996 Forum 1999-2005
zbomb's confused 996
Old 04-12-2021, 09:12 PM
  #481
zbomb
zbomb's Avatar
Received 4,287 Likes on 1,809 Posts
Originally Posted by yaz996
Just need to find the time. After a handful of runs on the new suspension and rubber, I think my next upgrade needs to be the driver.
You digging the new setup Yaz ? I saw that pic you posted in the black car thread, you're car is looking fire !
Originally Posted by Charles Navarro
Opening up the wheel arch liners will help significantly. We did this on every race car we built in addition to making our own radiator shrouds to improve airflow.
When I was tracking both my Boxster and Cayman, I eliminated one of the two a/c condensers on both cars like how Porsche did it on the GT3. Didn't hurt the function of the a/c at all except if the car was baking in the sun and it was ridiculously hot and humid outside. It just takes a little longer to catch up in those instances. We ended up making kits for these, but I only have them for 987/997 and later models currently :-(
Opening up the liner is a really good free tip Charles, I'm going to do that before my next track day...
Since you're here, couple questions I hope you can provide your experience on:
What did you like to see for temps on the race cars you built for oil and water ?
For someone that runs your deep sump / baffle and XP9 and still experiences dips and instability of oil pressure - Is oil temp control the next step in trying to mitigate the issue ?
Are pressure drops with the parts mentioned above down to 20PSI at 3.8K RPM unique to my case in your opinion or something you see often ?
Mucho thanks in advance !
Old 04-12-2021, 09:26 PM
  #482
zbomb
zbomb's Avatar
Throwing it out there... I'm looking for a budget set of cat deletes... I want to modify them and have small mufflers welded in roughly where the cats would be.... When I say budget... I mean budget...
If anyone has a bead on a set, let me know.
Old 04-12-2021, 09:28 PM
  #483
Jnelso
Jnelso's Avatar
Interested in opening up wheel arch liners. Anyone provide the basic procedure to do so?
Old 04-12-2021, 09:31 PM
  #484
theprf
theprf's Avatar
Received 1,775 Likes on 1,130 Posts
There's a writeup on Pelican. Basically you cut vertical slots in the liners like the Turbo/GT2 liners have. The lines to cut along are already in the liners, as I recall.
jobyt (04-12-2021)
Old 04-12-2021, 09:37 PM
  #485
Jnelso
Jnelso's Avatar
Yeah, I have seen that but I thought that was just to improve cooling to the brakes.
  #486
theprf
theprf's Avatar
Oh BTW Jason the difference in handling between your car and mine is like night and day. I'm sort-of herding the car along and yours is going right where you want it. HBdunn's car is the same way your car is. I need to improve the precision of this car - it can't be all me for pete's sake. I'm sure the extra 700 pounds isn't helping but the difference is ridiculous. Now that I have the mechanicals sorted out I need to address the suspension. When I get back from this trip I'd like to find out what you have done for suspension parts; I'm sure mine is mostly original and needs replaced.
Old 04-12-2021, 09:39 PM
  #487
theprf
theprf's Avatar
I think it's mostly to improve the airflow out of the radiators. Perhaps Charles Navarro will elaborate on what he's done to clarify.
Jnelso (04-12-2021)
Old 04-12-2021, 09:41 PM
  #488
jobyt
jobyt's Avatar
Here you go.
The following 2 users liked this post by jobyt:
RC713 (04-20-2021), zbomb (04-12-2021)
Old 04-12-2021, 09:48 PM
  #489
zbomb
zbomb's Avatar
It's working well - at my current still very novice skill, its easy to drive and neutral. I would be more than happy to help someone else spend money so you let me know when you're ready !
Watching the Palmer video and the ton of other footage I have is kind of cringy because I critique each corner and how easily it looks from the couch I could have / should have gone faster. I have the data to use in tandem with the video and it paints an interesting picture that shows, I have a long way to go as a driver. But, I am pretty happy with the progression - I am able to feel more in the car and its slowing down for me a lot more than even just a couple track days ago - step by step, brick by brick !
Old 04-12-2021, 09:54 PM
  #490
Jnelso
Jnelso's Avatar
You guys are making me nervous, I may have to trade in my B8 Bilsteins and H&R springs for coilovers.
zbomb (04-12-2021)
Old 04-12-2021, 09:56 PM
  #491
zbomb
zbomb's Avatar
F YEAH ! Let me help spend some of your money too !
Not that I want to be a bad influence on anyones finances... But I do, I really do want to be a bad influence on your finances
Old 04-12-2021, 09:58 PM
  #492
Jnelso
Jnelso's Avatar
I know its always better to have a partner in crime.
Old 04-12-2021, 10:02 PM
  #493
Jnelso
Jnelso's Avatar
There was a great quote from someone previously on Rennlist that said its OK to list your expenses just don’t add them up.
Old 04-12-2021, 10:07 PM
  #494
zbomb
zbomb's Avatar
Forgiveness not permission brother - learn it, live it, go faster
Smart dude !
Jnelso (04-12-2021)
Old 04-12-2021, 10:37 PM
  #495
hbdunn
hbdunn's Avatar
FWIW
I don't have the data you have but my day at Palmer I didn't see oil temps above 220F measured from the factory sensor. It was only about 50 degrees that day. I also recently installed a center radiator and while I was only going by the dash gauge it ran cooler than any of my previous track days.
Quick Reply: zbomb's confused 996
