Nose lift, CPO, PCNA
#331
Hey sorry I've been really busy. I don;t have any additional switches with me. I'm glad someone got to making a DIY for the switch replacement. It really isn't that hard.
I ordered them from https://thesensorconnection.com/ . I would give them a call to get a quote.
cdixon, I still need to get around to testing that solenoid valve. Right now it looks like there must have been some sort of desiccant failure (oil contamination perhaps?) causing all this corrosion. Right now I've figured out that there is a pinch clamp holding part of the compressor shaft together that I need to pull apart.
cdixon (03-02-2023)
#333
OK, here is the deal. The price breakdown is the following based on quantities:
$245 - 1
$212 - 3
$141 - 5
ETA is 8-10 weeks to get these in.
$245 - 1
$212 - 3
$141 - 5
#334
Originally Posted by powdrhound;[url=tel:18662257
18662257[/url]]OK, here is the deal. The price breakdown is the following based on quantities:
$245 - 1
$212 - 3
$141 - 5
$245 - 1
$212 - 3
$141 - 5
#335
The switch from Germany should be around 50 Euros-
It might be a good idea to email the other vendors, including the one in Spain-
But, I would think that the vendor you contacted would quote an even lower price if 10 or maybe even 20 were bought-I'm sure we could get 20 of us together to make a group buy-
#336
$245 - 1
$212 - 3
$141 - 5
$245 - 1
$212 - 3
$141 - 5
#337
It would indeed be good to get quotes from multiple sources-reminds me of the VAS 6154 vendors that started raising their prices after too many people started buying them on eBay
If it's the same source and it's more expensive, I would definitely point it out to the salesperson-
JB
#338
So at&t decided to allow me to reach the German site
https://www.suco.de/en/pressure-moni...-hex27/f1/146/
Here it is, and it would be nice if some European members wrote or called them to get a quote-if someone can place an order in a European country(if they won't ship to the US) it might still be worth it, if they are indeed 50 Euros there-
It would be nice to get this switch with a price of regular maintenance like an oil change
JB
JB
#340
Here’s the link to the folks in the UK that can get them… Quite a long lead time though when I checked a few years ago…
https://www.oem.co.uk/products/press...switch-_-54332
Good site as it provides spec details for all the variants
#341
@cdixon I finally got around to testing the solenoid and removing the cover for the pneumatic valve. All my solenoids make a good thunk when 12V is applied. I took the cover off of the pneumatic valve and everything in there looks corrosion free and the valve piston moves OK.
Does anyone know how to remove the plastic air dryer housing from the aluminum valve block? I don't just want to pry and break something.
Pneumatic valve piston and cap
Pneumatic valve cylinder
#343
in for group buy
#344
The internals of that 2/2 pneumatic relief valve looks fine to me.
As I said before, I got lucky and never had to dig as deep into the system as you are. It’s looking like the dryer, main compressor cylinder is a factory sealed unit. :-(
I’ve always thought the whole pump unit, looks like a hacked air suspension compressor to me. I did try to track one down on the internet but gave up, maybe i’ll look again.
#345
here are the part nos from when dealer fixed my lift
997-341-963-90 ($467(list) $365/online)
997-341-965-90
997-341-967-90
997-341-965-90
997-341-967-90
