996 Forum 1999-2005
What did you do to your 996 today?
Old 04-01-2022, 11:15 PM
  #7036
philbert996
philbert996's Avatar
Received 1,143 Likes on 536 Posts
Haha, I didn’t remember how to turn the rear wiper on.
Old 04-02-2022, 08:29 AM
  #7037
3/98 911 coupe
3/98 911 coupe's Avatar
Default Are you near Birmingham???
Originally Posted by Porschetech3
In Alabama tag/registration on my '99 996 is only $30.91 for a year. No inspection or sniff test, just "run what you brung" ...
But the Feds will still bust a shop for "tampering with emissions" so most shops won't do it unless it's an "off-road only car"...
i Maybe picking up a car there. If you are close enough would like to meet you, drink a beer or two, share a meal. Let me know. Off course my treat.
Old 04-02-2022, 08:54 AM
  #7038
3/98 911 coupe
Default Car wash, early morning coffee, not
Last week I washed the car on Friday night, the dew and the pollen were bad so other than clean wheels it look dirty. Today got up early. Watched a bunch of You tube videos on the cayenne gts with the wife and now car cleaning. Yes had to start the day with caffeine, yes sir, old grand dad 100 and rebel 100 Coke Zero to add caffeine to the mix, Porsche Saturday is here vroom vroom.
My trusted artic mug keeps it chilled.
I haven’t had any coffee since April 12 2013.
Old 04-02-2022, 09:36 AM
  #7039
EVOMMM
EVOMMM's Avatar
Received 1,659 Likes on 970 Posts
God bless your liver LOL love how you live brother
The following 2 users liked this post by EVOMMM:
Lady Silver (04-02-2022), SSDVC (04-03-2022)
Old 04-06-2022, 07:02 PM
  #7040
GC996
GC996's Avatar
Received 3,869 Likes on 2,205 Posts
Just got my new UAOS with track drain, as well as new LN IMS Retro, LN Low Temp Thermostat and OEM Oil Cooler. Love the look of new parts! See picture below.
Going in to see my Indy next week to have the parts put on the car. Its about time the parts are replaced again since its been ~10 years. My Porsche Motorsports AOS began to fail about a week ago with a muffled high pitched squeal. Just a few days earlier, it tested just fine with the manometer and oil cap test. A few days later I started it up, heard the squeal, tested the oil cap and with the manometer and it was failing. It was time to add Skip's UAOS to improve the durability of the AOS, but to also take advantage of the extra quart of oil it can run to help with oil cooling. The UAOS materials are very high quality and it looks killer. Looking forward to it being on the car!
My LN IMS Retro is 10-12 years old, has seen many track days and has performed beautifully. But since we are dropping the engine, its about time to replace it. I will eventually go with the IMS Solution when I get my engine rebuilt in a few years. In the meantime, I am using the cost savings for other parts that I will be replacing later this year in another visit to the Indy. Yep, will replace the RMS, check the clutch and flywheel as well, but don't think there are any issues.
This is my second visit to my Indy over the past two months, of which they went over the car with a fine tooth comb to look for leaks and test parts. Bores have been scoped, deep sump has been dropped and the bores and oil system are in great shape. No scoring and no debris. Fuel injectors were replaced, plugs, coils, sensors are all relatively new, but they were checked as well. Suspension and brakes are in great shape. Just need to get an alignment and corner balance. After this Indy visit, the next steps will wrap around adding more oil cooling and the UIDS. Next year will be a suspension refresh and then an exhaust refresh.
The 996 is a durable and incredible car if you change the oil often and systematically replace parts over time. What's not to like?!
The following 11 users liked this post by GC996:
Billup (04-07-2022), bmchan (04-06-2022), C2-996 (04-07-2022), escreation (04-08-2022), EVOMMM (04-06-2022), JohnCA58 (04-06-2022), philbert996 (04-06-2022), plpete84 (04-07-2022), Ratchet1025 (04-07-2022), Type65 (04-07-2022), zbomb (04-06-2022) and 6 others liked this post. (Show less...)
Old 04-06-2022, 09:47 PM
  #7041
Boff
Boff's Avatar
Got my car back from storage today.
Had the dealer replace the expansion tank and various SAI system parts while it was there. I’ve done a few jobs on my car as I slowly learn how to turn a wrench, but those jobs seemed well beyond my meager skills.
