What did you do to your 997 today?
Old 07-16-2020, 10:31 PM
  #10411
rtl5009
rtl5009's Avatar
I took my cluster out a few years ago to clean all the lenses and I scratched the **** out of the steering column shroud plastics. Today I repainted them and the inner door sills.
turned out great!
rtl5009 is offline
The following 6 users liked this post by rtl5009:
heavysixer22 (07-16-2020), Ironman88 (07-16-2020), Khloesdad (07-17-2020), ru_stupid2 (07-20-2020), tegraphile (07-17-2020), VT Blue (07-16-2020) and 1 others liked this post. (Show less...)
Old 07-16-2020, 10:43 PM
  #10412
heavysixer22
heavysixer22's Avatar
My first wrenching on the car! I changed a brake bulb in the time it took to heat up nacho's in the toaster oven.
I'm sure all the maintenance on 997's is that easy, right?!
heavysixer22 is offline
The following 2 users liked this post by heavysixer22:
Ratchet1025 (07-19-2020), ru_stupid2 (07-20-2020)
Old 07-16-2020, 10:46 PM
  #10413
TheTorch
TheTorch's Avatar
You wouldn't be joking if it was the fixed 3rd brake light. Much, much more time consuming and requires some absurd backseat gymnastics (not the good kind) to get it done.
TheTorch is offline
irnnr (07-17-2020)
Old 07-17-2020, 01:08 AM
  #10414
tegraphile
tegraphile's Avatar
Installing the Function First Shift Right kit into the OEM SSK. Unfortunately, got stuck on getting the snap rings into place, so ordered a snap ring plier and will pick it up in the morning.
tegraphile is offline
hamishpotter (07-25-2020)
Old 07-17-2020, 01:10 AM
  #10415
tegraphile
tegraphile's Avatar
turned out great!
They look amazing! Can I ask how to prepped them and what kind of paint did you use?
Old 07-17-2020, 09:24 AM
  #10416
rtl5009
rtl5009's Avatar
I scrapped all of the old rubber coating with a credit card, cut it in half with a really sharp blade and used the cut edge to scrap as its fresh and works great. Hit it with simple green and let it soak in and then wiped with a red rag a few times to get all the residuals off. Cleaned with dawn soap and water and then gave it about 4 coats of this Rust-Oleum Custom Matte Black Lacquer Spray Paint- they had it at autozone. I masked off the little microphone (I am guessing) vents on top of the steering wheel surround.
Take your time taking off the surround, there are a few wires that need unclipped and push out of their holder but its an easy job.
rtl5009 is offline
tegraphile (07-18-2020)
Old 07-17-2020, 04:03 PM
  #10417
irnnr
irnnr's Avatar
I recently did that, too. Not hard, but yeah, better get some yoga practice in before. Did it in an hour I guess, just taking my time.
irnnr is offline
TheTorch (07-17-2020)
Old 07-18-2020, 02:25 PM
  #10418
doclouie
doclouie's Avatar
Changed out the brake fluid, Motul RBF600, at 2 years and two months here in deep East Texas. I bought a probe to test the water amount in the fluid and it was at 3%. Going to change the fluid more often going forward. One of these is not like the other. Crazy how dark it gets.
doclouie is offline
Old 07-18-2020, 07:12 PM
  #10419
North Shore 911
North Shore 911's Avatar
Originally Posted by TheMurse
May not be to everyone’s taste but I like it
I did this 2 years ago - Great minds think alike
North Shore 911 is offline
TheMurse (07-20-2020)
Old 07-19-2020, 03:58 PM
  #10420
platinum997
platinum997's Avatar
little autocross this morning.
platinum997 is offline
Old 07-19-2020, 05:20 PM
  #10421
Sporty
Sporty's Avatar
I just replaced my climate controls with the MaCarbons- they came out great and thanks to the video (the one with the guy with the tweezer method if you google it)
rstl5009: that looks great. How are hard was it to get the sills out -do they just pop off ? Anyone know how to take the pieces off by the door handle and window switches, that is, do you have to take off the whole door panel off or will they pop off. I will be on a refinishing campaign for all those crappy rubberized pieces that are showing more and more scratches, including the center console
Sporty is offline
Old 07-19-2020, 07:00 PM
  #10422
ru_stupid2
ru_stupid2's Avatar
Default Fuel injectors on 997.1
I put new fuel injectors in and what a PITA. The passenger side was a more difficult than the driver side (after removing the coolant tank).. pulling the tank was well worth it 100%! With the tank in place I could barely get a h d in. With the tank out I can get both arms fully in the cavity.
ru_stupid2 is offline
The following 2 users liked this post by ru_stupid2:
jayi836 (07-20-2020), Ratchet1025 (07-19-2020)
Old 07-19-2020, 07:42 PM
  #10423
rtl5009
rtl5009's Avatar
Lol! Your removed the coolant tank to do the injectors..... the injectors on a 997.1 are tedious but a relatively Easy job. I’ve done it without even lowering the motor!
rtl5009 is offline
Old 07-19-2020, 07:47 PM
  #10424
Khloesdad
Khloesdad's Avatar
Curious why you replaced the injectors.
Khloesdad is offline
Old 07-19-2020, 11:55 PM
  #10425
JoshGordon
JoshGordon's Avatar
Installed a Numeric shifter in place of the stock shifter. Very mechanical and precise, and got rid of the annoying plasticky sounds when shifting. It's a shame it's covered by the center console, it's like an engineering work of art.
JoshGordon is offline
The following 4 users liked this post by JoshGordon:
G.I.G. (07-21-2020), IrishLegend (08-10-2020), jayi836 (07-20-2020), Ratchet1025 (07-20-2020)
Quick Reply: What did you do to your 997 today?
