996 Forum 1999-2005
UAOS install/tips/tricks
Old 02-09-2022, 02:47 AM
  #511
Porschetech3
Porschetech3's Avatar
Received 4,741 Likes on 2,138 Posts
Originally Posted by 501Max
A certain 922 996 will return to Barber Feb 19-20 with Chin giving the track drain an opportunity to work and earn its' keep
Thank you @Porschetech3 !
Time for a new sticker:
You will be well satisfied with the performance of the UAOS with Track Drain !!
Good luck and have fun at Barber !!
501Max (02-09-2022)
Old 02-19-2022, 12:01 AM
  #512
c210rg
c210rg's Avatar
Hey Skip, was wondering if you knew when the UAOS CFN kit will be available again. I am ok with the carbon fiber accumulator vs the aluminum one. I will also be ordering the drain back option as well. Just trying to keep the price down. Thanks.
Porschetech3 (02-19-2022)
Old 02-19-2022, 12:18 AM
  #513
zbomb
zbomb's Avatar
Received 4,295 Likes on 1,813 Posts
Dude - I am cheap and value oriented, so it is very rare I would advocate for the gucci part... Get the alum accumulator, it is entirely worth the money, The construction is vastly superior to the alternative.
Old 02-19-2022, 01:13 AM
  #514
Porschetech3
@c210rg the contract I had with the company who I hired to make the Carbon Fiber/Nylon Accumulators had ran out and they tried to jack the price on them. I already had George making the CNC Billet Aluminum ones which are much more robust and beautiful that I discontinued the Carbon Fiber/Nylon ones.
You will not be disappointed !!!
CNC Billet Black Anodized Aluminum Accumulator with "Cotes De Geneve" finish
Old 02-19-2022, 01:40 AM
  #515
c210rg
c210rg's Avatar
Thank you both Porschetech3 and Zbomb, I have no doubt it's worth it. The carbon fiber one was $250 less and was thinking of other things to spend money on that's all. I will order the now standard UAOS and be very happy. Thanks again for a great product.
zbomb (02-19-2022)
Old 02-26-2022, 03:33 PM
  #516
c210rg
c210rg's Avatar
I have ordered the UAOS with drain back. Will I be receiving a confirmation email or can you just tell me I am all set, either way works for me. Thanks.
Old 02-26-2022, 07:07 PM
  #517
Porschetech3
Thank you for your order, it is placed in queue, you're all set !! I will be shipping it out next week and you will receive a tracking # when it's on the way.
BTW : I do need your year model to send the correct kit..Cheers !!
Old 02-26-2022, 09:00 PM
  #518
c210rg
c210rg's Avatar
Thank you for the shipping info. I knew I forgot something, 2003 C4S Tiptronic. I am going to do the "blow-by-test" before install. My manometer readings are a bit low right now, 3.89 inH2O. Either I have a leak or possibly my new engine didn't get the proper ring break in. We shall see, also want to add data to your blow by thread.
Old 02-27-2022, 01:10 AM
  #519
Porschetech3
Thank you, yes, -3.89 inH20 is lower than expected on the factory AOS system. I will be watching/interested for your test results
Old 03-13-2022, 06:41 PM
  #520
c210rg
c210rg's Avatar
Hey Skip and others, Got pretty far this weekend with the UAOS install. Last manifold bolt was not to bad getting out, I used a small 10mm wrench. The hard bolt on the AOS was 5mm socket screw, that made that easier. The tough time I had was getting the most forward manifold bolt started, my manifold was being pushed outward and it made starting the bolt and getting it down far enough to get a wrench back on it rather difficult, but i finally got it.
The problem I am having is with the new tube going reward from the new sealed AOS to the accumulator pushing the brake booster hose up into the roof of the engine compartment. It is pretty tight now and I have not raised the engine back up. I don't see how it's going to fit, I tried other ways of routing, but it didn't seem to work either.
The other problem is when I close my deck lid, the fan hits the new remote AOS. With about 2 inch's to go it hits pretty hard. I thought about cutting the hose from the remote AOS to the intake plenum to shorten it up a bit but that gives me less wiggle room to make that tight bend from the AOS to the plenum.
It was all pretty straight forward up to here, any help you guys can give me is very much appreciated. I've included some pictures of my problem areas.
Spoiler
Old 03-13-2022, 06:56 PM
  #521
Porschetech3
Do you have the factory deck lid and fan ?
I haven't had anyone have an issue with an 03 ..
For the aluminum/nylon breather hose , the aluminum part should be angled down more away from the power brake hose. You should be able to twist it some in the nylon to clear.
I know its it's a tight fit, but everything is on a Porsche...lol
PS. you can also slightly shorten the rubber hose from the back of the regulator to the intake, that will set the regulator back further to get more fan clearance..
Old 03-13-2022, 07:16 PM
  #522
c210rg
c210rg's Avatar
Hey Skip, it is a factory deck lid. The hose from the sealed AOS is hitting the intake manifold toward the front of the engine, so it wont go down any further and pushes it up against the brake booster line. I looked at all the install pictures hear and it didn't seem anyone else had this issue. I will keep playing with it and see where I get, just thought you or someone might of had this issue and had a simple solution. Yes it's all fairly tight but I'm use to that. Thanks again.
Old 03-15-2022, 05:47 AM
  #523
RuVaRo
8th Gear
RuVaRo's Avatar
Spoiler
I had the same problem with my 2002 C4S Tiptronic and solved it.
Just have the brake hose tube under the tube from AOS to UAOS-Catchtank
See next photos
Old 03-15-2022, 04:00 PM
  #524
c210rg
c210rg's Avatar
Ya that's where I ended up at to make it work. Thank you for the suggestion. Someone else may run into the same problem and will see your post, so good to have it documented.
Old 03-15-2022, 11:21 PM
  #525
Porschetech3
Yes, running UNDER will work just well, but the offset in the Custom Aluminum/Nylon pipe is designed to go down and over at a 45 degree angle to clear the brake hose and align with original routing.
Some adjustment may be necessary, but as always "more than one way to skin a cat"..
Quick Reply: UAOS install/tips/tricks
