Orthojoe's track build journal
#1216
Originally Posted by facefixr
Another. I must say you dont hear the sound breaking up on the app itself but the lock up of the data happens at least twice a lap for 1-2 seconds.
#1217
Location: Mid-Atlantic (on land, not in the middle of the ocean)
Received 4,381 Likes
Yes, #1. I'm thinking that stickier compound at the outside of the Sport Cup 2 N0 may mean higher temp on the outside, so that could affect what the target temps need to be at the inside, middle, and outside when dialing in the camber.
#1218
the video playback on the phone is good but still shows data lock up...so while the video continues the steering input etc will hang up for a few seconds then catch up. usually 2-3 times per lap. and always at the end/beginning of laps. gonna look into something more like your setup i think.
#1219
To download/export the Track App video I would suggest using QuickTime (on a Mac running Yosemite) with an iPhone running iOS 8.xx
My previous post on exporting.
https://rennlist.com/forums/991-gt3/883831-downloading-porsche-track-app-videos-from-an-iphone-a-how-to.html
Also, for what it's worth, it's helpful to set your iPhone in Airplane mode but with WiFi on.
#1220
Received 1,224 Likes
Anyway, I bought a set of new MPSC2s and a pyrometer, and will share findings in few weeks.
#1221
I agree on different temps for different compounds and that softer compound generally would heat up slightly more given same load and speed. But thinking how these compounds would work within the same tire, it seems that it needs to be reversed - harder compound withstands more friction, so to get even wear of the tire, harder compound should bear more load and thus potentially get hotter. Loading both compounds the same would cause premature wear of the soft part and reduced tire life. Tough to say what's going to factor in more - more heat on softer compound due to higher friction ability or more heat on harder compound due to more load.
Since the wear isn't too extreme towards the outside, I'm hoping that 1.5 cambers won't result in unacceptably uneven wear, and I plan to play with with pressures as needed, thinking that a slightly higher pressure should shift the contact patch towards the center of the tire, if needed.
Another factor is that the tires appear to be heat-cycling out before they wear out, so it's not really necessary to keep the wear totally even in order to maximize the tire life, and instead I'm giving priority to maximizing grip and handling.
#1223
I've had no issues with video playback on the phone.
https://rennlist.com/forums/991-gt3/...-a-how-to.html
#1224
Got my GT3 back today with cambers set back to 1.5, drove the car a bit on the road, and immediately noticed a significant difference in the feel of the car. Steering is less heavy, response to steering is generally better, and feels more planted, just as I remembered it feeling before I increased the cambers to 2.0. I'm surprised how sensitive the feel of the car is to the camber. Looking forward to trying it on track this weekend (all track miles so far have been with 2.0 cambers).
#1226
#1227
#1228
This thread has been kind of dead lately, so I'll try to inject a little life into it, but not much going on.
1) I had a talk with John @ BGB regarding the setup on the GT3, so I have the following setup based on his recommendations:
Front camber -2.7
Front toe out 1.5mm each side
Front caster 9.5 degrees
Front sway bar stiff
Rear camber -2.4
Rear toe in 3mm each side
Rear sway bar middle
I haven't driven the car on track yet, but Chris has, and he thinks the setup is perfect. Outer edge wear in the rear is being sacrificed, but it does look like you need to sacrifice it in order to get the proper dynamics. I'll see for myself next Saturday at thill with PCA.
2) I'm still not enamored with the Trofeo R. I've got a set of N spec MPSC2 (finally) from Damon @ Tire rack sitting in the garage waiting to go on next. The 2nd set of Trofeo R are still wearing more on the rear tires than the front. Very strange since the MPSC2 wore more on the front than the rear. Both tires are good for 4-5 track days.
3) Ten track days on the AP rotors and Ferodo pads:
Front AP rotors still look pretty good for 10 days of track use
Front Ferodo DS1.11 pads:
Rear Ferodo DS1.11 pads:
The rear OEM rotors still look great and barely have any cracks at all.
4) RSS makes adjustable thrust arm bushings now that don't require a spacer/adapter:
5) A pic of the Tarett LCA monoball ends:
6) The car never smokes on startup anymore and barely burns any oil on track.
Front camber -2.7
Rear camber -2.4
#1229
