[Engineering Explained] Porsche's New 911 Engine Is Absolutely Brilliant
#166
You are misquoting me to my own face. If you didn’t get what I wrote or don’t understand the bigger picture . Porsche was heavily restricted with what they could do with ice. They were even encouraged to build faster EV.. They played you. I see won . Have fun watching your money evaporate with this car . Even worse could be driving a service loaner more than actual car..
Edit: I’m seriously cracking up here that your threat is I’ll spend time in your car.
#167
I didn't read this entire thread but the Engineering explained video had 3 things that stood out to me as non truths.
1- I believe he compares weights of the old car to the new car with the standard rear seat delete which gives a false sense of how much weight the hybrid system adds. He says 103lbs i believe. The porsche official reveal said 50kilos, or 110lbs. I don't think we have official numbers on the hybrid system. But maybe he's right on this one..maybe
2- he claims that the weight doesn't affect handling because the car is faster on the nurburgring, which is absurd, because the weight does negatively affect handling and the car is faster on the ring because it has more power. That should be obvious to anyone with half a brain. He uses very tricky wording to lure you down that path of logic. Not cool. Dishonest.
3- The most disingenuous and enviro-apologist claim of all, he claims that Lamba 1 doesn't negatively affect horsepower. That's a preposterous and false claim. I can't even believe he made this point with a straight face. The engine has a 20% bump!!! in displacement and a giant turbo and only makes 5 extra horsepower. And he disguises it very cleverly for those who aren't paying attention by using the combined system's power (including the electric motor) to prove his point. Slimy. Apologist. Dishonest. Not cool. He knows better
To put it in perspective, 50 kilos (110lbs) is roughly equivalent to having an overweight driver or having a 13-year-old passenger in the car, how much will that impact performance? Moreover, the engine mounting is 10 cm lower, which lowers the center of gravity and better handling.
Lambda 1 and Horsepower:
Regarding Lambda 1 and its impact on horsepower, Lambda 1 is about achieving a stoichiometric air-fuel ratio, which optimizes emissions and fuel efficiency without necessarily sacrificing significant horsepower. The 20% bump in displacement with only a 5hp increase can be attributed to various factors, including emission regulations and the integration of the electric motor. Using combined system power to illustrate the overall performance boost is valid and reflects the complexity of modern hybrid systems and emissions standards.
You might be a guy who doesn't even know how to change your own car’s oil. Jason Fenske, has a mechanical engineering degree and years of experience. His analysis is based on real technical knowledge. Calling him "slimy," "apologist," and "dishonest" is ridiculous.
#168
This thread is about the GTS but question about the base 992.2. It says it uses the same 3.0l engine but paired with the larger turbo's of the 992.1 Turbo. I assume that means the variable vane turbocharger design previoulsy reserved for the "Turbo"s since the 997 generation now gets introduced to the base 911? I like that thought. Also, the 992.2 base gets the larger intercooler, yet, the intercooler intakes on the lower rear bumper of the base bumpers is gone...so, not needed, never needed before or what?
#169
Weight and Handling:
Billy Bluejay (06-21-2024)
#170
I'm enjoying this thread.
![popcorn](https://rennlist.com/forums/images/smilies/popcorn.gif)
#171
If you think putting the engine 10cm lower equals a nearly 9 second improvement at the ring, then you are wrong. Sorry. It's from the increase in horsepower and torque. I don't understand the point you're making about having a passenger as extra weight. Extra weight is bad and negatively affects lap times which he claims magically didn't happen here. That's a lie.
Wow I might be. Or I might have done 6 or 7 engine swaps in my garage on jack stands. You'll never know. But you are defending bad information based on the fact that you think Jason Fenske is an authority figure. Speaking of which, it's probably time for your 6th booster.
Jason is well known and has over 3.8 million followers, which says something about him. I think you need you show some facts before you can discredit him.
#172
Well Jason is well known and has over 3.8 million followers, which says something about him. I think you need you show some facts before you can discredit him.
