Has anyone done a CarPlay retrofit / Headunit replacement for 991.1
#2716
I see in the guide that was written for the android units, it states that you should have at least 6 GB RAM and 128 GB ROM. Has anyone tried the 4 GB/ 64 GB 8581 unit from CHSTEK? How much slower would the 4 GB on a head unit running CP be? I am asking because the 8/256 GB 7862 and the fiber optic box is over $541 right now on AliExpress and the 4/64 GB 8581 with fiber optic box is $390 on Ebay. Both are from Chstek store. Is it worth the extra $150 to get the 7862?
#2717
#2719
That said, if you only want to run AA or Carplay then 4GB will be fine.. as long as you don't want to take advantage of the native app options in future where more RAM allows faster switching between apps.
Everyone's usage is different.. Go for the bargain if you are confident you'll stick with CP, but do consider if this will limit your options in the future..
The 8581 is also an older unit, much bigger in dimensions and I believe with older CPUs, although I m on a train and can't check that for you to be sure.
The combination of 4gb RAM and a slower cpu is not recommended, but it does depend what vehicle you are fitting it to? If you are replacing pcm 3.1 then I really recommend sticking with the 7862
ZedZed (05-17-2024)
#2720
Factory > Original Car Agreement > Radar Display ON/OFF
Factory > Local Radar switch (choose whether to put radar display on full screen)
Factory > Radar Window (choose whether to display radar overlay - my preferred option)
You'll find all the reverse camera options in there also.
#2721
All the settings you need are under "Factory" (my code was 3368, per the guide):
This should just make these options under a more public menu view!!!
#2722
When my head unit was acting up on me a couple of years ago, (luckily a HD swap fixed it), I remember seeing that you had to get a PCM and it had to be programmed to your car because so much was tied to it. Now it looks like everyone is disregarding that. What has changed? What do we really loose if we make the change to an aftermarket HU? Are these new Chinese units able to control the things that are in the PCM units where the standard Pioneer and Alpine units couldn't? I like these new units (Chstek), but I am afraid to pull the trigger because I'm afraid I will lose some functions that my PCM might be controlling. If it is just items like sending phone, radio, and navigation info to the instrument cluster, I could care less. My car is a manual, does that mean I will have to rewire the backup camara? Will the parking sensors still work? I've seen some comments on the TPMS. Does that go away if it is in my instrument cluster? What else is running through the PCM?
#2723
And it takes less than an hour to install!
Please see resources on post #2700 if you haven't already. I looked at lots of options before buying the CHSTEK (inc Mr12Volt and other Android HUs). Couldn't be happier with the end result!
(I have no factory TPMS so can't comment on that specific)
#2724
There will be a few of us queueing up to answer this one... I know it sounds too good to be true, but you've nailed it (i.e. you only lose the instrument cluster display for phone, radio and nav). For BOSE owners, there's also the minor issue of lack of full fader control for the rear speakers (as the RCA > MOST optical convertor is 2-channel). The list of benefits, however, is a long one... much larger screen, CarPlay/AA, native Android apps, free offline nav and maps (installed to the HU), customisation of look and feel and more...
"Native Android apps" have no appeal to me (as an Android hater), and I'd much rather use the CarPlay apps for nav and music. Other apps don't interest me in the least. For backup, (in those rare cases where you have no cell signal) the factory nav, and every other PCM function works.
shammerman (05-17-2024)
#2726
Hi Whiskey Tango - you have 2 basic options 1) upgrade the internals of your PCM 3.1 with a solution like Mr 12 Volt, or swap out the entire unit for an Android based head unit such as the CHSTEK 7862 that you can find on Ali Express. Both will work in your car which is the same model year as mine.
This thread is dedicated to the Andrioid units, but there is plenty of info out there on the PCM upgrade options.
Please see our guide on this post for all you need to know about Android head unit upgrades
#2727
Factory TPMS still works in the MultiFunctional Display. As you rightly say, the only things that no longer work in the MFD are the satnav display (for obvious reasons), the telephone and radio station display. Everything else is there. PLus, everything that is controlled by he canbus still works as normal - eg the radar proximity sensors (displayed on screen as well as audibly), door open alerts and so on.
Chuck245 (05-17-2024)
#2728
#2729
#2730
Like beauty, preferences and perceived benefits are always in the eye of the beholder. With Mr12Volt, you don't lose anything, and you still have optical outputs providing OEM-quality sound, and all the other listed benefits, other than the slightly larger screen. You also retain an entirely OEM look, which is much better in my book.
