Panamera 2010-Current
Isudar Carplay for PCM 3.1
Old 04-01-2022 | 08:55 AM
  #871
marcus_v's Avatar
marcus_v
Default Strange Sound Issue
I have the Isudar V2 Board and SW version 0105B (991.1 with BOSE).
Sometimes (!) when I enter the car, Carplay starts without sound (although music is playing). If I switch to the PCM Tuner, music is playing and sound is normal. Switching back to Carplay - no sound.
only workaround is to restart the PCM or to close the car or to pull the PCM fuse.
has anyone experienced the same problem? What could be the reason and how could I fix it?
Edit: I had the same problem with JoyeAuto (before I got my ISUDAR).
Old 04-01-2022 | 01:39 PM
  #872
danby's Avatar
danby
It sounds like you may want to your phone to "forget" your PCM's bluetooth connection. Maybe your phone is connected to both devices and using the PCM link for the audio instead of the iSudar one.
Old 04-01-2022 | 01:56 PM
  #873
marcus_v's Avatar
marcus_v
This was my first thought, too - I deactivated AUX BT and set my bluetooth settings (iPhone) to ignore PCM. Unfortunately, it didn’t help.
Old 04-01-2022 | 02:03 PM
  #874
danby's Avatar
danby
Maybe check if your phone is connected to the PCM BT the next time it happens? I'm not sure how else it might be receiving your audio.
Old 04-01-2022 | 02:12 PM
  #875
marcus_v's Avatar
marcus_v
There is no AUX Bluetooth connection anymore between PCM and iPhone - I deleted the phone from the PCM device list and ignored PCM in my phone settings.
Old 04-01-2022 | 02:16 PM
  #876
marcus_v's Avatar
marcus_v
And it only happens sometimes. Not always, but at least 3 of 10 times. If it happens, then only when I enter the car - never while driving (means if there is sound via Carplay it stays stable).
But I can hear sound when I‘m switching to the PCM Tuner.
Old 04-02-2022 | 03:15 AM
  #877
blowme's Avatar
blowme
Default Isudar
Finally got the time to do the installation. Not the most straight forward instruction but whatev.
But now i noticed my screen color is wayy off, and the screen quality is definitely worse than before. Does anyone have this problem and is there a fix?
Old 04-02-2022 | 04:20 AM
  #878
marcus_v's Avatar
marcus_v
Most likely one of the ribbons (video) is not seated correctly - while you fix it you should also check all other ribbon connections.
Old 04-02-2022 | 09:52 PM
  #879
Willy07's Avatar
Willy07
Yeah…bad ribbon connection for sure , re seat.
Old 04-03-2022 | 06:11 PM
  #880
DennisRF's Avatar
DennisRF
Hello Fantasmos,
I'm appreciative of all the information you and the others here have provided on this Carplay system.
I watched the video you have provided here and at 10:39 of the video it shows your PCM 3.1 has a system version of 4.76.
Would you happen to know if that vesion is a requirement for the Isudar to function or will it work on a PCM 3.1 version 3.43?
I have looked through most of if not all of the posts regarding this topic and have not come across any mention of version requirements.
Thanks,
Dennis
Old 04-04-2022 | 06:33 AM
  #881
Alexchrisro's Avatar
Alexchrisro
Originally Posted by griskait
Android phone (not sure if iPhone has something similar) I found that if you go to settings / android auto/ there is an entry that you can deactivate called "automatically starts media". I did it and didn't lost connection since. I noticed that my disconnections were related to some activities happening in the phone. I have the original fw and I was going to try the update route when I realized that this does the trick for now. It has been a week and everything is stable.
Thank you very much for sharing this tip. Sometimes it would really bother me that the music was stuttering, but after i switched off the "automatically start media" like you said, it works great.
griskait (04-06-2022)
Old 04-04-2022 | 09:27 PM
  #882
ars69's Avatar
ars69
Default xm with cp
Any way to play regular car satellite radio but be in CarPlay mode and still get google maps sound? Obviously able to do it without maps sound but curious if can get audio from both. Thanks!
Old 04-05-2022 | 04:18 PM
  #883
sac02's Avatar
sac02
No.
The Isudar works because it inserts itself as the "AUX" source (you have to select Aux on the PCM to hear carplay audio). The PCM is unaware that there is any "carplay" happening, the PCM is just playing audio from the AUX input and the Isudar is hijacking the video display to display Carplay.
The PCM simply can't play two sources (satellite and AUX) simultaneously.
Old 04-05-2022 | 04:45 PM
  #884
allroadusa's Avatar
allroadusa
Actually, I would have been possible if Nav directions could go thru HFP and not AD2P (like a phone call basically). I don't know if Isudar supports HFP Prompts. You could try to activate HFP Prompts in Maps settings and report back.
Old 04-07-2022 | 05:17 AM
  #885
konkab's Avatar
konkab
I know there are CarPlay modules that have two separate wires for audio output for navigation instructions. I don't remember if Isudar unit has these wires, but maybe it does. In the setups I saw people connected the wires to the central speaker for navigation instructions.
Quick Reply: Isudar Carplay for PCM 3.1
