Old 11-11-2017, 01:50 AM
  #8566
odonnell
odonnell's Avatar
Experimented with using studs/nuts for the outer CV joints. Made installation a lot nicer and way less grease getting on things. Torquing is easy and there's no need to pick grime out of the bolts.
Old 11-11-2017, 02:25 AM
  #8567
kirkandorules
kirkandorules's Avatar
Bought one! Just picked up an '87 924S to be my winter car while the 986 gets (mostly) put away for the winter. Needs a few little things, but clutch is new and water pump/belts are pretty recent.
Old 11-12-2017, 02:37 PM
  #8568
dmjames
dmjames's Avatar
Rescued the 951 from where it died last night about a mile south of the Wyoming border (in the middle of freaking nowhere) after the bolts backed out of one cv joint while doing 90mph on the highway... Car was still there this morning, and about 15-20 minutes to get it reassembled on the side of the highway, then limped it 85 miles or so back home...
Time to replace the cv bolts, and the boots while I'm at it...
Old 11-12-2017, 09:11 PM
  #8569
curtisr
curtisr's Avatar
Glad you did, Kirk. And welcome to the forums. Hope you'll keep us up to date with what ever you do to it.
Old 11-13-2017, 09:11 AM
  #8570
dreygata
dreygata's Avatar
One step forward two steps back. Realized that I never gapped my speed reference sensor while the engine was out of the car, so now I get to play contortionist getting at the bolts.
Old 11-13-2017, 09:36 AM
  #8571
ealoken
ealoken's Avatar
This arrived..
Old 11-13-2017, 09:56 AM
  #8572
morghen
morghen's Avatar
pretty thing
Old 11-13-2017, 11:01 AM
  #8573
ealoken
ealoken's Avatar
La Sleeves done
Old 11-13-2017, 12:16 PM
  #8574
autocomman
autocomman's Avatar
I set mine on fire yesterday...well it set itself on fire...
Old 11-14-2017, 12:49 AM
  #8575
Tiger03447
Tiger03447's Avatar
Nice looking job, Michael..Clincher nuts on the studs?? or blue locktite? I haven't gotten that far on mine..work keeps getting in the way...Got the rear end passenger side put together, now for the driver's side of the bearing/spacer job..Perhaps this week??
Old 11-14-2017, 08:49 AM
  #8576
944 Lachlan
944 Lachlan's Avatar
was it the fuel lines over the hot side?
Old 11-14-2017, 08:50 AM
  #8577
odonnell
odonnell's Avatar
They're just ordinary nuts, but Class 10 and a dot of loctite. I figured a locknut would probably screw the stud deeper in at the other side in the stub axles. They're torqued to 33 ft-lbs like OEM, being 12.9 studs. That's maximum tensile stretch and should be sufficient to keep them from coming loose (like our cylinder head nuts).
Old 11-14-2017, 12:21 PM
  #8578
autocomman
autocomman's Avatar
I wish, that would have been an easy fix. Motor was out for a clutch and reseal and I guess somehow I filled the heat shield on one exhaust manifold runner with oil, cause it smoked like crazy then hit flash point. Now I gotta drill a hole to drain it and hopefully get the oil out of the heat shield and what ever else is in there
Old 11-14-2017, 12:56 PM
  #8579
V2Rocket
V2Rocket's Avatar
Originally Posted by ealoken
La Sleeves done
where, and how much?
or are you in EU?
Old 11-16-2017, 12:46 PM
  #8580
racerbvd
racerbvd's Avatar
Loaded up to head to the track :-)
