996 Forum 1999-2005
What did you do to your 996 today?
Old 01-19-2021, 11:15 PM
  #4636
SoCal911t
SoCal911t's Avatar
Received 1,474 Likes on 712 Posts
Removed the engine lid with the Carrera fixed wing.
And swapped it for the original lid with retractable wing.
Also installed an airbox and snorkel from a 997 3.8 'S'
The following 4 users liked this post by SoCal911t:
dporto (01-19-2021), LV_996 (03-11-2022), sasilverbullet (01-20-2021), wyovino (01-20-2021)
Old 01-19-2021, 11:24 PM
  #4637
Mike Murphy
Mike Murphy's Avatar
Received 1,724 Likes on 1,071 Posts
Originally Posted by TexSquirrel
Ha!
I just informed my wife recently that I'm getting in line to have my engine rebuilt by Flat 6 Innovation.
Her only concern was, "are you sure that electric cars aren't going to completely replace gas powered cars?"
I told her I'd be the crazy old guy polluting the environment with my home brew fuel before I quite driving my 911.
Her response was, "it's your car...you're going to do what you're going to do, so go ahead."
BTW, there's no need to spend $1500 on control arms.
I spent $340 for the front and a ~$550 for the rear. (do the front first, then decide if you want to do the rear)
The Feal coil overs ran about $1400 though.
I don't golf, I don't fish...much. So instead I spend money on my car...and on tools.
For all we know, having a 996 engine rebuilt could be better for the environment than buying a new electric car.
The following 4 users liked this post by Mike Murphy:
996fried (01-24-2021), jandackson (01-20-2021), paddlefoot64 (01-19-2021), TexSquirrel (01-20-2021)
Old 01-19-2021, 11:47 PM
  #4638
paddlefoot64
paddlefoot64's Avatar
Love your fender cover!
The following 4 users liked this post by paddlefoot64:
Mike Murphy (01-20-2021), sasilverbullet (01-20-2021), TexSquirrel (01-20-2021), Tom Loder (01-20-2021)
Old 01-20-2021, 01:09 PM
  #4639
Ponchobroke
Ponchobroke's Avatar
Nice day here ~56 deg... DRIVE TIME!
The following 6 users liked this post by Ponchobroke:
Guaji (01-29-2021), Mike Murphy (01-20-2021), paddlefoot64 (01-20-2021), RazorKQ (01-20-2021), sasilverbullet (01-20-2021), SoundnSpeed (01-20-2021) and 1 others liked this post. (Show less...)
Old 01-20-2021, 10:44 PM
  #4640
plpete84
plpete84's Avatar
Received 1,828 Likes on 924 Posts
Drove it on a beach!
The following 9 users liked this post by plpete84:
dcsjc (01-20-2021), dporto (01-21-2021), FLTWRLD996 (01-22-2021), Guaji (01-29-2021), Houtx996 (01-20-2021), KellyMN (01-20-2021), Mike Murphy (01-21-2021), paddlefoot64 (01-20-2021), sasilverbullet (01-21-2021) and 4 others liked this post. (Show less...)
Old 01-20-2021, 11:33 PM
  #4641
dcsjc
dcsjc's Avatar
Pismo? Haven’t had the guts to take the 996 there but when we drove our A4 there we got a note from the Audi service dept, “large quantities of sand found in lower engine cover.” Ha!
Old 01-20-2021, 11:48 PM
  #4642
KellyMN
KellyMN's Avatar
That’s an epic pic that needs to be blown up and framed!
Old 01-20-2021, 11:59 PM
  #4643
plpete84
plpete84's Avatar
Thanks gents. This was actually in Chincoteague, VA while on a little get away. Cool area with wild horses roaming the island. Trip back home is about 170mi so should blow out most of sand. Didn't go crazy but a very fun experience.
Old 01-21-2021, 12:07 AM
  #4644
SoCal911t
SoCal911t's Avatar
It's cheap peace of mind and the little pouch is actually useful. It's NLA from the dealer but I stumbled across this NOS one on Ebay for around $60.00 I think. They still pop up once in a while. Porsche calls it a 'Service Cover' and it's part # PNA50599600.
Better pic:
dporto (01-21-2021)
Old 01-21-2021, 09:55 AM
  #4645
rino924
rino924's Avatar
Needed a place to put this and didn't want to create a new thread. I have done some reading but just want some opinions once I get my car out on the road again this spring.
2001 Carrera, 77k on the miles. I bought it towards the end of September and only have about 300 miles on it before I parked it for winter. Shortly after delivery I had to have O2 sensors replaced and had a leaking coolant line going into the thermostat. Last few times I drove it I was leaking coolant out the front bumper. Took it all apart and I suspect radiator. Looks like the other radiator in my service records has already been replaced.
I plan to take the car into the Indy dealer in March probably to get that done. Anything else I should probably address? Some notable things done are below:
43,518 miles (Oct 2011): new coolant tank, cap and passenger side radiator
55,187 miles (Oct 2013): new clutch
61,212 miles (July 2015): Spark plugs and fuel filter replaced
68,459 miles (June 2018): IMS and crankshaft seal
77,184 miles (Sept 2020): water pump drive belt, new front shock, new front and rear brake hose
I don't see a new water pump in my service history so maybe have that addressed with the radiator replacement? I am sure the suspension is getting tired but that might be something I do on my own down the line.
Just want some opinions instead of me just throwing money at the car
Old 01-21-2021, 10:54 AM
  #4646
TexSquirrel
TexSquirrel's Avatar
Received 2,423 Likes on 1,288 Posts
That sounds like a solid plan to me.
I'd definitely replace the water pump & thermostat if you don't know how old they are.
Old 01-21-2021, 10:58 AM
  #4647
rino924
rino924's Avatar
Perfect I will add that to the list, thank you
Old 01-21-2021, 01:25 PM
  #4648
bill_996
bill_996's Avatar
I agree that it is a good idea to replace the water pump and thermostat while the coolant is drained. Then check the drive belt and pulleys for wear.
It is probably also a good idea to replace the resistors or the whole fan units while you are doing the radiators. The fans have to be removed when changing the rads anyway and the resistors are a common failure item that mean that your fans will not come on with the a/c or when the engine is hot enough. I am replacing both of mine after I was unable to get the fans to turn on with a Durametric.
Old 01-21-2021, 01:32 PM
  #4649
Mike Murphy
I will go against the grain and tell you to inspect the water pump, but I wouldn’t necessarily replace it. Some WPs last 20 years and have no visible wear, while others have replaced them and they last 6 months or 2 years. There are a lot of thing that cost a lot of money on this car. Proactively replacing components could just result in spending money for no reason. That said, the WP problem is that if they do fail, they could cause major catastrophic engine failure because the engine gets too hot, even if the gauge shows a normal temp. So it’s a catch-22. I know of no safe way to prevent this, even if some say that replacing the water pump could prevent this, unless you place temperature sensors in various areas inside the engine - not realistic. If the WP shaft is loose, or the WP is leaking, or if the impeller has lost some blades, then yes, replace it. If it still looks and feels like new, but is indeed older, it might be a good one and will continue to last. If you do get a new WP, then make sure you pick the right one. Don’t go with metal impellers, and don’t pick a cheap one.
EDIT: even some newer 911s have WP issues, such as the 997 and 991, so it’s not like newer is better.
Old 01-21-2021, 06:21 PM
  #4650
sdematt
sdematt's Avatar
Corrected below
Quick Reply: What did you do to your 996 today?
