993 Forum 1995-1998
New! 9m93 Speedster widebody - full build in detail
Old 02-15-2010, 06:48 PM
  #241
NineMeister
NineMeister's Avatar
Marc has mixed the colour base coat, so not long to wait now, Graham!
Old 02-15-2010, 08:02 PM
  #242
JPP
JPP's Avatar
O.k., now I'm paying attention. Here we go, Graham ....
Old 02-16-2010, 12:38 PM
  #243
grahampeterm
grahampeterm's Avatar
And ........ I'm waiting! As are, I suspect, a few peeps on RL ! Have I made the right choice????? Should we have gone lighter ..........Fountain........Azzuro.......Wakeboard (find that one if you can!) or 'std' Cobalt............
Graham
Old 02-16-2010, 12:51 PM
  #244
alpinadvl
alpinadvl's Avatar
Graham
Here's some support for you :
I want to see a cobalt blue speedster !
(ps: you can always go thru the whole paint-stripping process again at a later time if you get bored ! )
ps: great job by all involved. certainly is top notch workmanship ! (keep those pictures coming!)
Old 02-16-2010, 01:46 PM
  #245
Barty964rst
Barty964rst's Avatar
It's a good question. That car is still UK registered but the owner now resides in Geneva so he has taken it back there (with his other car, a red RHD 964 RSL) to play with for the summer. I suppose it would be a good enough excuse for a journo to take a nice trip to Switzerland for a weekend break .....
I'll post a few photos on the 964 forum to keep you happy in the meantime.
Thanks Colin, was a great article from memory. The fact I remember it proves that statement! look forward to pics and thanks.
Old 02-17-2010, 01:28 AM
  #246
brucec59
brucec59's Avatar
That car could be any color and it will be absolutely stunning, I'm sure.
Old 02-17-2010, 09:39 AM
  #247
NineMeister
Nearly there boys!
To get the shell ready to colour paint the underside and engine bay the lads have flatted off the surfaces to be painted with scotchbrite, cleaned off the residue and are now applying soft edge masking (foam tape) to the wheel arch lips to make it easier to blend in the top coat when the outer panels are painted. Once the soft edge is on, the rest of the car is masked and bagged to keep off overspray.
The lads are having lunch whilst some other parts are baked in the booth, then the shell will be rolled in and colour painted this afternoon. You can see a sneak preview of the Cobalt on the 964 rear bumper section test piece which is in the foreground of one of the shots.
Anyone spot the two RHD yellow 993RS's in the background?
Old 02-17-2010, 11:22 AM
  #248
Nollie
Nollie's Avatar
OH WOW that is going to be stunning!
Old 02-17-2010, 12:00 PM
  #249
NineMeister
It's Cobalt Blue!!!!
Sneak preview of the waterbased basecoat mid-application from outside the booth; another couple of coats to ensure full coverage, air dry & then hit it with two coats of clear lacquer. It's only when the lacquer is applied that the metallic in the base colour will start to come alive.
Old 02-17-2010, 12:01 PM
  #250
grahampeterm
Guess where I gotta go tomorrow!!!
Old 02-17-2010, 12:03 PM
  #251
JPP
JPP's Avatar
Nearly there boys!
So, the does the foam tap create a 'rolled' edge situation which allows the paint to fog/blend at the edges instead of creating a ridge?
Old 02-17-2010, 01:45 PM
  #252
NineMeister
The foam soaks up the paint and naturally feathers out the paint edge over a narrow band; you usually use it in door gaps so that you can paint straight across the quarter panel and door without having to paint the door shut and door frame.
Old 02-17-2010, 01:54 PM
  #253
H.H.Chinn
H.H.Chinn's Avatar
Excellent work!!! The Cobalt blue is absolutely stunning! How many coats of clear are you planning to apply in the end? I've seen up to five on a C coupe with incredible depth in the color.
Old 02-17-2010, 02:11 PM
  #254
NineMeister
Oh yes, it's definitely blue .....
All laquered, solvents have flashed off (evaporated) so it's ready to bake. That's Marc in the paint suit and his oldest son Reece who's come in to work with his dad today to stave off the boredom of school half term.
Old 02-17-2010, 02:19 PM
  #255
NineMeister
There are many different types of clear lacquer, the latest specification from Lechler is a high solids version which gives full coverage with two coats, a tack coat to seal the surface and a wetter finish coat which flows out to form a level finish. On outer panels we would leave the second coat of lacquer wet for as long as possible before baking to give the paint a chance to level. Obviously if you can get full coverage in two coats you are going to use a lot less solvents in the painting process, so the later thicker paints have less impact on the environment.
That said, on the outer panels I suspect that Marc may lacquer it in two coats of high solid as normal, then dry flat the whole car and hit it with a third coat to achieve the additional show quality paint depth that you mention.
Quick Reply: New! 9m93 Speedster widebody - full build in detail
