Note to Porsche classic - 997 PCCM plus request
#2101
Recently installed my PCCM+. My car came with PCM 2.1, sound package plus (no Bose), factory navigation.
I'm getting this iGO Navigation message with the SD card installed.
I reconfigured unit several times, but then remembered I did not install the orange fiber optic loop cable. Is that the issue?
Does that cable install in the frunk at the connection to the factory navigation module?
#2102
I have Bose, but had this same message when I installed my SD card the first go-round. Never got it past the initial configuration. Returned the SD card and installed a new one and it worked fine. Might want to return your card and try a new one, which is easy to do. Good luck.
Sam-g (06-10-2023)
#2104
Just to clarify, is "H" needed at all if your car is equipped with Sound Package Plus or Bose? My car has factory nav and I'm wondering if it's needed to loop out the old nav unit.
I'll also try a new SD card to see if that resolves my nav startup issues.
#2105
Yes, if you have factory nav you need to use the loop. I believe the directions are in the pinned diy guide.
#2106
#2109
From the photo (excellent - thanks!) that looks like a flip up ZIF connector - did you try to flip up the tab? Any other tips to get to the point in the photo?
I'm going to deal with the same issue - except I need to match sand beige leather so lines and gaps will be much more obvious.
#2110
Hi all,
can anyone elaborate on the settings for the internal and external mics in this so called Developer menue. Especially what ist meant with PGA, UPLINK and OP?
I maxed out PGA and UPLINK following the DIY-Guide, but I didn't realize any significant change in soundqualitiy and volume ....or am I deaf?? Having a call with top and windows down is nearly impossible. Any help is appreciated.
THX
THX
#2111
PGA ?
UPLINK ?
OP?
I can't get UPLINK numbers 12/12
#2113
How do you remove the PCCM+ once you 'click it' in place. Having a difficult time removing and wondering if I did the above by accident?
Are you meant to push the tabs in together? As the alley key approach for the PCM doesn't seem to work for the PCCM +
#2114
All 4 tabs need to be pressed
@Ryany08 you can get someone to help you & press all 4 tabs simultaneously. Or you can use micro wrench for Allen screws. They are not Quarter turn, so you’ll need to turn them all the way - which will take some time & patience. Tip - I recall it’s the opposite direction of the PCM radio.
I cranked in top two screws all the way in, so top tabs are depressed all the time. Much easier to access bottom tabs if I need to remove.
hope this helps.
hope this helps.
#2115
hope this helps.
hope this helps.
