Chunks slow build... very slow.
#676
Like Uncle Ben said, “With great power comes great responsibility’”…. I damaged a bolt using my monster 1/2 driver. Ordered a couple nuts and bolts but aside from that mishap, the rear is finished. Should start the fronts which I read is easier because you only have the option to remove the hub completely and not be dumb thinking I could just remove certain bolts to get around it.
I did finish the speaker mods and man the CAI kit is pretty damn nice, makes for pro looking work. Ordered a second set of speaker deletes rather than have a mix n match speaker grill set up(rears are CF). Do any of you use the radio removal tools to remove the radio? Unfortunately I’ll have to remove the center console again because I totally forgot to reroute the cell phone plug from under there.
#677
Back to P car stuff. Had lunch with Barbancourt up in Broward. He hooked me up with an old shift boot so I could finish my shifter project. Photo of his car because I love the simple clean set up.
Next are the pics of the shift boot install to the frame. I did ok but still happy with it but I could’ve been finished a little better. The weighted **** is very nice and I love it.
Here’s a before pic with the GT3RS shift ****.
The following 6 users liked this post by TheChunkNorris:
GC996 (11-08-2022),
JMattKTM (11-09-2022),
plpete84 (11-09-2022),
Ratchet1025 (11-09-2022),
yaz996 (11-08-2022),
and 1 others liked this post.
#679
Thanks brother and yes, the VW is correctly occupying the garage but I could probably install the dash speakers now. Unfortunately Tropical Storm Nicole is out in the Atlantic deciding where to make landfall so the weather here is trash.
#680
Still working on the VW… the upper A arm ball joint will not release and I managed to break a ball joint separator that was probably made of Chineseum. Anyway, my battery died on the Porsche and I guess I never noticed but the battery is giant relative to the car. Never really thought where I needed to stand until it was time to remove the old battery… yep I stepped into the frunk and the hood provided fantastic shade.
Removed the radio to see where the Rennkit would need to be mounted. For those with the BTR3, where did you all run power and ground?
Completely random thoughts, now that the VW is out and I’ve been really slow to work on her… the Porsche is now my daily. Man I commend you guys who use this car every day! The Teq cage forces you to site upright which isn’t too bad but reaching back to get the seatbelt once in the seat is my only gripe about the cage. Fuel mileage has been pretty good at about 220mi to the tank and premium is around $4.30 a gal in my area. I did manage to catch the ledge of a curb and “rip” the lip off, it went back on with no problem and gave me an opportunity to retape the cup lip.
The more I drive it, the more I enjoy the car. Very happy with the ownership experience thus far.
RennKit-Dave (11-17-2022)
#681
As far as the 996, you are braver than I stepping in the frunk like that! Although I'm sure it made taking the battery out much easier. Also, you are only getting 220 miles for a full tank?!?! That's like 14 MPG. I typically get upwards of 350 miles to a tank if I run it all the way down..
#682
I stand in the frunk all the time, well not all the time but when u work on the battery and the fuel pump.
As far as the cage goes its rough on a stock seat position. Ill probably remove mine for the dragon trip.
#683
Basic Sponsor
Do you have the written instructions for the Bluetooth Retrofit Kit installation? We also provide some video links.
Dave
Rennkit
djcooper@rennkit.com
http://rennkit.com/
Rennkit
http://rennkit.com/
- Patented eRam Kit™ for 996/997 Turbo & Carrera GT wings
- Cal*Cool™ - brake cooling 996/997 / Bluetooth Retrofit Kit™ for 1998-2011 cars / Wing Extenders™ 987 Cayman / 997 Turbo
- AUTO-BLiP for MT / Function F1RST Shift ***** / Girodisc 2-piece rotors / OS Giken LSD / Phenix suspension / Zunsport grills / 997/987 switches/PCM ***** / Border Coilovers
#684
Damn dude you're a bull in a china shop.
When I did my heater foam thing I popped the struts and put the hood over against the windshield. (I did not have the luxury of being in southern climes, and the sun was not a factor.)
#685
The following 4 users liked this post by theprf:
#686
I have broken pickle forks too. Ball joints can be a real PITA. I guess it's time for the heat and the BFH. Keep at it and it'll eventually break free. Or take a grinder to the ball joints stud and press it out and replace the joint.
The following 2 users liked this post by TheChunkNorris:
RennKit-Dave (11-17-2022),
Type65 (11-17-2022)
#687
The following 2 users liked this post by SoCal911t:
TheChunkNorris (11-16-2022),
wdb (11-18-2022)
#689
One other update. Finally got around to installing the speakers into the car. Took about 30mins per speaker to convert a OEM speaker delete to a working speaker using the CAI kit and then removing the tabs on the Kickers to install into the CAI adapter. Ordered the speakers from Crutchfield since the speaker cables were included for free. Here’s the price breakdown for those who wanted to know.
Speaker Deletes - 55.00 per set x 2 = 110.00
Kicker 43DSC404 - 51.00 per set x 2 = 102.00
CAI speaker adapter kit - 50.00 per set x 2 = 100.00
So factoring the grand total of $312.00 and dividing by 4, the kickers sound better than the Bose units at 78.00 per. Links for products below.
Speaker adapter kit:
https://cai-store.com/collections/99...t-also-boxster
Speakers:
https://www.crutchfield.com/p_206DSC...-43DSC404.html
Speaker Deletes:
I found the Kickers to sound more crisp and pleasant, especially at $50 per set. Sure I could’ve gone more expensive to a Hertz or JL unit but I don’t think my ear could really tell the difference. Here’s what they looked like post conversion.
Speakers:
Speaker Deletes:
plpete84 (11-17-2022)
#690
I figured the floor board could support my weight, why not the frunk?
