Sponsored By:
Sponsored By:
Diesel Cayenne and VW emission issue
Old 09-02-2019 | 05:59 PM
  #6346
BrewDude's Avatar
BrewDude
Originally Posted by skiahh
Anyone know anything about this suit and whether if affects CDs?
https://www.msn.com/en-us/money/comp...ent/ar-AAGEPTx
Nope...only gas.
https://www.thedrive.com/news/29641/...98000-vehicles
Looks like I'll be getting some coin back for my allroad.
Old 09-02-2019 | 09:29 PM
  #6347
MJG911's Avatar
MJG911
and I think we generally outperformed the gas mileage numbers, at least pre-fix.
Old 09-09-2019 | 03:03 PM
  #6348
f4 plt's Avatar
f4 plt
Veteran: Air Force
I just got a check engine light on our 2014 diesel Cayenne with messages or other abnormalities shown the car has 98,000+ miles and has had the def blue heater element replaced at least twice. The latest under the current recall. I’m taking it to the dealer in the morning as they think it may be an EGR valve . Others that have had an EGR issues, did you get any messages other than a check engine light
Old 09-09-2019 | 03:50 PM
  #6349
r553's Avatar
r553
f4 plt,
When I got a CEL in my CD the dealer replaced the EGR control valve at 40K miles.
Good luck
Rob
Old 09-10-2019 | 10:15 AM
  #6350
docwyte's Avatar
docwyte
Had to have the dealer reset the AdBlue fill sensor, again. I followed the procedure in the manual and the light did go off, then came back on a few days later and refused to clear. My icarsoft couldn't clear it, can a Durametric?
Old 09-10-2019 | 11:59 AM
  #6351
f4 plt's Avatar
f4 plt
Veteran: Air Force
Took my car to the dealer. They ran the codes and it was not an EGR control va,vet issue but instead a fuel injector going bad. Part had to be ordered and I was told no issue to continue driving the car . They will replace it when the part comes in
Old 09-10-2019 | 12:04 PM
  #6352
lightemup67's Avatar
lightemup67
Will it be covered under the emissions warranty? Or are you coming out of pocket for it? Just wondering what people are getting covered.
Old 09-10-2019 | 01:07 PM
  #6353
f4 plt's Avatar
f4 plt
Veteran: Air Force
I did not ask, but the car is still under CPO warranty so it should be covered
Old 09-10-2019 | 06:06 PM
  #6354
User 52121's Avatar
User 52121
Too much Volkswagen, not enough Porsche to get the Durametric to talk to the Cayenne, unfortunately. Might have better luck with a VAG-COM.
Old 09-10-2019 | 07:10 PM
  #6355
Nugget's Avatar
Nugget
I've had no trouble resetting oil change and scheduled maintenance alerts on my Cayenne Diesel using the Durametric. I'm not sure what would be involved with AdBlue, though. Isn't that strictly just a level sensor, and not something that requires a reset? I've always topped off my AdBlue myself when the alert comes up and I've never had to clear anything -- no dealer or Durametric involved at all.
Maybe a failing sensor, docwyte? I'm not sure how it works, but I don't think there's anything in the computer that needs to be reset.
Old 09-10-2019 | 08:48 PM
  #6356
BrewDude's Avatar
BrewDude
VCDS won't communicate fully either, unless you have the latest HEX-Net dongles anyway, and even then it's still sketchy.
My PoCOM has surprised me as far as features and it's cheaper than Durametric with more frequent updates to the software.
Old 09-11-2019 | 10:01 AM
  #6357
docwyte's Avatar
docwyte
Definitely something the dealer can reset. They plugged into it and were able to reset the warning light. The sensor has been replaced a couple of times already.
Old 09-16-2019 | 12:56 AM
  #6358
User 52121's Avatar
User 52121
Alright, so I had a few free moments this afternoon and did some quick data logs with the PIWIS. It was a humid day and the throttle lag was apparent.
I feel pretty confident it’s mostly the trans. I was able to record a full 1.5s between me flooring it, and the engine calling for boost... it was waiting for the trans to react. Requested boost level remained flat until it selected gear, THEN requested boost went up and THEN actual boost ramped up.
Putting the car in manual mode and flooring it, requested boost jumps up immediately.
Contributing to the lag... my theory... has to do with the manifold being full of nothing but EGR gas. When you drop the throttle the car gets almost 100% EGR. For seconds, it will sit at 100% EGR until you tip back in and the EGR ramps down.
So decelerate from speed, you get full EGR, and tip into the throttle rolling a corner... the engine is choking and full of its own exhaust, the trans doesn’t know what to do so it sits doing nothing... THEN it decides to add boost.
I wish I had a unfixed one I could look at data on.
It also makes me think to wait until Malone offers a TCU tune to go along with their ECM tunes...
The following 4 users liked this post by User 52121:
BrewDude (09-16-2019), hotrod2448 (09-16-2019), MJG911 (09-16-2019), Nugget (09-16-2019)
Old 09-16-2019 | 09:08 PM
  #6359
skiahh's Avatar
skiahh
Except for the EGR aspect, it's exactly what I've been seeing, thinking and telling my dealer!
Lately, when cold (first thing in the morning; and by cold, I'm talking mid to high 50s), the transmission has become so bad, it almost seems like there's a binding somewhere in the system. 3rd gear, about 22 mph as the trans hunts for what the hell it's supposed to be doing (TC lock up, shift to 4th to keep RPM as low as possible or upshift to provide enough torque to keep going), it's started bucking pretty good. This is on the '15; no reports of this behavior on the '14.
Dropping it off tomorrow afternoon and then back Wed AM to demonstrate.
Old 09-16-2019 | 09:40 PM
  #6360
User 52121's Avatar
User 52121
The digging started based on a theory that I, and some former co-workers (diesel engineers) had over how they "fixed" it - as well as a preventative check. In a lot of diesels, I've been told that EGR is used when at WOT to reduce cylinder pressures. When considering a Malone tune, and a full EGR disable, we were wondering - if the strategy uses EGR to keep cylinder pressures down, this mighe be an issue. But testing confirmed - at WOT, EGR is 0. The other thing we wanted to look at was the tip-in performance. I/we expected to see a lot more EGR during throttle tip-in to explain the horrible lag. It was the only easy thing we could come up with that might make sense. EGR the bejeebers out of it for emissions and since you're nowhere near the "peak" performance numbers they won't get penalized.
But the instant you tip in heavy - the EGR valve is (commanded to, anyways) slam shut. So the remaining theory is that, since it's damn near (or actually IS) 100% EGR while you're slowing down... the entire intake path has backfilled with exhaust gas enough that when you tip in... you're basically gagging the engine for a bit.
I suppose there's also the chance the EGR is still hanging open - tho the system DOES monitor actual EGR position so if there's a chance for it to hang open, being an emissions component, I'd expect a CEL immediately.
Quick Reply: Diesel Cayenne and VW emission issue
