Isudar Carplay for PCM 3.1
#616
Alright, for people that had PCM3.1-GD… and wasn't able to update the MCU to fix volume, the support person for Amazon side (support0888) just sent me a new archive with gd_upgrade.bin and mcuupgrade.bin. With the two files on USB stick, my board was able to update.
I checked and the mcuupgrade.bin with hex editor and it is exactly the same as the one @Santirx, but the gd_upgrade.bin is a new file that we have never seen before with a creation date of 01/05/2022, 1 minute before the mcuupgrade.bin
#618
@JohsonChou This is for the volume fix though correct ? NOT the new steering wheel back button fix ?
#619
front (aftermarket) camera supported?
does this Isudar Carplay unit support an aftermarket camera?
if yes, has anyone added one? what hardware did you use?
I know Isudar is still working through some bugs with their firmware but I might still pull the trigger soon.
I did notice you can no longer order the Isudar via Amazon only direct & I think aliexpress...
#620
#621
That is a storefront for Isudar and you can actually specify if you want v1.2 or v2.0 of the board…
#622
Also http://xyingly.com
#623
(If my memory is correct, that was a thing with researching the Joyceauto & you had to request needed some longer screws during your order)
* how long did it take to receive your order once purchased?
(& does it matter from China or Poland?)
(I am trying to time receiving mine close to my planned install date / if it matters I'm in San Diego)
#624
[QUOTE=981BGTS;17908774]I
I ordered a second kit, 2.0 board on 1/11/22. I received it today 1/24/22.
All the screws on my first kit, 2.0 board, included all the screws needed to install into a PCM with XM/Sirius.
* does it matter if you have Sirius/XM radio?
#625
I just wanna report that my reverse camera was fixed by resetting the fuse. So people that previously wasn't able to upgrade because of the greyed out button can upgrade with the new mucupgrade.bin and gd_upgrade.bin together on the usb.
#627
I received today the MCU Firmware update to correct steering wheel behavior, and I'm happy to report that the issue has been corrected with this new update.
This update makes the Isudar PCM3.1 platform almost perfect (4.5 stars in my view). A few lingering issues remain, that are less intrusive:
1. Calls going on-hold when pressing the steering wheel phone button (this behavior observed when phone is paired with PCM)
2. Connection time after turning car off
#628
#629
For me, having that steering wheel return button control both MFD and CarPlay at the same time was very annoying and disruptive. And it wasn’t an OEM behavior. I’m glad I did the update.
Just so you know, the PCM return button still works.
#630
Yes it does. If you like the steering wheel return button behavior as is, do not update.