I should be able to pull off the headlight restoration and short shifter install I have lined up, though!
The following 2 users liked this post by Boff:
EVOMMM (04-06-2022), GC996 (04-06-2022)
Old 04-07-2022, 04:32 PM
  #7042
Sam-Son
Sam-Son's Avatar
Very cool. Always a good feeling knowing everything is tip top.
The Porsche Motorsport AOS failed? Weren't they over engineered to be rather robust?
GC996 (04-07-2022)
Old 04-07-2022, 05:03 PM
  #7043
GC996
GC996's Avatar
Absolutely, the MS AOS has proven to be very robust and really the only safe option for our cars until the UAOS was launched. Mine lasted over 10 years with countless track days. If Skip didn't invent the UAOS, I would replace my failing ms aos with another.
However, the UAOS is superior to the motorsports aos in design and functionality. Because the UAOS is a series of components versus one big plastic piece, you can replace components on the UAOS easily and cheaply, not to mention that the MS AOS could never run oil levels above full. Whereas due to the design of the UAOS, it can handle running an extra quart of oil above full, possibly more. This is HUGE for engine cooling, oil starvation mitigation, engine longevity and overall a safer, more durable and effective solution for both street and track.
The following 2 users liked this post by GC996:
c210rg (04-07-2022), Porschetech3 (04-07-2022)
Old 04-07-2022, 05:37 PM
  #7044
Porschetech3
Porschetech3's Avatar
Received 4,605 Likes on 2,090 Posts
The Porsche Motorsport AOS was designed to "hold" more oil in the body of the AOS (to keep it from going into the intake), It still uses the same drain hole/size as the Factory AOS, so the oil can't drain any faster to the sump, but it can "hold" more. "Holding" more oil does two things.1. It helps keep oil from going into the intake, 2. it lowers the oil level in the sump which has two effects, one good and one bad,(a) lowering the oil level in the sump helps to keep oil from overwhelming the AOS to begin with, (b) lowering the oil level in the sump causes more risk of oil starvation in high-G turns.
The UAOS w/XTDD on the other hand doesn't hold more oil in the body or the Accumulator ( but can run a higher initial oil level), it has an Accumulator that catches and oil that comes from the AOS, and the Accumulator has another drain to the sump. So neither the AOS or the Accumulator hold more oil, and USES TWO drains to return oil to the sump twice as fast and keep the oil level in the sump much higher to help reduce oil starvation in high-G turns..
The Porsche Motorsport AOS still has a rubber diaphragm that will eventually fail, and is in the same location as the Factory AOS.
The following 2 users liked this post by Porschetech3:
GC996 (04-07-2022), peterp (04-07-2022)
Old 04-07-2022, 07:47 PM
  #7045
GC996
GC996's Avatar
What he says ^
Old 04-07-2022, 08:58 PM
  #7046
Nate.Evans
Nate.Evans's Avatar
*Edit* Double post…
Old 04-07-2022, 11:31 PM
  #7047
JMELZER
JMELZER's Avatar
We had a nice day today so I got her out for the first time this year and then changed the oil.
GC996 (04-09-2022)
Old 04-08-2022, 11:59 AM
  #7048
Dalejohn
Dalejohn's Avatar
Default You guys inspired me!
Because of all the helpful info everyone supplied I finally broke down and pulled the center console of my 996 and painted it. It was a arduous process to keep the surface as smooth as possible as I layered on the paint and clear coat but turned out nice if I don’t say so myself!
Before and after photos..
The following 9 users liked this post by Dalejohn:
AZPete (04-15-2022), Billup (04-10-2022), GC996 (04-08-2022), TexSquirrel (04-08-2022), TheUnscented (04-08-2022), Type65 (04-08-2022), wdb (04-08-2022), Willys 47 (04-08-2022), wyovino (04-08-2022) and 4 others liked this post. (Show less...)
Old 04-08-2022, 12:12 PM
  #7049
TexSquirrel
TexSquirrel's Avatar
Received 2,423 Likes on 1,288 Posts
Wow, that looks really nice Dalejohn!
Dalejohn (04-08-2022)
Old 04-08-2022, 12:23 PM
  #7050
Optionman1
Optionman1's Avatar
Received 2,149 Likes on 1,013 Posts
When I buy this 996tt I might need your expertise!
Quick Reply: What did you do to your 996 today?
