Note to Porsche classic - 997 PCCM plus request
#166
Thanks again @myw for finding this. I read through the PDF manual over the weekend and have some thoughts/observations, several of which you've already pointed out.
First, I'm assuming the two different part numbers are for Bose and non-Bose cars, but can't confirm that. I guess we'll find out when these are actually made available for sale.
As I mentioned in the other 997 PCCM+ thread, wired Carplay isn't a deal breaker for me, as I usually take the opportunity to charge my phone when I get in my cars anyway. However, with the USB port on the front of the unit, it will look a little odd plugging in a USB there on a regular basis. I was really hoping that the USB port would be on the back, or at least there would be a second one on the back, so I could run the cable more discreetly to the small storage area beneath the HVAC controls. Based on the pictures, that doesn't look like it's going to be an option.
Under the audio settings section of the manual, it only makes mention of a 2-band EQ: trebble and bass. That's a big miss when it is so easy to program in at least a 3-band EQ (treble, mid, bass) into even a basic car stereo. Shoot, every low-mid tier rental car I've had for the past 10 years has had a minimum of a 3-band EQ. The 10+ year old Kenwood in my 4Runner has a 10-band EQ. The Bose speakers and placement can actually be pretty good if given the audio settings and EQ to allow you to customize it for the type of music you listen to. Unfortunately, that doesn't look like it is an option with the PCCM+, which is disappointing. With all of that said, I am currently using the Transit Blu HF transceiver for connecting to my phone, which only sounds like an OK FM channel. So just having native Bluetooth in the HU will be an improvement in audio quality over what I have now.
I still plan on buying this when it becomes available, and I will likely use it like I do with my Kenwood in my 4Runner that does not have Carplay, but does have Bluetooth. I would sync my phone to the PCCM+ via Bluetooth for audio streaming and voice calls. On the occasion that I want or need turn-by-turn directions, I would leave another USB cable in the glove box and plug it in to use Carplay for navigation. I actually think it's quicker and easier to navigate through my playlist and enter directions in navigation through my phone itself. So using Carplay on a regular basis, especially since my 997 isn't my daily, won't be necessary.
Lastly, regarding no support for a backup camera, that doesn't bother me all that much either. As others have pointed out, it's disappointing that it's not compatible for those who want it, but I find it fairly easy to park and backup my 911. When parking in public parking lots, I try to back into a spot or find a spot where I can drive through so it's easier to pull out when I'm leaving. With our cars being so small, I never have to back all the way up to a curb or wall for the whole car to easily fit in a spot, unlike a truck or large SUV where you need to get within inches so you can fit in the spot.
Hopefully we hear more about pricing and availability soon....
#168
#169
it's silly as they 996 guys have been complaining about that right away, and it's been 2 years. The fact that at it's heart, it is a chinese android device (nothing wrong with this) means that the back up camera was 'removed'. ugh
TerrestrialFlyte (06-19-2022)
#171
Update: I called my local dealer, Porsche Littleton, as well as sent an e-mail to Suncoast Parts, and neither of them have any information or the part numbers listed in the owner's manual in their system. So pricing and availability is still TBD. I suspect Suncoast will send an update in the marketing e-mails when it becomes available. I might try to call back in a month or so to see if there has been any movement with availability.
It will. On page 33 of the owner's manual, it outlines how to access and change your individual settings: lights, wiper, climate, lock, and factory settings.
ekam (05-11-2022)
#173
I am guessing that an external microphone is not needed and the internal one can be used if you're not looking for perfect call quality? The length of my phone call would be a minute, simply enough to say that I'm driving and would call back later. Would rather not have to route a microphone throughout the cabin. While a backup camera would be nice, I also wouldn't want to go through the wiring for one, so not having one is fine with me. Mostly looking for the Porsche aesthetic, both when the unit is off as well as the interface when it is on.
Also, if you put the part numbers into any online vendor, it now shows up, but it shows up as a discontinued product. Previously, I don't remember even seeing it on the websites when looking up the part number.
https://www.sunsetporscheparts.com/o...mm-99764259000
https://www.sunsetporscheparts.com/o...mm-99764259100
ekam (05-15-2022)
#174
That being said, this is a welcome update and given my 997 is my daily, and the infotainment is THE single biggest deficiency, they cannot release this for sale soon enough!
myw (05-17-2022)
#176
Ok, I have to ask, those that asks for wireless CarPlay/AndroidAuto, don't you have to plug the phone in anyway to charge...? Unless the car has wireless charging, wireless CarPlay/AndroidAuto is a bit pointless...?
#177
To me wireless in a huge advantage which is why I went with the joyauto addon for the factory 3.1 pcm
#178
That said, compared to the aux adaptor I'm currently running in my 997, I'll take wired only Apple CarPlay!
#179
I fabricated a mount to keep the phone out of site but easy to insert into a wireless charger. It works great for full day drives and the charge is higher at the end of the day than at the start. I used to use a charger that opened when it sensed your hand on the side but the phone would release when I went for the seat heater. The one I use now is a gravity hold. With the wireless Carplay / AA it's as easy as can be and I don't worry about wearing out the cheap power plug in my Samsung (the only failure point I've had on a phone and the reason I refuse to connect to it).
The radio sticker is so I don't forget to bring it on group drives.
mikes70 (05-16-2022)
#180
To Wayne's example, Anthony just installed his 9XX in my .2 C2S this weekend. It's awesome and I'll do a separate write-up soon. That said, I recently did the Rennline phone mount to Spiegel wireless charger hack (search threads) so I now have wireless CarPlay and wireless mount charging. In addition, my son spliced in a USB to Lightning cord behind the PCM, and I drilled a hole, adding a rubber grommet, through the back of the cubby under the HVAC so the primary or a secondary phone can charge (wired) simultaneously...either one going off of 9XX's CarPlay.
I'm not waiting for Porsche's replacement, and am really, really happy with both the 9XX unit and Anthony. Dude knows his stuff inside and out.
Thx!
Bob
Thx!
Bob
The following 4 users liked this post by VT Blue:
