Has anyone done a CarPlay retrofit / Headunit replacement for 991.1
#2746
For me, yes. Just like all of the many above claiming their choice of an aftermarket HU is superior, but you decided to call me out. ![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
It also occurs to me that this decision is probably affected by the model of Porsche that you own. They're all great vehicles.
However, I'm MOST familiar with the pre-owned 911 market, where OEM is very highly valued and commands higher prices. An aftermarket HU would be a turn-off to many potential pre-owned 911 buyers, but a fully functional PCM modified with a perfectly functioning CarPlay solution would be desirable.
#2747
Yes, that's precisely what this discussion is all about. Add Mr12Volt to your list of PCM mods, but it has the advantage over your list because it provides full digital sound quality using the OEM optical outputs. The ones you list have to convert digital to analog.
shammerman (05-20-2024)
#2748
That's great, it really is. I feel exactly the same about the choice I made. Everyone's happy.
#2749
However, I'm MOST familiar with the pre-owned 911 market, where OEM is very highly valued and commands higher prices. An aftermarket HU would be a turn-off to many potential pre-owed 911 buyers, but a fully functional PCM modified with a perfectly functioning CarPlay solution would be desirable.
#2750
As I recall, earlier 991.1 models don't have native CarPlay, but you can fix that with retrofit kits from third-party sellers. These kits are made to work perfectly with the existing PCM system, giving you a factory-like CarPlay experience. Brands like JoyeAuto, Naviplus, and Car Solutions offer these kits, which keep your car's original look while adding modern features.
#2751
#2753
The same applies to the PCM modification solutions, but folks are less likely to want to make the change since it already provides AndroidAuto and CarPlay with a fully functional OEM PCM system. If they value OEM, why would they change something that isn't broken?
#2754
#2755
I'm preparing to install my CHSTEK unit this weekend. My car has front & rear aftermarket cameras. I see on the CHSTEK harness a yellow RCA jack labeled for a rear camera, There are other camera inputs, but none labeled for a front camera. Can anyone give guidance?
Also regarding the cameras, they require a 12v power source in addition to the video feeds. Which two wires am I looking for to feed power to the cameras?
#2756
I'm not really sure why you are hammering this so hard. You are clearly very happy with the choice you made. Just as those who made a different choice are happy with the choices we made. Why do you care so much what other people have installed into their cars? Enjoy what you have like we are enjoying what we have.
#2757
#2758
For those contemplating installing the 'add-on board' type of solution, there is a great thread here on Rennlist which is devoted to just that:
https://rennlist.com/forums/panamera...pcm-3-1-a.html
#2759
Yes I know the PCM nav apps are dated, but I can't remember the last time I did not have a cell signal where I drive. I said factory nav is still there in a pinch, in the extremely remote chance I do not have a cell signal. The PCM maps may be several years out of date, but the main roads aren't out of date and they pre-date the GPS system.
Apps like Google Maps do allow you to download maps for offline use when there is no cell connection (GPS still works on a phone with no cell signal), and the maps are always up to date because 99+% of the time you do have a cell signal and the maps update in the background with no human intervention necessary. Since Waze has been owned by Google for close to a decade now, those maps are updated frequently as well.
Again, I see no upside to the aftermarket head-unit approach except for a slightly larger, and higher resolution screen. However, I'm not watching movies, I'm enjoying driving a remarkable sports car and glancing only occasionally at a map or a music app play screen. Moreover, I do see more downsides to turning the PCM into a paperweight.
but at least the swap is super easy compared to more intricate install process of the retrofit units.
I totally understand porsche people and trying to keep the purity, I 1000000% empathize.
but when a new head unit is cheaper to acquire, cheaper and quicker to install (assuming you are paying for labor) and you get better performance in almost all quantifiable measures. It’s just too hard to ignore imo.
Having spent extensive time with both this is what I would recommend to mos people especially novice DIY’ers.
You clearly aren’t most and that’s exactly why we have options!
#2760
The most disappointing thing for me is what was once an almost 100% argument free thread, growing post by post from the questions and answers of its enthusiastic subscribers, has started to decend down the old and tired path of so many other forums.
Enough everyone please! This thread is only really focussing on those who are interested in Android units - for better or for worse.
Let's all contribute to the forums where we can make a positive contribution, wherever and whatever that may be.
