PIWIS 3 Coding Retrofit and Feature Request
#676
#677
Hi,
I am Anthony with 9XX Research, and we specialize in uncharted territories. If many others have tried and cannot complete something perfectly, we will finish the job. This time around, we are introducing:
Matrix LED Full Activation for 992, 718, Cayenne, Macan, Panamera $700
Matrix LED Full Activation for 992, 718, Cayenne, Macan, Panamera $500 for first 5 from Rennlist
Taycan $900 (coming in September)
Free gift for all: Comfort windows and sunroof w/Matrix LED activation
Recoding (if needed after a dealer visit) $200 for all models
9XX Research is an Official Porsche Partner, ID# DDA2197. We strictly follow Porsche protocol on equipment standards, and therefore no remote sessions will be offered for Matrix LED Activation. We will visit you during our USA touring schedule, and we are fully equipped to recover your car from damaged codes done by others.
Recovery of full function $2000
Required if erroneously programmed by a non-Porsche partner prior.
(e.g., Homelink damage by erroneous Matrix LED coding by third party other than 9XX or Porsche Service Center)
for more details on pricing
https://9xx.com/pages/9xx-experience-pricing
Please visit 9xx.com and register for our tour, so we will not miss you in the upcoming tour.
- Past history of accomplishing what others say is “Impossible”.
- CarPlay
- Spoiler
- Camera
- MagSafe charger
- Rattle Finder
No errors, No loss of any functionality.
Just great products!
Learn more about Porsche Matrix LED system here https://www.porsche.com/usa/aboutpors...
https://youtu.be/Y2thlvqwMIc
- CarPlay
- Spoiler
- Camera
- MagSafe charger
- Rattle Finder
#679
John you are absolutely correct. I have taken 718 and Macan off the list..
#681
I have some members asking me what is Comfort Windows. I have made a video and I hope it helps.
https://youtu.be/DwVeuOL_HaU
#682
718socal (06-12-2023)
#685
Finally got around to calibrating my speedo. Turns out the inaccuracy was not linear, that is to say it was less accurate at lower speeds. I only needed to change the value of Y1 from 100% to 97% to make my speedo match the GPS speeds of WAZE and the SPEED App on my phone. My speedo now also matches the radar signs posted along the roadside in my area.
#686
Since the GPS speed and the radar signs tend to agree I guess I have a greater confidence in their accuracy than my car's speedo. Yes 97% alters the speedo readout. At slower speeds my speedo would read 2-4 kph high. After experimenting changing Y1 to 97% pretty much eliminates the deviation and tilts the correction from 0 (Y1) to 250 (Y2). I'm not too concerned about Y3 400kph since I don't have a Bugatti Chiron. lol!
#687
Z06jerry (06-12-2023)
#690
I've tested the fix in PIWIS to adjust for smaller tire sizes (I'm using a 265/35/19 and 305/30/19). To get the correct value I plugged in a 25Hz GPS, ODBII speed reader and set the cruise control to 30mph. Higher speeds would probably be more accurate but there is traffic on the freeway right now.
When at 30mph per cruise control, I observed the speed logged by the GPS and by the ODBII monitor. In this case, they were 28.3 and 28.6 respectively.
I wasn't sure how the "Kennlinie Geschwindigkeitskorrektur: Korrektufaktor Yx" multiplier worked, so I tried 106% initially but that made my speedo faster. (hit 20mph pulling out the driveway) so used 94.33% (28.3mph / 30mph = 0.9433) which resulted in a almost aligned GPS/ODBII/Speedometer reading.
In PIWIS the values you want to change are "Kennlinie Geschwindigkeitskorrektur: Korrektufaktor Yx". I don't know if you have to change Y1, 2 and 3, I tried all 3 and things seem to be fine now but I may update if I run into problems.
*and now I see Socal was just posting about this. I confirm his findings.
