to get out of developer mode.
Old 08-02-2023, 09:33 PM
  #739
Westcoast
Westcoast's Avatar
Received 4,711 Likes on 2,741 Posts
Push and hold CAR to get out. are these microSD cards?
And when you unzipped the folder, onto the root of the card, not into a folder right?
Old 08-02-2023, 09:59 PM
  #740
mtregan
mtregan's Avatar
Eventually I figured it out. Regular SD cards. Unzipped the folder onto the root of the card. But all the files are in the MH12_US_POG11......folder on the SD card. Am I supposed to take all the files/folders in the MH12 folder and place those on the root of the SD card rather than them being in the MH12 folder?
Old 08-03-2023, 01:18 AM
  #741
Westcoast
Westcoast's Avatar
Yes, the files should be extracted onto the root of the SDcard, not into a single folder... the file structure should resemble the image in the post above that I showed the Swdlautorun example. (post # 726)
Old 08-03-2023, 06:25 AM
  #742
mtregan
mtregan's Avatar
That was the problem. Took about 30 min and all installed now. Will try the map update tonight. Thanks for all your help.
For others with a 718 I'd suggest watching the 911 install video vs the 718. I had originally watched the 718 video, assuming it was car specific. During the install I could only find the 911 install video on my iphone, while I sat in the car. I thought it was much more detailed than the 718 video.
Old 08-03-2023, 06:26 AM
  #743
DomTheBomb
DomTheBomb's Avatar
Yup did all the above, but phone and car just sit there waiting for the other to connect
Old 08-03-2023, 09:57 AM
  #744
Westcoast
Westcoast's Avatar
Just to be clear, your phone needs to be connected to the WiFi hotspot being generated by the car (PCM), that SSID can be found on the PCM as well as the password for connecting.
Old 08-03-2023, 01:09 PM
  #745
mtregan
mtregan's Avatar
Now that I have nav installed. To update the maps, I download P336_N60S5MIBH3-NAR-2023-2304. Unzip to the root directory on my SD car. Insert in car and go to the Software update option on the PCM? Will I need to select Mib1 or Mib2 or will the car know which one to select by itself.
Old 08-03-2023, 01:43 PM
  #746
Westcoast
Westcoast's Avatar
Cool I didn't even know that version was available! Extract the files to the root of the SD card, put the card in SD1 and uses the PCM screens to initiate the map database update and you should see SD1 as the only selection not greyed out.
Old 08-03-2023, 06:30 PM
  #747
Westcoast
Westcoast's Avatar
That only took about 30 minutes to update...
718socal (08-03-2023)
Old 08-03-2023, 06:57 PM
  #748
718socal
718socal's Avatar
Did the remove P85 and P87? I don't see them anymore on MIB Solution website.
Old 08-03-2023, 07:05 PM
  #749
Westcoast
Westcoast's Avatar
I guess so, I don't see them either! Perhaps simply no longer needed?
Old 08-04-2023, 08:11 AM
  #750
mtregan
mtregan's Avatar
Updated my maps last night as well to the 2023/2304 version. Took about 30 minutes as well.
Quick Reply: OEM Navigation Retrofit DIY
