What did you do to your 997 today?
Old 03-02-2020, 10:45 AM
  #9571
TheTorch
TheTorch's Avatar
Originally Posted by JEHolloway
Does that FF shifter **** fit like the stock one attaching at base to the ring clip that must be turned to unattach from the shift boot?
Not exactly. You remove the stock locking ring and a plastic sleeve washer that holds the leather boot onto the shifter and the FF has a double o-ring setup that holds the boot on. The **** is attached with a couple of hex set screws onto the actual shifter arm.
Easily reversible back to stock. Having been using it for a couple weeks, I would say the only downside of the FF delrin **** is that it's a bit slippery.
Installation directions at bottom of: http://www.function-first.com/produc...sic-shift-****
TheTorch is offline
JEHolloway (03-02-2020)
Old 03-02-2020, 12:28 PM
  #9572
HenryPcar
HenryPcar's Avatar
Originally Posted by Ironman88
I'm probably somewhat of a nutcase fanatic - but here is the process / products that I used:
1. CarPro Iron X (initial cleaner - primarily for the barrels and inside rim)
2) Sonax Full Effect Wheel Cleaner (outside of wheels)
3) Stoner Tar / Bug remover
4) P21S Paintwork Cleanser
5) CarPro Eraser - prep for ceramic (hyper wax in this case - removes any polish residue and promotes adhesion for the wax / sealant)
6) Chemical Guys "Hydroslick"
Tell us , do you ever enjoy going out driving your car ?
HenryPcar is offline
Old 03-02-2020, 12:40 PM
  #9573
Fined
Fined's Avatar
On the wheels alone?! 6 chemicals/treatments for just the wheels? If so, wow. I just use dish soap and then rinse them off
Thats some commitment to them being clean!
Fined is offline
dmpslc (03-04-2020)
Old 03-02-2020, 03:41 PM
  #9574
Ironman88
Ironman88's Avatar
Received 2,238 Likes on 1,178 Posts
For me it more than just getting them clean. It's cleaning, restoration, and protecting. With all of this done, it will be quite a bit easier to keep them nice.
Completed both of the fronts yesterday...
Ironman88 is offline
Old 03-02-2020, 03:47 PM
  #9575
V-Raptor
3rd Gear
V-Raptor's Avatar
Originally Posted by NikkiSixxPA
Today, I drove it
NikkiSixxPA great pics! Is that Atlas Gray?
V-Raptor is offline
Old 03-02-2020, 06:39 PM
  #9576
RangerRick
RangerRick's Avatar
I drove her like I stole her!
RangerRick is offline
latonnelier (03-02-2020)
Old 03-02-2020, 08:01 PM
  #9577
Wayne Smith
Wayne Smith's Avatar
Received 1,199 Likes on 766 Posts
I installed a retrofit satellite radio via the aux port in the center glove box (2010 C4S) ... Made my own tap-a-fuses, mounted the controller inside the center tower, everything else was straight forward. Should have done this years ago.
Wayne Smith is offline
Ratchet1025 (03-06-2020)
Old 03-03-2020, 12:01 PM
  #9578
AIrey1507
AIrey1507's Avatar
No picture, but completed the key swap process using this $20 blank from Amazon -
Amazon Amazon
and the instructions found here - https://www.6speedonline.com/forums/...ransplant.html
Overall the process was easy, just time consuming. My old key was in really bad shape, and I had a spare with blade/transponder, but no buttons/circuit board. So I took the blade, battery terminals and transponder out of the spare key. Took the rubber pad & circuit board from my "good" cracked key. Hardest parts were getting the battery terminals seated properly, and then aligning the rubber pad/circuit board to make good connection with the remote buttons. The transponder was very tedious - I basically ended up cutting off all the key material holding it in, vs. getting through the glue and angling out the transponder. Fortunately the transponder itself seems to be pretty resilient. Nice to have the new look key (I just searched/bought on Amazon, no endorsement on this being an OEM replacement) for only a $20 investment and some patience, vs. spending $200 on the key and another $50-150 on having the dealer program it.
AIrey1507 is offline
Old 03-03-2020, 02:14 PM
  #9579
quickxotica
quickxotica's Avatar
Swapped my stock sport steering wheel for a less blingy all-black alcantara wheel. (pics taken before I fully snapped in the airbag)
After:
Before
Before (I never loved all the faux silver on this wheel design -- trying too hard, IMO)
Also, i just received this fun box. Hmm... I wonder what's inside?
Love the individual numbering! Full anorak mode.
quickxotica is offline
The following 2 users liked this post by quickxotica:
Aclmin (03-03-2020), byroncheung (03-04-2020)
Old 03-03-2020, 08:05 PM
  #9580
Daenan44
3rd Gear
Daenan44's Avatar
Removed stuff with hopes of a good memory!
Daenan44 is offline
The following 2 users liked this post by Daenan44:
jayi836 (03-04-2020), quickxotica (03-04-2020)
Old 03-04-2020, 12:59 PM
  #9581
jayi836
jayi836's Avatar
What are you doing to your Turbo?
jayi836 is offline
Old 03-04-2020, 01:07 PM
  #9582
PCARNTHZST
PCARNTHZST's Avatar
Drove it for the first time this year then changed the oil
PCARNTHZST is offline
Old 03-04-2020, 07:20 PM
  #9583
Daenan44
3rd Gear
Daenan44's Avatar
Question
As has happened with many people, it started as a coolant leak and the plan to fix/pin fittings... which means might as well knock out sharkwerks elbows, all the other basic maintenance (plugs/coils/hoses/water pump etc). Since the engine is out, need to pin the cams.
Then black friday deal on AMS Alpha Intercoolers popped up and ECU/TCU tune from Markski. Realized that it's not right to put the stock exhaust back on, so picked up Kline SS exhaust. Intake pipes should be here next week too.
Now I am at a crossroads on whether or not to do injectors (in the event I want to try out E85) and/or 63.5/65mm VTGs.
Daenan44 is offline
jayi836 (03-05-2020)
Old 03-04-2020, 09:02 PM
  #9584
Vincent713
Vincent713's Avatar
Interested in buying your old steering wheel if it's for sale.
Vincent713 is offline
Old 03-04-2020, 09:49 PM
  #9585
lexhair
lexhair's Avatar
I drove it to work for the first time. Ever. Owned it a week. 09 C4S.
lexhair is offline
The following 5 users liked this post by lexhair:
997GTScab (03-13-2020), Ironman88 (03-04-2020), jayi836 (03-05-2020), JEHolloway (03-05-2020), TheTorch (03-04-2020)
Quick Reply: What did you do to your 997 today?
