Lithium ion battery
#121
#122
Thanks! Maybe he can explain then why they're placing AGM's in 992s with RAS and what the inherent risks are as I outlined above in writing of course.
siberian
siberian
#123
I don't have the answers to those questions, but if you spend some time searching, you will be able to independently corroborate that while using a lithium battery to compensate for the weight of the actuators was part of the reason, the other part being that the RAS system requires more current than a non-lithium battery can consistently provide per the engineers.
#124
Yes I agree and that was my take. So WHY are they placing the wrong battery in 992s (because they can't get any LiFePO4s) but what are the risks of doing so, as I outlined?
siberian
siberian
#125
#126
And mine, but it should be answered as I certainly wouldn't be too keen to drive a car that may lock the rear wheels 3 degrees off due to a battery fail...
The safer alternative is to DISABLE RAS until the right battery is installed. Furthermore we still don't know whether the battery failure is the battery itself, a BMS error or harness or a combination.
siberian
siberian
#127
Tompoodie (05-16-2022)
#128
siberian
siberian
I am not trying to cast Porsche as some evil empire, just the shareholder value focused corporation that it is. That said, for a higher-end consumer products company selling to enthusiasts, one would think that better transparency and disclosure to the customers would result in increased shareholder value in the long term.
#129
#130
[QUOTE=Drew46;18145956
I am not trying to cast Porsche as some evil empire, just the shareholder value focused corporation that it is. That said, for a higher-end consumer products company selling to enthusiasts, one would think that better transparency and disclosure to the customers would result in increased shareholder value in the long term.[/QUOTE]
Very true on this and several other issues!
#131
Premium Sponsor
is it possible that the charger can damage the harness/bms/sensor on the battery?
i only ask because my issue w/ the sensor flashing low voltage started after i came back from vacation, when i had the car locked and on the trickle charger. it was fully charged, but when i started it, bam, warning light. So it freaked me out that maybe the charger fried it somehow. I use the CTEK lithium charger fwiw, not the Porshce branded, and used the battery positive, but a negative post terminal near the battery (couldn't reach the big negative post by the driver side), using that 'hardwire' ring harness, not the alligator clamps.
But let me also say that Porsche tried to blame an E-Brake Sensor locking up my brake system on the Battery!.. Which is utterly proposterous, so I told them "your wrong" and gave the reasons and they interestingly changed there minds after I said we could go to court on this if they wanted. They will blame anything on other manufactures products to get out of warranty issues. But remember, if you are using the CTEK that is the Porsche Charger so they can't really say anything.
#132
Premium Sponsor
FWIW My 2S is now running RWS with a Porsche supplied AGM battery. Everything seems to work fine in 80 degree weather. I have no idea if that would be the case below freezing. I don’t know how big of an AGM they installed to make it work or how long the battery will handle this type of usage. Just has to make it to the end of July for me.
Might be worth it to your fellow owners on Rennlist and beyond to call the dealership and ask what they did because there are several bringing up this same problem and looking for a solution. Secondly, and and potentially selfishly as an aftermarket business that would like to prove you don't have to have a $2000 dollar Porsche Lithium Battery I would be willing to even pay for that info because it solves what might be a larger problem than we can even see on these forums, and we feel our product is better.
I think this does show Porsche knows they can solve this...so that is good new for many of you.
Last, I am calling boloney on the "necessary" comment from Porsche or whatever engineer said that with RAS... they did it before with AGM batteries, and while LITHIUM absolutely has less resistance and a better ability for higher loads, it does not mean you have to have it for certain loads. Also, if your Car specifically required it, then you would probably want to put even more Amp Hours in the Battery and beef up the Alternator for more output since the Battery isn't actually designed to POWER parts of your Car when running. A battery designed to support and stabilize your charging system and provide starting, lighting and ignition power... not to power RAS, or Power Steering when the Car is running, it just supports any overloads if they do occur. I think for sure using Lithium was a way to improve on several areas... lightweight benefit, better discharge current for higher loads, long life, and for Porsche the ability to make a closed system that generates extra revenue, but I don't thinks it is "necessary" for the car to run normally.
#133
Being I am not the manufacturer of the Charger products, I don't want to step outside of bounds and say incorrect info... but from experiance and understandinf DC current and voltage issues there should be no issues whatsoever with a Charger damaging any sensor simply because it does not do anything more than an alternator does to the battery and in fact does it much less since it will rarely go as high in voltage than an Alternator does at time, and secondly it only puts out about 4~5 Amps Max on a CTEK or Optimate Chargers.... So that would not affect or damage any sensor. They also have reverse polarity protections on these modern chargers, so another thing that would protect the Sensor.
#134
well, i may have gotten lucky! My SA just called and told me they have a battery in stock. Apparently it was set aside for a different customer, but it fell through. he didn't know details, all he knows is that his parts dept told him it's now available for me. So i got an appointment next Wed 5/25 to get it installed.
<fingers crossed>
<fingers crossed>
Fullyield (05-19-2022)
#135
I feel you. In these uncertain situations we tend to look for any and all possible or probable causes but at the end as a renowned sleuth once remarked "when you eliminate everything else then whatever remains however unlikely must be the cause". I think in this case it's unlikely to be a charger (whether Porsche, CTEK or other) but battery related. Now as to whether it's the BMS, physical battery or harness that's for a CSI autopsy to determine. Way beyond anything any of us (and I would venture most dealers) to determine. Most likely the latter will be told by Porsche to ship it home to them - and I doubt anyone will ever really know the cause.
siberian
siberian
Here is the battery module location.
When the battery sit too long at below lower limit, the protection (BMS) stuck in locked state likely corrupted.
The data need to be restored to allow recharge and resume its function. A vendor claim it works for 2018 to 2020 model with above battery series.
PM for more.
