zbomb's confused 996
#226
I own a machine shop.... I got saws . And lathes, and bridgeports, and and and..
#227
That looks like a really nice way to measure oil pressure before the engine. I see a pressure transducer there, is the other a temperature sensor?
If it is a temp sensor try to get the element sticking into the flow of oil. Your picture looks as if it may be recessed a bit, which will give lower readings if it's measuring a stagnant pocket of oil.
Remind me, is the oil cooler before or after the filter? If you're measuring pre-cooler temperatures it will obviously be somewhat higher than post-cooler temps. How much would be tricky to figure out.
Can you add a second oil pressure sensor to the AIM? You might want to measure oil pressure at the standard location, too, using a "T" fitting so you can compare them. 42 Draft Designs makes an oil pressure splitter block that I have used for multiple sensor installs. Hmm, seems they don't make it anymore - too bad, it was a nice product.
Ratchet1025 (02-08-2021)
#228
The filter is before the cooler. Measuring delta across the cooler would be nice, just not in the budget at the moment. I think it gives a pretty good basis for generating data in any case and should represent worst case scenario.
Adding another pressure sensor for the aim is possible. It would need to be mounted and I need a channel expansion to get another QTY 4 analog sensor inputs.
The housing I got is like a 45 dollar eBay special, I would have liked to use something higher quality and I looked for a while but could not find the 13/16-16 with 2 1/8 NPT from the established MFGs.
That said, I’m hoping it can be made to work.
#229
If you want to modify the adapter fitting I can do that. I'd suggest that you bring as many pieces as possible - IE, the spin on adapter - so I can measure accurately. I probably have a longer piece of 13/16 threaded tube from one of my VW oil cooler installs. MOCAL sends a long and a short piece to fit different cars. The VW's might be 3/4? I can't quite remember now. Anyway your adapter can surely be modified to suit.
zbomb (02-08-2021)
#230
I’ll get the LN adapter off tonight and can drop off everything involved to you tomorrow or whenever convenient.
Shoot me a PM with whatever works for you and I’ll make it work for me.
#231
Today was one of those days... Don't have the tools I need, Amazon shipments delayed, don't have the parts, oh yeah - and I am not a mechanic, so some things - especially where something needs to be created... take forever and sometimes after forever, come out like **** and have to be redone.
So... I failed to get the steering sensor mounted, what a bitch that job has turned out to be - the riv nut tool kit I bought doesn't come with M3 despite the fact I did buy M3 riv nuts, totally my oversight. No problem, do it the old fashioned way with a bolt and a washer...nope, rips the threads off the bolts. Ok... back to the drawing board after dinner on that front.
Oh yeah... the best part of the day - after laying in the footwell for a ridiculous amount of time vacillating on the least ****ty way to mount the string pot for the steering sensor...hmmm, that looks like the clutch may hit it when fully depressed - I should check before committing. Push the pedal down with my hand...TO THE FLOOR... ****.... The gearbox is out...and the inside of the slave is on my floor along with a bunch of brake fluid....great ! what a dunce.
So then, I decided to back it off a few notches and finish moving the horn button now that I have the Cup quick release with no horn provision mounted... that came out well. And I remounted the dash mount to a much more secure location, I can also see it better, so that's a win.
Still feeling mildly cranky about the fact I cannot seem to get the **** I need done...done a thought came into my head after seeing a message from a friend pop in my inbox.
I AM WICKED LUCKY
I have got support from some really great people that have made my life a lot easier than it would otherwise be, they have gone way, way out of their way to help me out and asked nothing in return. Some companies have answered my emails, texts or phone calls after hours or on the weekend, they've helped me out with advice or even getting me a new part out overnight when I broke something. I figured a small way I could show my appreciation for these folks...
My Hood of Fame...get it...Hood, like Hall....But its a hood....anyway.
Thank you to the people / companies listed, you'll finish every lap or get to every destination just a bit before I do. PS.. I have to request stickers from a couple more very deserving companies and I'll update as the Hood of Fame grows.
I AM WICKED LUCKY
The following 7 users liked this post by zbomb:
Jnelso (02-14-2021),
plpete84 (02-14-2021),
Porschetech3 (02-15-2021),
Ratchet1025 (02-14-2021),
RC713 (04-19-2021),
and 2 others liked this post.
#232
Man its nice to be reccognised, though i suspect thats for a different Aaron .
#233
Very cool credits board!
Keep up the good thinking and methodical work, it will absolutely pay off. Keep the Instant Gratification frustration bug at bay.
This year will be really cool with this car. The instant gratification problem I have is I want to see you get out and race this thing!
Here's my favorite pic: Racing with the fall colors in Massachusetts around you. Come on! How much better does it get?
The following 2 users liked this post by golock911:
Ratchet1025 (02-15-2021),
TheChunkNorris (02-15-2021)
#234
I like that pic a lot too ! here's one without the watermark for ya... That day was really fun and the track is something else.
The following 2 users liked this post by zbomb:
golock911 (02-16-2021),
#235
Palmer is an amazing track.
I took this picture from the rocks above Turn 1 looking back towards the rest of the track. Watch zbomb's video to see these turns from in-car! On the rocks in the center of the picture are two layers of track. The middle layer is Turn 4 and the upper layer is Turn 10. Yes you change elevation about 150 feet from Turn 2 to Turn 4, then another 150 feet from Turn 5 to Turn 10, then 300 feet from Turn 10 to Turn 14 leading onto the "straight" which is actually the curved bit of track that's on the left of the picture.
The following 2 users liked this post by theprf:
zbomb (02-15-2021)
#236
Some redemption today...Lot of time lying upside down in the footwell paid off - when the smallest rivnut tool I could find shows up Wed (Please baby Jesus let Amazon not be delayed) I can crunch the 2 rivnuts in and be done with it. Thanks to my little guy Tyler for being my tool maid and making it so I only had to get out of position a couple times. Also, found an excuse to buy that right angle drill that worked pissah.
The sensor is mounted on the firewall. A section of non shrunk shrink tube goes around the steering shaft for a flat surface and the string of the string pot and the shrink tube are secured to the shaft with a hose clamp. Just looking at it - does not look like it should have taken nearly as long.
#237
"string pot" I haven't seen those !! Nifty little idea for some electronics fab work....
#238
Not to resolution yet QC, but a path is there, turned out to be a little more involved to get the pieces working together than just cutting the adapter fitting down.
Once resolution has been achieved, I’ll let you know what it took to get there.
