Has anyone done a CarPlay retrofit / Headunit replacement for 991.1
#2596
It's easy to connect the camera if you have one already installed.. you just connect the camera power cable to one that is marked on the loom that cones with the new head unit and that's it. It should earth through the existing connection you have.
mamick (05-04-2024)
mamick (05-04-2024)
#2598
SECRET BUTTON CONTROL - ERISIN-STYLE UNITS!
While carrying out a controlled scientific experiment (AKA prodding the wrong button), I have discovered an undocumented feature.
If you hold down the heated rear screen button for a second or two the display switches to the rear camera view, even while driving. This can sometimes be useful.
This works on our Cayman and may well work on other Porsche models too. Give it a try!
#2599
@ratt359 I just ordered my Chstek unit and I was looking through the wiring and back of the unit pictures on this forum and on aliexpress, I was wondering how you wired power for the BU camera. When I installed my BU camera with the other Android HU I ran the power and ground all the way to the HU, I did not tap into the reverse light. I assume I will have to tap into the reverse wire on the ISO connector, is that what you did?
I assume the same thing for my MOST box which needs BATT+, ACC and GND.
#2600
Will do. I am in the states and based on the time it took to get the Ersin HU from Aliexpress I don't expect to get the Chstek HU for 2-3 of weeks. As soon as it arrives I will jump on it. Since it is just replacing the HU and knowing how straightforward it was wiring in the Ersin HU I am not expecting it to take long time, we shall see. Honestly my biggest issue the first time was running the wiring for the BU camera and of course forgetting to wire power to the MOST box, doh!
I did message the seller and asked them to make sure the CHSTEK HU had the latest canbus software that addresses the dashboard dimming issue. We will see if that happens.
#2601
#2602
The Erisin Unit seems to use our Quadlock to install the CHSTEK, at least from photos has different wiring harness
#2606
#2608
Guys - the CHSTEK unit isn't the same as this Owtowsin unit here, is it:
https://rennlist.com/forums/997-foru...l#post19413633
That unit is more or less as deep as the PCM, so that's an easy way to tell. I can't find any pics showing the depth on the website
@ratt359 - is your CHSTEK unit the same depth as the Erisin?
#2609
Has anyone got shipping confirmatin of their CHSTEK order yet? I ordered mine on 1st May, it took a day or two for them to ask the question if I needed the Most adapter or not and I have had no update since - the order is still marked as "To ship"
#2610
Things should get back to normal early next week.
