Any Rennlisters from New Zealand?
Pete. This one may well set the market for your own Im guessing (similar spec and kms).
No Gen 2 'S' cars at all.
NZ seems to have quite a few 2009 Gen 1s - must be the way the stock was registered in the market. You can tell from the steering wheel, front bumper and I think all the gen 2's NZ spec had PCM3.
This is for Walter. Sorry to inject Honda into the Porsche talk
Walter, CEL code is 22, which is the Vtec oil pressure switch. This is what I found. I doubt you had Vtec power at Uncles.
Then we move to the water temp gauge. The threaded brass part is the sender. It should have a threaded fitting for the gauge, but No, it has a bodged one. The gauge works on resistance so the fitting should be tight and resistance free. It may not be the problem but it doesn't help.
Paul, how much longer until your 993 hits the road again? Need you there for Lola's first post rebuild run mate!
Welcome new people to the madness :-D
