Any Rennlisters from New Zealand?
Macca, I haven't looked back since I watched Rob at CCS change Herman's pads one Saturday. Newer cars are even easier than the air cooled. I changed out the Cayenne fronts this afternoon. $110 for the pads from Trademe and an hour of my time. Job done.
Porsche make pad changing easier for quick pad changes at the race track. One clip on the 993 from memory and they're out! Some cars can be a real effort.
Car is great on the motorway and normal roads, but too stiff for aggressive B or C roads driving.
When you push hard the car starts to tramline (and not sure I am a fan of Trofeo's on damp or wet roads.
The car is still understeering and it was noticeable today. The car is booked in again tomorrow for another tweak of the geo.
I got the car air-born twice which was frightening - (I believe the suspension is stock.......)
The car scared me and is going to kill me on damp back roads.
Mind you - I think you were suffering too Doug on the back roads we travelled today.
Car still needs to be dialled in correctly.
I still like it, you just don't realise how quick you are going and I am respective (scared) of the car at the moment.........
The car looked really nice Paul. Yes, that last road before Huntly was especially rough. I run the RS60 on broads with the PASM off most of the time so that it can soak up the humps and bumps. Unfortunately after you bailed to come back on SH1 the second half of the roads to the east of SH1 were much better. Next time we'll do the route clockwise to get the better roads first.
I'm interested to know if the 996 GT3 suspension allows you to soften it up for non-track use?
My MPSS were fine in today's dry/damp and occasionally wet conditions. Only the occasional squirm. Was nice when we had dry stretches of road. Roll on spring/summer aye.
I'm still learning the GT3.
I am happy run the 993 at the limit as I know that car and it's well set up for it's limits.
The GT3 is more twitchy and agile in nature - not like other 911's I have driven, so I am scared to find the limits on a road - I need to dial out the understeering and do a few track days to learn it's limits.
Car is great on the motorway and normal roads, but too stiff for aggressive B or C roads driving. When you push hard the car starts to tramline (and not sure I am a fan of Trofeo's on damp or wet roads. The car is still understeering and it was noticeable today. The car is booked in again tomorrow for another tweak of the geo. I got the car air-born twice which was frightening - (I believe the suspension is stock.......) The car scared me and is going to kill me on damp back roads. Mind you - I think you were suffering too Doug on the back roads we travelled today. Car still needs to be dialled in correctly. I still like it, you just don't realise how quick you are going and I am respective (scared) of the car at the moment.........
Not sure how quick Doug was going today but he and I done some drives and would suggest you were not going much quicker than usual. Road surface was obviously not as good as Nothland which is a problem in Waikato sometime...?
part of what you are experiencing is due to the Trofeo R sidewall. They are notoriously stiff which is why you must run on track with pressures around 28/29 PSI F plus R hot pressures. on the road I'm not sure what is recommended but if you are pushing on you wouldn't want to be much more than 27-28 cold IMO. I don't have direct experience but a bunch of my GT3 buddies do and many are using them on the track and reporting back on them. They have quite differing characteristics to the MPSC2.
Also you have sway bars to dial out understeer. Stiffen the rear and soften the front. How do you have them set up now?
In all honesty the 993RS and 996 GT3 I had were no faster than a standard C2 or 996C2 on NZ backroads. A softer chassis more figuring suspension and grippy road tyres help you cover ground as quickly with less pucker moments than driving to be **** off a firmly set up GT3/RS with aggressive camber. My 991 GT3 is a revelation in this regard because for the first time the car is quite good on the back roads AND the track as well as motorway and commute. The new GT3 & RS is much commented on on how good the PASM and compliance are in normal mode. But that's technology. Fact is a stock 991 C 2 on MPSS is quick as the 991 GT3 on really poorly paved damp NZ back roads as it inspires more confidence. You will get dialled in once you can trust the tyres and chassis. Don't go crazy on the ground till you have read up more on the Trofeo pressures and played with the sway bars IMO. keep them close to factory for now.
the bottom line is until the latest generation GT3 these were not cars people in UK or NZ raved about on our crappy surfaced back roads! They were cars you could drive to the track and on nicer windy flowing roads with good surface like you find in Europe Wales and Lake District they. One together nicely. but on our roads sometimes very different. EVO did a piece between a readers 4.0RS and the New GT3 in 2013 and both the 4.0 RS owner and the magazine found the new car far quicker on UK B roads. Nothing to do with hP just ability to press on. Nothing new here but your 996.2 is even stiffer than my old 996.1 Gt3 and no were near as flexible chassis as your 993. You will master it soon I'm sure but you will always have some pucker up moments in a Gt3 when pushing on in NZ roads regardless generation...
i understand the concept in the 993 but have never done it. In that car the pads only been changed once in 10 years but when it comes time I will come to your workshop :-)
agree on both counts. I know an Australia based in US who has 987 with 3.8L S engine transplant running PRK. It's a BG Motorsports build - a race car. He's been testing it over this weekend done almost 9 hours solid track time on it in last two days and reckons it is the dogs nuts. Not a cheap project that one cost him as much as a new GT3.
As for skittishness from poor compliance in bumpy corners, how adjustable is your suspension? I guess it doesn't allow you to soften back the fast bounce and fast rebound on the dampers?
My BMW 750il could take some bumpy corners quicker than the Turbo, and the Turbo is more road optimized than a GT3, so I know where you're coming from on that front.
If you ever do end up looking for aftermarket shocks, the Ohlins DFVs should be a good allround fit for your mix of driving, particularly if you don't want to be adjusting settings much: http://www.roadandtrackbyohlins.com/