#173
Can we limit the "shoving" etc. please.
siberian
siberian
The following 4 users liked this post by siberian:
#174
The vents on the sides of the lower rear bumper of the .1 base and .1 S were the air flow exit points for the intercoolers. The air enters from the top engine grill cover which is the same for the .2. The .2 base uses the the old GTS/ Sport Design rear lower diffuser section with one large air exit vent below the license plate area in between the exhaust outlets.
edit: found an image of the 992.1 Turbo S that shows the cooling air flow.
![](https://cimg1.ibsrv.net/gimg/rennlist.com-vbulletin/1366x768/p20_0014_a3_rgb_15beef0665a05505c4df3f161a14e6c0220a6993.jpg)
Tobeit (06-18-2024)
#175
I think you didn't get his argument, 110 lbs is almost nothing in a car that weighs close to 3600 lbs, and having a lower center of gravity has a lot to do with handling which leads to a better utilization of the power.
Say that in the Carrera T thread where they worry about 20lbs because it makes such a huge difference. lol.
I've been watching EE videos for many years and he's very knowledgable. That said, everything he stated in the video is technical specifications that Porsche provided (to everyone). It's one thing when it's on paper, but again, would like to see real world battery testing as well as reliability.
Having said that, I don't mind one bit someone mentioning issues with the video. Why not? Maybe they have legitimate concern with something in the video. I would like to hear it for one.
#176
Go watch the video again. That's not what was said or implied. He floats the idea that the weight didn't negatively impact handling. It's a very dishonest and purposely misleading description and use of words and concepts.
I love Jason's videos as well. In this case he put out clearly misleading information, and the story that he decided to tell with the numbers is not representative of the truth. So I'm calling it out. I don't know what facts you want me to produce out of thin air. I'm not gonna whiteboard it for you. Ask one of the tuners to better explain it. How about we make some predictions based on our knowledge of engines and see who ends up being correct?
#177
#178
************************************************** (edited). You clearly don't know what you are talking about. You also contradicted yourself by saying "Including emissions regulation". LMAO...yeah that's what Lambda 1 is!! It's an emissions regulation decreed by the EU. It's not done voluntarily. You will be proven wrong when someone cracks the ECU and unlocks an UNPRECEDENTED amount of horsepower because Lambda 1 is in fact so detrimental to horsepower. You can do all the mental gymnastics you want, but when you increase displacement by 20% and add a larger turbo and lose torque, guess what? The timing table on that motor is probably pure trash. Please see yourself out of the conversation
Thank you for removing that comment, I understand that I was not intended.
#179
I don't know the answer to the turbos question.
![](https://cimg5.ibsrv.net/gimg/rennlist.com-vbulletin/1001x677/intercooler_base_bumper_c142aa1c2a713b67d9984cfb134ce3546da27bf4.png)
#180
I said Lambda 1 optimizes emissions and fuel efficiency. It's not solely about emissions regulation; it's also about achieving the optimal air-fuel ratio for engine performance. I didn’t contradict myself, and your pathetic attempt to sound knowledgeable by insulting is others is as weak as your arguments.
Can you explain lambda 1 and how it affects horsepower in an internal combustion engine?
ChatGPT
Lambda 1, also known as stoichiometric ratio, refers to the air-fuel mixture ratio in an internal combustion engine where there is exactly enough air to burn all of the fuel completely. In simpler terms, it is the perfect balance between the amount of air and fuel for efficient combustion to occur.
When an engine is running at lambda 1, it means that it is burning fuel efficiently without any excess fuel or oxygen leftover. This optimal ratio is important for achieving maximum power output and fuel efficiency.
In terms of horsepower, running an engine at lambda 1 ensures that the combustion process is clean and complete, leading to maximum power production. Deviating from this ideal ratio can result in decreased power output, poor fuel efficiency, and increased emissions.
Overall, maintaining lambda 1 in an internal combustion engine is crucial for achieving optimal performance, efficiency, and emissions control.
ChatGPT
