997 GT2/GT3 Forum 2005-2012
Catastrophic Coolant Hose Coupling Failure Registry
Old 05-02-2013, 02:57 PM
  #376
jpflip
jpflip's Avatar
2002 TT.... Got this car in 2008 with 39,200 miles on it and one of the pipes failed at 47,000 miles. On engine removal I've found another pipe loose in his recess. The glue was in powder form! Both pipes were located on the water pump housing....Got all eight welded and no problem since....
Old 05-10-2013, 03:18 PM
  #377
Nizer
Nizer's Avatar
Received 1,882 Likes on 970 Posts
Old 05-10-2013, 04:32 PM
  #378
lp997
lp997's Avatar
Even if you are not in the US, Did you file an incident report with the NHTSB? So far the NHTSB is acting on just 8-10 reports of failures, mine being one of them. The more people who follow up the more likely Porsche will be forced to make a permanent fix.
Old 05-10-2013, 05:32 PM
  #379
Gofishracing
Gofishracing's Avatar
That is not accurate. As per NTHSA to me at the initiation of the Investigation:
Bob,
An investigation is officially open and now on our public website, wwwsafercar.gov, investigation number PE13009. The opening statement lists 10 reports to us which is a snapshot at the time the official paperwork started through the approval process and then there is a delay of 72 hours before it goes public to allow the manufacturer to get up to speed.
Stephen
So- if you had a repair just file a complaint- I'm sure there are hundreds by now. I'll get an update next week.
Old 05-23-2013, 08:46 PM
  #380
jcb-memphis
jcb-memphis's Avatar
Originally Posted by horsepowerfarm View Post
This is my 2003 996TT at .8 bar on its first pass on the dyno. This happened in late March. I have a case open with the NHTSA. Not tracked, before mods, 82,000 mile daily driver in central Texas.
This is making at least one person in cognitive dissonance on Porsche having this problem spinning....
I hope NHTSA sees this and says...hmmm....on ramp....no traction....kids in minivan right behind them...hmmm...elevated ramp......distracted parent.....
jb
Old 06-03-2013, 03:09 AM
  #381
karmx7
karmx7's Avatar
As best I can tell from the description he hits some coolant in the braking zone on track. He doesn't say if it was from a previous car (I didn't see any obvious line on the track) or if it was from his car (it's somewhat suspicious that a GT3 suffers a violent spin under braking apparently from the loss of traction at the rear....). At any rate, it's a pretty hard hit and I'm glad to see that he is OK.
Old 06-03-2013, 09:34 AM
  #382
FFaust
FFaust's Avatar
He says there was a line of coolant on the track, which you can see at approx 0:28 min. Spent 24 hours in hospital.
Old 06-03-2013, 11:04 AM
  #383
karmx7
karmx7's Avatar
Yep, I believe you are correct (hard to tell but it looks like a car may be pulled off to the right which had dumped the coolant).
Old 06-14-2013, 01:57 PM
  #384
jkwino
jkwino's Avatar
2004 996 GT3
Turn 3 Summit Point
Right side coolant hose decoupled
dumped coolant on the loaded rear wheel- caused a spin and crash resulting in expensive front end repair.
replaced with 997 part
Old 06-14-2013, 01:59 PM
  #385
jkwino
jkwino's Avatar
Also had the pressure fit metal hose barb fail- this failed at SP turn 10. Expensive repair again.
Both incidents around 43k miles
Old 06-14-2013, 02:34 PM
  #386
jkwino
jkwino's Avatar
Does anyone know if PCNA has done any remediation for past incidents repaired that happened either during or out of warranty. Two expensive repairs plus a crash do not make me a very happy customer right now.
Old 06-14-2013, 03:27 PM
  #387
Andrew D.
Andrew D.'s Avatar
'07 997.1 GT3
Welded to replace epoxy after catastrophic failure.
Replaced left and right-side front radiator hoses and flanges with superseded parts after repeated failures.
Old 06-14-2013, 04:56 PM
  #388
Gofishracing
if the fitting failed file a report. I am going to reach out to all PCA Chapters.
Old 06-14-2013, 11:34 PM
  #389
Bailey-86-MA
Bailey-86-MA's Avatar
Year: 2002
Model: GT2
Mileage: 26,000
Circumstances surrounding failure: May 2013, Turn 3 NHMS (rear end got loose but no spin)
Specific Coupling: top fitting in manifold
Repair Solution: getting all fittings welded by EPE in Natick, MA
Last edited by Bailey-86-MA; 06-14-2013 at 11:37 PM. Reason: belongs in 996 GT2 forum
Old 06-17-2013, 03:23 PM
  #390
Andrew D.
Andrew D.'s Avatar
Report filed. I will get the word out to all POC members.
Quick Reply: Catastrophic Coolant Hose Coupling Failure Registry
