Any Rennlisters from New Zealand?
Old 02-27-2014, 02:19 AM
  #10456
ChrisB_NZ
ChrisB_NZ's Avatar
Originally Posted by John McM
Chris, what garaging options are there at HD?
Each apartment has a double garage. I own half an apartment with Mack and Anne Storey so only have one spot. Steve has 2 apartments and his commercial building, so lots of garaging options.
Old 02-27-2014, 02:23 AM
  #10457
John McM
John McM's Avatar
Thanks. Just wondering about options other than driving a car to the track e.g. pure race cars.
Old 02-27-2014, 02:25 AM
  #10458
kiwi 911
kiwi 911's Avatar
Steve will rent you a spot - $50/wk from memory?
Old 02-27-2014, 02:33 AM
  #10459
ChrisB_NZ
ChrisB_NZ's Avatar
Or you can buy half an apartment (Mack and Anne are looking to sell), rent the apartment out and use the garage for yourself. Half a 2 bedroom apartment goes for around $210 - $220k fully furnished.
Old 02-27-2014, 02:46 AM
  #10460
Spokes
Spokes's Avatar
Anyone purchase a 2 or 4 post lift locally and had it installed. Like to set one up for this winter. Recommendations appreciated. I see there are a few China made ones with distribution companies predominately in Auckland, which doesn't bother me, as long as quality is OK.
Old 02-27-2014, 03:15 AM
  #10461
CS Mende
CS Mende's Avatar
Catching up. Thanks for the rides Sean & Pete!
Originally Posted by Maxem
Yes, it will stay LHD to add to the weirdness experience.
Thumbs up! Just the way Porsche meant it to be.
Now I just need to figure out how to get Steve & the boys to find time for a second project.
Speaks for itself.
Congrats on the times - despite the travails it's still mission accomplished!
Ok - this is the correct footage for my PB.Video Link: http://youtu.be/MhJBskQLwzo Need to look at other footage to get some more of the RSG.
Looks very smooth ... but agree - higher camera and lower AIM mounting.
Old 02-27-2014, 03:52 AM
  #10462
peterC2S
peterC2S's Avatar
2015 is free so far... but get in quick!
Old 02-27-2014, 03:59 AM
  #10463
Obsessed
Obsessed's Avatar
Originally Posted by Macca
Oops. The sans air con brigade. Unfortunately after having the compressor overhauled the evaporator has let go. Big job with time running out and no oem parts in stock in nz means zero chance of cold air on SITT . Timing bad. Wife will not be happy. I'm getting a little bit frustrated by the endless things that crop up in trying to prepare for these high intensity jaunts but at the end of the day this is what happens as these cars get older especially when we choose to ride them harder now than the first owners did when they were new.....13 hassle free years of reliable ownership but age is catching up on her now.
Sorry for the rant!
Macca, I think she knows you've been unfaithful...
Old 02-27-2014, 04:01 AM
  #10464
Obsessed
Obsessed's Avatar
Ok - this is the correct footage for my PB. Need to look at other footage to get some more of the RSG.
John, great work. I think it was getting a bit wide on Barrel 51 that cost you those two-hundredths!
Old 02-27-2014, 04:04 AM
  #10465
Obsessed
Obsessed's Avatar
Hang on, you were talking about your 993 and not your wife, right?!?
Old 02-27-2014, 04:23 AM
  #10466
Macca
Macca's Avatar
LOL! Good to hear from you Michael!
P.S. If you every need your engine rebuilding it Paul will do it for 7K!
  #10467
O2GO
O2GO's Avatar
Ha ha, Good one Michael!!
Old 02-27-2014, 04:27 AM
  #10468
PHG
PHG's Avatar
Phil. I chopped through the side wall of a new tyre yesterday (left rear), so will now be getting to at least Matt's recommendation of minimum 36 pound in the rear when hot. I spoke to Dave Taylor (Motorsport Services) today. Dave has managed a few racing 996tt's and he said they used to run the rears around 40 pound when hot, The speed and weight of the car together with the wide low profile tyres on the rear meant they used to regularly chop out the side walls if they ran the pressures to low. I will also do a bit more research on Rennlist to get others views.
Thanks Pete. I appreciate the input. I noted Maccas pics last week re the split in his. Did you just 'peel' yr tyre off the rim so to speak!!
Old 02-27-2014, 04:30 AM
  #10469
PHG
PHG's Avatar
He he - can't say too much..........
I was planning to take Pete through when it's finished - you can come for a nosey too.
BBQ for the lads Paul??
Old 02-27-2014, 04:32 AM
  #10470
PHG
PHG's Avatar
Originally Posted by mjg
Another factor to watch with that is running too low cold temps when first starting... might be safer to start close to the target temp and drop after you come in rather than starting in the 20s.
yes Matt
I have been learning from reading this thread. Was debating driving down on low pressure colder tyres, as don't have a pump, but was unsure re the repercussions..
Quick Reply: Any Rennlisters from New Zealand?
